I have a problem with my new TP-Link HS110 running with openHAB 2.2.0. Here is my items definition:
Switch HS110_Waschmaschine_Switch “Waschmaschine Schalter [%s]” (gWaschkueche) { channel=“tplinksmarthome:hs110:E169AB:switch” }
Number HS110_Waschmaschine_Power “Waschmaschine Leistung [%d W]” (gWaschkueche) { channel=“tplinksmarthome:hs110:E169AB:power” }
Number HS110_Waschmaschine_kWh “Waschmaschine Verbrauch [%.1f kWh]” (gWaschkueche) { channel=“tplinksmarthome:hs110:E169AB:energyUsage” }
Number HS110_Waschmaschine_Current “Waschmaschine Strom [%.1f A]” (gWaschkueche) { channel=“tplinksmarthome:hs110:E169AB:current” }
Number HS110_Waschmaschine_Voltage “Waschmaschine Strom [%.1f V]” (gWaschkueche) { channel=“tplinksmarthome:hs110:E169AB:voltage” }
Number HS110_Waschmaschine_Rssi “Waschmaschine Rssi [%d dBm]” (gWaschkueche) { channel=“tplinksmarthome:hs110:E169AB:rssi” }
Sitemap:
Frame label=“Waschküche”
Switch item=HS110_Waschmaschine_Switch
Text item=HS110_Waschmaschine_Power
Text item=HS110_Waschmaschine_kWh
Text item=HS110_Waschmaschine_Current
Text item=HS110_Waschmaschine_Voltage
Text item=HS110_Waschmaschine_Rssi
The switch functionality is working and the Rssi signal is reported but none of the others. Any ideas what I did wrong? In Kasa App I see the power and kWh values.
Thank you,
Markus
