Hi There,
I’ve recently purchased a TP-link KL50 smart bulb, but I haven’t been able to find a binding for it (openHAB 2.4). Does anyone know if there is one available or if there will be ?
You can try if adding the bulb manually (either in files or PaperUi) as a lbxxx bulb device works. If that works it means it uses the same protocol and I can be easily add it to the tplink binding.
Hi Hilbrand, thanks for your advice. I managed to control it as an LB100. It does everything I need now.
Thanks for your help
