since, the network binding is not available for OH3 I´m using the TR064 binding with maconline to get my presence tracked, the last two weeks.
After some days I was wondering why all my lights went off couple of times a day - presence off = all lights off.
When I checked the logs I can see that randomly all my devices (Apple products) (for testing only one at the moment) went for some seconds offline in the binding.
In the FritzBox the mac addresses were never offline also disabling WiFi will let the mac address online for up to 5 minutes.
Is there a knowing problem in the binding or a refresh problem (fritzbox 60 seconds; lan device 30 seconds)?
In the network binding I know when you do arpping on Apple devices there must be a special setup for refresh / timeouts but I´m not aware of a config like that in TR064.
I also patched my system to the latest stable version - 3.0.1 but still the same error.
Here the logs, when the MACs went offline nothing else happened.
What is really weird that the ON/OFF happens all 10/11 minutes - so there must be something with the binding itself.
2021-04-07 08:13:38.917 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Systeminfo_Openhab1_MemoryUsedPercent' changed from 8.4 to 8.3
2021-04-07 08:13:53.922 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Systeminfo_Openhab1_CpuTemperature' changed from 42.8 °C to 43.3 °C
2021-04-07 08:14:04.681 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhone_Diana_Online' changed from ON to OFF
2021-04-07 08:14:04.914 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhone_Steffen_Online' changed from ON to OFF
2021-04-07 08:14:04.918 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'G_Presence' changed from ON to OFF through iPhone_Steffen_Online
2021-04-07 08:14:08.939 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Systeminfo_Openhab1_MemoryUsedPercent' changed from 8.3 to 8.4
2021-04-07 08:14:19.838 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Systeminfo_Openhab1_CpuUptime' changed from 662.0 to 663.0
2021-04-07 08:14:23.945 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Systeminfo_Openhab1_CpuTemperature' changed from 43.3 °C to 42.8 °C
2021-04-07 08:14:30.140 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhone_Steffen_Online' changed from OFF to ON
2021-04-07 08:14:30.143 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'G_Presence' changed from OFF to ON through iPhone_Steffen_Online
2021-04-07 08:14:30.202 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'iPhone_Diana_Online' changed from OFF to ON
2021-04-07 08:15:08.985 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Systeminfo_Openhab1_CpuTemperature' changed from 42.8 °C to 43.8 °C
2021-04-07 08:15:19.840 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Systeminfo_Openhab1_CpuUptime' changed from 663.0 to 664.0
2021-04-07 08:15:23.996 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Systeminfo_Openhab1_CpuTemperature' changed from 43.8 °C to 43.3 °C
Please set the bindings log level to TRACE, of it happens that often, you should be able to manage the amount of logs collected. Please show the requests before the macs go offline.
Ah you are right, I never checked it after I upgraded it to 3.0 - on the beginning it was not available.
In the past I did it as well BUT Apple Devices / Fritz Box and Fritz Repeater in Mesh are doing stupid stuff. I setuped a static IP on the Fritz for my Apple devices but they don´t like it and when I walk in the house and connect to another repeater it will get a DHCP address for a 2nd MAC address… so I thought the MACONLINE would be a good solution.
