I’ve updated my Fritzbox 7590 to version 7.25 yesterday.
Siince then the TR064 Binding doesn’t seem to work anymore.
I’m getting this error:
Thing 'tr064:fritzbox:9e2a904f7d' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): com.sun.xml.messaging.saaj.SOAPExceptionImpl: Unable to create envelope from given source:
SAAJ0511: Unable to create envelope from given source
The box created a new default user during the update, but the username is not accepted.
Had the same problem.
Then I created an extra user for it in the FritzBox, stored it in the binding and left the binding deactivated for a few hours.
After I switched back to HTTP, the binding was able to register again.
AVM has changed something again, which confuses OpenHAB.
I’m new here and I’m trying to connect OH3 stabel 3.0.1 to my Fritzbox 7580 firmware 7.25. I get the following error
HTTP-Response-Code 500 (Internal Server Error), SOAP-Fault: 401 (invalid action).
It doesn’t matter if I use the automatically generated user or a self created one.
the TR064 is switched on in the Fritzbox, tested with http://fritz.box:49000/tr64desc.xml.
The Config Host is eagl whether I use fritz.box or the IP. the error remains.
Can someone help me or tell me where I have a thinking error
Is there a way to fix it? Running Fritzbox 7590 with Fritz!OS 7.28 and OH 3.2.0M3. It is not possible to get a working connection from TR064 to my Box.
€dit: Looks that a restart was sufficient and now the thing is online.
