Tracing what turn on an item
I can see in my event log that a light is coming on. But I’m to find what is turning it on. I don’t think it’s via the app (as in manually switched), nor via the physical switch.
I can see a rule triggering at the time. Is there any way of getting more detail from the events for where it might have come from.
It’s a zwave switch, can another zwave device be triggering this one to come on? How would I find that if it’s the case?
Look in your events.log for a command event to your mystery Item. That will not tell you where it originated, but at least you will know it was something openHAB did, and not a private transaction from another zwave device (which is possible, yes).
Yeah event s not telling me enough. I suspect it’s something with the zwave network. And even looking at the zwave logs I can’t tell if the device is being actioned, or if an error condition is triggering the device to turn on and teh zwave log is just picking up that it’s been turned on.
This is a fibaro dual relay, and it has a number of “what to do when alarm frame received” I mostly have them all turned off (heat, over power etc), but it still seems to be coming on randomly.
At 13:12:09.42 it seemed to magically turn on. I have an alert now for when it does, and I manually turn it back off. This happening about 30 seconds to 1 minute later.
2022-02-28 13:11:16.594 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2022-02-28 13:11:16.594 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2022-02-28 13:11:16.594 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2022-02-28 13:11:16.595 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 2
2022-02-28 13:11:16.595 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-02-28 13:11:16.595 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-02-28 13:11:16.595 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 3: Meter: Type=Electric(1), Scale=W(2), Value=0E+1
2022-02-28 13:11:16.595 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-02-28 13:11:16.595 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=2, command class=COMMAND_CLASS_METER, value=0E+1
2022-02-28 13:11:16.595 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:a5365e91:node3:meter_watts2 to 0 [DecimalType]
2022-02-28 13:11:16.595 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-02-28 13:11:16.596 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2377c3d7.
2022-02-28 13:11:22.596 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2022-02-28 13:11:22.596 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2022-02-28 13:11:22.596 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2022-02-28 13:11:22.596 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 1
2022-02-28 13:11:22.596 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-02-28 13:11:22.596 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-02-28 13:11:22.596 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 3: Meter: Type=Electric(1), Scale=kWh(0), Value=138.6
2022-02-28 13:11:22.597 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-02-28 13:11:22.597 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_METER, value=138.6
2022-02-28 13:11:22.597 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:a5365e91:node3:meter_kwh1 to 138.6 [DecimalType]
2022-02-28 13:11:22.597 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-02-28 13:11:22.597 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@131ffc30.
2022-02-28 13:11:22.670 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2022-02-28 13:11:22.670 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2022-02-28 13:11:22.670 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2022-02-28 13:11:22.670 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 2
2022-02-28 13:11:22.670 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-02-28 13:11:22.670 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-02-28 13:11:22.671 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 3: Meter: Type=Electric(1), Scale=kWh(0), Value=0.77
2022-02-28 13:11:22.671 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-02-28 13:11:22.671 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=2, command class=COMMAND_CLASS_METER, value=0.77
2022-02-28 13:11:22.671 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:a5365e91:node3:meter_kwh2 to 0.77 [DecimalType]
2022-02-28 13:11:22.671 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-02-28 13:11:22.671 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3498d58c.
2022-02-28 13:12:09.423 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2022-02-28 13:12:09.423 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2022-02-28 13:12:09.423 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2022-02-28 13:12:09.423 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 1
2022-02-28 13:12:09.423 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_SWITCH_BINARY
2022-02-28 13:12:09.423 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
2022-02-28 13:12:09.423 [DEBUG] [rotocol.commandclass.ZWaveBinarySwitchCommandClass] - NODE 3: Switch Binary report, value = 255
2022-02-28 13:12:09.423 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2022-02-28 13:12:09.423 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_SWITCH_BINARY, value=255
2022-02-28 13:12:09.424 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:a5365e91:node3:switch_binary1 to ON [OnOffType]
2022-02-28 13:12:09.424 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-02-28 13:12:09.424 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@248dcae8.
2022-02-28 13:12:11.568 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2022-02-28 13:12:11.568 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2022-02-28 13:12:11.568 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2022-02-28 13:12:11.568 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 1
2022-02-28 13:12:11.569 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-02-28 13:12:11.569 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-02-28 13:12:11.569 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 3: Meter: Type=Electric(1), Scale=W(2), Value=15
2022-02-28 13:12:11.569 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-02-28 13:12:11.569 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_METER, value=15
2022-02-28 13:12:11.569 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:a5365e91:node3:meter_watts1 to 15 [DecimalType]
2022-02-28 13:12:11.570 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-02-28 13:12:11.570 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@7f71e13c.
2022-02-28 13:12:41.246 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Command received zwave:device:a5365e91:node3:switch_binary1 --> OFF [OnOffType]
2022-02-28 13:12:41.246 [DEBUG] [rotocol.commandclass.ZWaveBinarySwitchCommandClass] - NODE 3: Creating new message for application command SWITCH_BINARY_SET
2022-02-28 13:12:41.246 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Encapsulating message, instance / endpoint 1
2022-02-28 13:12:41.246 [DEBUG] [otocol.commandclass.ZWaveMultiInstanceCommandClass] - NODE 3: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2022-02-28 13:12:41.246 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2022-02-28 13:12:41.246 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2022-02-28 13:12:41.246 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Adding to device queue
2022-02-28 13:12:41.247 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Added 12648 to queue - size 1
2022-02-28 13:12:41.247 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 3: Sending REQUEST Message = 01 0E 00 13 03 07 60 0D 01 01 25 01 00 25 41 CB
2022-02-28 13:12:41.249 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling initialised at 86400 seconds - start in 1500 milliseconds.
2022-02-28 13:12:41.257 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 3: sentData successfully placed on stack.
2022-02-28 13:12:41.257 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: TID 12648: Transaction not completed
2022-02-28 13:12:41.274 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 3: SendData Request. CallBack ID = 65, Status = Transmission complete and ACK received(0)
2022-02-28 13:12:41.274 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2022-02-28 13:12:41.274 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Response processed after 26ms
2022-02-28 13:12:41.274 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: TID 12648: Transaction completed
2022-02-28 13:12:41.274 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: notifyTransactionResponse TID:12648 DONE
2022-02-28 13:12:41.277 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2022-02-28 13:12:41.363 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2022-02-28 13:12:41.363 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2022-02-28 13:12:41.363 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2022-02-28 13:12:41.363 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 1
2022-02-28 13:12:41.363 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_SWITCH_BINARY
2022-02-28 13:12:41.363 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
2022-02-28 13:12:41.363 [DEBUG] [rotocol.commandclass.ZWaveBinarySwitchCommandClass] - NODE 3: Switch Binary report, value = 0
2022-02-28 13:12:41.363 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2022-02-28 13:12:41.364 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_SWITCH_BINARY, value=0
2022-02-28 13:12:41.364 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:a5365e91:node3:switch_binary1 to OFF [OnOffType]
2022-02-28 13:12:41.364 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-02-28 13:12:41.364 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6eed3a0d.
2022-02-28 13:12:41.564 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2022-02-28 13:12:41.564 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2022-02-28 13:12:41.565 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2022-02-28 13:12:41.565 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 1
2022-02-28 13:12:41.565 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-02-28 13:12:41.565 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-02-28 13:12:41.565 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 3: Meter: Type=Electric(1), Scale=W(2), Value=0E+1
2022-02-28 13:12:41.565 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-02-28 13:12:41.565 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_METER, value=0E+1
2022-02-28 13:12:41.565 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:a5365e91:node3:meter_watts1 to 0 [DecimalType]
2022-02-28 13:12:41.565 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-02-28 13:12:41.565 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@60c53f6f.
2022-02-28 13:12:42.749 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling...
2022-02-28 13:12:42.750 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:a5365e91:node3:meter_kwh
2022-02-28 13:12:42.750 [DEBUG] [nding.zwave.internal.converter.ZWaveMeterConverter] - NODE 3: Generating poll message for COMMAND_CLASS_METER, endpoint 0
2022-02-28 13:12:42.750 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 3: Creating new message for application command METER_GET
2022-02-28 13:12:42.750 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-02-28 13:12:42.750 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Command Class COMMAND_CLASS_METER is NOT required to be secured
2022-02-28 13:12:42.750 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:a5365e91:node3:meter_watts
2022-02-28 13:12:42.751 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-02-28 13:12:42.751 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Command Class COMMAND_CLASS_METER is NOT required to be secured
2022-02-28 13:12:42.751 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:a5365e91:node3:alarm_heat
2022-02-28 13:12:42.751 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:a5365e91:node3:switch_binary1
2022-02-28 13:12:42.751 [DEBUG] [wave.internal.converter.ZWaveBinarySwitchConverter] - NODE 3: Generating poll message for COMMAND_CLASS_SWITCH_BINARY, endpoint 1
2022-02-28 13:12:42.751 [DEBUG] [rotocol.commandclass.ZWaveBinarySwitchCommandClass] - NODE 3: Creating new message for application command SWITCH_BINARY_GET
2022-02-28 13:12:42.751 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Encapsulating message, instance / endpoint 1
2022-02-28 13:12:42.751 [DEBUG] [otocol.commandclass.ZWaveMultiInstanceCommandClass] - NODE 3: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2022-02-28 13:12:42.751 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2022-02-28 13:12:42.751 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2022-02-28 13:12:42.752 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling skipped for zwave:device:a5365e91:node3:switch_binary1 on COMMAND_CLASS_BASIC
2022-02-28 13:12:42.752 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:a5365e91:node3:meter_kwh1
2022-02-28 13:12:42.752 [DEBUG] [nding.zwave.internal.converter.ZWaveMeterConverter] - NODE 3: Generating poll message for COMMAND_CLASS_METER, endpoint 1
2022-02-28 13:12:42.752 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 3: Creating new message for application command METER_GET
2022-02-28 13:12:42.752 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Encapsulating message, instance / endpoint 1
2022-02-28 13:12:42.752 [DEBUG] [otocol.commandclass.ZWaveMultiInstanceCommandClass] - NODE 3: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2022-02-28 13:12:42.752 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2022-02-28 13:12:42.752 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2022-02-28 13:12:42.752 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:a5365e91:node3:meter_watts1
2022-02-28 13:12:42.753 [DEBUG] [nding.zwave.internal.converter.ZWaveMeterConverter] - NODE 3: Generating poll message for COMMAND_CLASS_METER, endpoint 1
2022-02-28 13:12:42.753 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 3: Creating new message for application command METER_GET
2022-02-28 13:12:42.753 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Encapsulating message, instance / endpoint 1
2022-02-28 13:12:42.753 [DEBUG] [otocol.commandclass.ZWaveMultiInstanceCommandClass] - NODE 3: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2022-02-28 13:12:42.753 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2022-02-28 13:12:42.753 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2022-02-28 13:12:42.753 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:a5365e91:node3:switch_binary2
2022-02-28 13:12:42.753 [DEBUG] [wave.internal.converter.ZWaveBinarySwitchConverter] - NODE 3: Generating poll message for COMMAND_CLASS_SWITCH_BINARY, endpoint 2
2022-02-28 13:12:42.753 [DEBUG] [rotocol.commandclass.ZWaveBinarySwitchCommandClass] - NODE 3: Creating new message for application command SWITCH_BINARY_GET
2022-02-28 13:12:42.753 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Encapsulating message, instance / endpoint 2
2022-02-28 13:12:42.753 [DEBUG] [otocol.commandclass.ZWaveMultiInstanceCommandClass] - NODE 3: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 2
2022-02-28 13:12:42.754 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling skipped for zwave:device:a5365e91:node3:switch_binary2 on COMMAND_CLASS_BASIC
2022-02-28 13:12:42.754 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:a5365e91:node3:meter_kwh2
2022-02-28 13:12:42.754 [DEBUG] [nding.zwave.internal.converter.ZWaveMeterConverter] - NODE 3: Generating poll message for COMMAND_CLASS_METER, endpoint 2
2022-02-28 13:12:42.754 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 3: Creating new message for application command METER_GET
2022-02-28 13:12:42.754 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Encapsulating message, instance / endpoint 2
2022-02-28 13:12:42.754 [DEBUG] [otocol.commandclass.ZWaveMultiInstanceCommandClass] - NODE 3: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 2
2022-02-28 13:12:42.754 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2022-02-28 13:12:42.754 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2022-02-28 13:12:42.754 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:a5365e91:node3:meter_watts2
2022-02-28 13:12:42.755 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Encapsulating message, instance / endpoint 2
2022-02-28 13:12:42.755 [DEBUG] [otocol.commandclass.ZWaveMultiInstanceCommandClass] - NODE 3: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 2
2022-02-28 13:12:42.755 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2022-02-28 13:12:42.755 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2022-02-28 13:12:42.755 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Adding to device queue
2022-02-28 13:12:42.755 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Added 12649 to queue - size 1
2022-02-28 13:12:42.755 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 3: Sending REQUEST Message = 01 0A 00 13 03 03 32 01 00 25 42 B2
2022-02-28 13:12:42.756 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Adding to device queue
2022-02-28 13:12:42.756 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Added 12650 to queue - size 1
2022-02-28 13:12:42.756 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Added 12651 to queue - size 2
2022-02-28 13:12:42.756 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Added 12652 to queue - size 3
2022-02-28 13:12:42.757 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Adding to device queue
2022-02-28 13:12:42.757 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Added 12653 to queue - size 4
2022-02-28 13:12:42.757 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Added 12654 to queue - size 5
2022-02-28 13:12:42.758 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Added 12655 to queue - size 6
2022-02-28 13:12:42.758 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Adding to device queue
2022-02-28 13:12:42.758 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Added 12656 to queue - size 7
2022-02-28 13:12:42.765 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 3: sentData successfully placed on stack.
2022-02-28 13:12:42.765 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: TID 12649: Transaction not completed
2022-02-28 13:12:42.781 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 3: SendData Request. CallBack ID = 66, Status = Transmission complete and ACK received(0)
2022-02-28 13:12:42.781 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2022-02-28 13:12:42.781 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: TID 12649: Transaction not completed
2022-02-28 13:12:42.793 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2022-02-28 13:12:42.793 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2022-02-28 13:12:42.793 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-02-28 13:12:42.793 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-02-28 13:12:42.793 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-02-28 13:12:42.793 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 3: Meter: Type=Electric(1), Scale=kWh(0), Value=138.6
2022-02-28 13:12:42.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-02-28 13:12:42.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=138.6
2022-02-28 13:12:42.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:a5365e91:node3:meter_kwh to 138.6 [DecimalType]
2022-02-28 13:12:42.794 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-02-28 13:12:42.794 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@585faee4.
2022-02-28 13:12:42.794 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@585faee4.
2022-02-28 13:12:42.794 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: notifyTransactionResponse TID:12649 DONE
2022-02-28 13:12:42.794 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2022-02-28 13:12:42.796 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 3: Sending REQUEST Message = 01 0A 00 13 03 03 32 01 10 25 43 A3
2022-02-28 13:12:42.805 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 3: sentData successfully placed on stack.
2022-02-28 13:12:42.805 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: TID 12650: Transaction not completed
2022-02-28 13:12:42.821 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 3: SendData Request. CallBack ID = 67, Status = Transmission complete and ACK received(0)
2022-02-28 13:12:42.822 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2022-02-28 13:12:42.822 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: TID 12650: Transaction not completed
2022-02-28 13:12:42.833 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2022-02-28 13:12:42.833 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2022-02-28 13:12:42.833 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-02-28 13:12:42.833 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-02-28 13:12:42.833 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-02-28 13:12:42.833 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 3: Meter: Type=Electric(1), Scale=W(2), Value=0E+1
2022-02-28 13:12:42.833 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-02-28 13:12:42.833 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=0E+1
BTW excluding everything but entries for NODE 3 in this log. So if the raw log useful, I can post that as well
This is rules DSL but I do something like this
logInfo("Bath Light rule", "Bathroom light rule triggered by: " + triggeringItemName)
How do you get the triggering item name? That might work. At least might eliminate some options.
So
   Item zwave_welcome_lights received update
    //how to get triggeringitemName
Okay, you have not shared what it did tell you, but guessing your Item gets no command event? I don’t think there is much more to see or do within openHAB if that is not present.
Just this:
2022-03-01 09:22:15.139 [GroupItemStateChangedEvent] - g_outside_lighting_alarm changed from OFF to ON through zwave_switch_welcome
2022-03-01 09:22:15.140 [GroupItemStateChangedEvent] - g_outside_lighting changed from OFF to ON through zwave_switch_welcome
2022-03-01 09:22:15.140 [vent.ItemStateChangedEvent] - zwave_switch_welcome changed from OFF to ON
Two switch groups the items is in are turned on because the item it, and the item is turned on. But there’s no source - this is what I mean by it doens’t tell me enough. Was it triggered via the UI by someone (it wont be at this time), or via a rule or via the relay internally doing something weird. I suspect the latter. But can’t prove it.
Heres the zwave json, maybe there’s something turned on here?
"zwave:device:a5365e91:node3": {
    "class": "org.eclipse.smarthome.core.thing.internal.ThingImpl",
    "value": {
      "label": "zwave_node03_welcome_lights",
      "bridgeUID": {
        "segments": [
          "zwave",
          "serial_zstick",
          "a5365e91"
      "channels": [
          "acceptedItemType": "Number",
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "a5365e91",
              "node3",
              "meter_kwh"
          "channelTypeUID": {
            "segments": [
              "zwave",
              "meter_kwh"
          "label": "Electric meter (kWh)",
          "description": "Indicates the energy consumption (kWh)",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:DecimalType": "COMMAND_CLASS_METER;type\u003dE_KWh"
          "defaultTags": []
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "a5365e91",
              "node3",
              "meter_watts"
          "channelTypeUID": {
            "segments": [
              "zwave",
              "meter_watts"
          "label": "Electric meter (watts)",
          "description": "Indicates the instantaneous power consumption",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:DecimalType": "COMMAND_CLASS_METER;type\u003dE_W"
          "defaultTags": []
          "acceptedItemType": "Switch",
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "a5365e91",
              "node3",
              "meter_reset"
          "channelTypeUID": {
            "segments": [
              "zwave",
              "meter_reset"
          "label": "Meter Reset",
          "description": "Reset the meter",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:OnOffType": "COMMAND_CLASS_METER;reset\u003dtrue"
          "defaultTags": []
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "a5365e91",
              "node3",
              "scene_number"
          "channelTypeUID": {
          "segments": [
              "zwave",
              "scene_number"
          "label": "Scene Number",
          "description": "Triggers when a scene button is pressed",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:DecimalType": "COMMAND_CLASS_CENTRAL_SCENE"
          "defaultTags": []
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "a5365e91",
              "node3",
              "alarm_heat"
          "channelTypeUID": {
            "segments": [
              "zwave",
              "alarm_heat"
          "label": "Alarm (heat)",
          "description": "Indicates if a heat alarm is triggered",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:OnOffType": "COMMAND_CLASS_ALARM;TYPE\u003dHEAT"
          "defaultTags": []
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "a5365e91",
              "node3",
              "notification_send"
          "channelTypeUID": {
           "segments": [
              "zwave",
              "notification_send"
          "label": "Send notification",
          "description": "Sends a notification",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:DecimalType": "COMMAND_CLASS_ALARM;event1\u003dSMOKE:1,event2\u003dACCESS_CONTROL:22,event3\u003dBURGLAR:1,event4\u003dEMERGENCY:1,event5\u003dEMERGENCY:2,event6\u003dEMERGENCY:3"
          "defaultTags": []
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "a5365e91",
              "node3",
              "alarm_power"
          "channelTypeUID": {
            "segments": [
              "zwave",
              "alarm_power"
          "label": "Alarm (power) [Deprecated]",
          "description": "Indicates if a power alarm is triggered",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:OnOffType": "COMMAND_CLASS_ALARM;type\u003dPOWER_MANAGEMENT"
          "defaultTags": []
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "a5365e91",
              "node3",
              "switch_binary1"
          "channelTypeUID": {
            "segments": [
              "zwave",
              "switch_binary"
          "label": "Switch 1",
          "description": "Switch the power on and off",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:OnOffType": "COMMAND_CLASS_SWITCH_BINARY:1,COMMAND_CLASS_BASIC:1"
          "defaultTags": []
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "a5365e91",
              "node3",
              "meter_kwh1"
          "channelTypeUID": {
            "segments": [
              "zwave",
              "meter_kwh"
          "label": "Electric meter (kWh) 1",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:DecimalType": "COMMAND_CLASS_METER:1;type\u003dE_KWh"
          "defaultTags": []
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "a5365e91",
              "node3",
              "meter_watts1"
        "channelTypeUID": {
            "segments": [
              "zwave",
              "meter_watts"
          "label": "Electric meter (watts) 1",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:DecimalType": "COMMAND_CLASS_METER:1;type\u003dE_W"
          "defaultTags": []
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "a5365e91",
              "node3",
              "switch_binary2"
          "channelTypeUID": {
            "segments": [
              "zwave",
              "switch_binary"
          "label": "Switch 2",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:OnOffType": "COMMAND_CLASS_SWITCH_BINARY:2,COMMAND_CLASS_BASIC:2"
          "defaultTags": []
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "a5365e91",
              "node3",
              "meter_kwh2"
         "channelTypeUID": {
            "segments": [
              "zwave",
              "meter_kwh"
          "label": "Electric meter (kWh) 2",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:DecimalType": "COMMAND_CLASS_METER:2;type\u003dE_KWh"
          "defaultTags": []
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "a5365e91",
              "node3",
              "meter_watts2"
          "channelTypeUID": {
            "segments": [
              "zwave",
              "meter_watts"
          "label": "Electric meter (watts) 2",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:DecimalType": "COMMAND_CLASS_METER:2;type\u003dE_W"
          "defaultTags": []
      "configuration": {
        "properties": {
          "config_30_1": 0,
          "config_31_2": 0,
          "config_55_1": 10,
          "binding_cmdrepollperiod": 1500,
          "config_54_1": 20,
          "config_32_2": 0,
          "config_53_2": 50,
          "config_11_1": 0,
          "config_10_1": 0,
         "config_51_1": 10,
          "config_50_1": 20,
          "group_5": "",
          "group_4": "",
          "group_1": "controller",
          "group_3": "",
          "group_2": "",
          "action_reinit": false,
          "config_16_1": 0,
          "config_37_2": 0,
          "config_38_2": 99,
          "config_59_2": 300,
          "config_12_2": 50,
          "config_17_2": 50,
          "config_18_2": 5,
          "config_33_2": 0,
          "config_35_1": 0,
          "config_58_2": 180,
          "config_13_2": 5,
          "config_15_1": 0,
          "config_36_2": 0,
          "config_57_2": 100,
          "config_42_1": 0,
          "config_20_1": 2,
          "config_41_1": 2,
          "config_21_1": 0,
          "config_43_1": 2,
          "config_40_1": 0,
          "config_60_1": 0,
          "action_failed": false,
          "action_remove": false,
          "binding_pollperiod": 86400,
          "action_heal": false,
          "config_27_1": 15,
          "config_28_1": 0,
          "config_9_1": 0,
          "config_29_1": 0,
          "config_44_2": 6,
          "node_id": 3
      "properties": {
        "zwave_class_basic": "BASIC_TYPE_ROUTING_SLAVE",
        "zwave_class_generic": "GENERIC_TYPE_SWITCH_BINARY",
        "zwave_frequent": "false",
        "zwave_neighbours": "1,5,10",
        "modelId": "FGS223",
        "zwave_version": "3.2",
        "zwave_listening": "true",
        "zwave_plus_devicetype": "NODE_TYPE_ZWAVEPLUS_NODE",
        "manufacturerId": "010F",
        "manufacturerRef": "0203:1000,0203:2000,0203:3000,0203:4000,0203:6000",
        "dbReference": "416",
        "zwave_deviceid": "12288",
        "zwave_nodeid": "3",
        "zwave_lastheal": "2022-02-28T02:13:02Z",
        "vendor": "Fibargroup",
        "defaultAssociations": "1",
        "zwave_routing": "true",
        "zwave_plus_roletype": "ROLE_TYPE_SLAVE_ALWAYS_ON",
        "zwave_beaming": "true",
        "zwave_secure": "false",
        "zwave_class_specific": "SPECIFIC_TYPE_POWER_SWITCH_BINARY",
        "zwave_manufacturer": "271",
        "zwave_devicetype": "515"
      "uid": {
        "segments": [
          "zwave",
          "device",
          "a5365e91",
          "node3"
      "thingTypeUID": {
        "segments": [
          "zwave",
          "fibaro_fgs223_00_000"
      "location": "Zwave"
No, or else you would see a command to your Item in your events.log
(The state change events that you do see are the result of incoming status reports.)
So it looks like external causes - another zwave device perhaps.
yeah I suspect zwave as well, but have no idea how to track it down.
I don’t think openHAB can help you. The ‘direct’ messaging will not be monitored by the binding.
You might guess at the culprit, and carefully examine your device settings. What other devices were likely to be active at that moment in time?
Or to really trace it you’d want to use a zniffer set up perhaps.
Yeah couple of weeks ago I had this one flashing…I wonder if it’s reached the end of it’s life.
I think I have a a shelly 2.5 here, I think I’ll replace it with that. I’m slowing decommissioning my zwave network in favour of shelly.
The weird this is this is a fibaro dual relay. The 2nd channel on this relay doesn’t have this problem. Just channel 1
I may have found it. I went through all items that had the problematic node as a neighbour And did find the odd setting of send hail CC or send basic cc report which I’ve now turned off.
Today is the first day I haven’t had it turn on randomly. No idea what setting in teh problematic node was accepting said commands/reports and deciding to turn on the S1 channel.
