MAke sure you remove it from paper ui. Remove all tradfri config files.
Then clear cache
Then try again. I had an issue at one point and realized in my frustration i had duplicated something. I had to restart. I manually removed from the json dB cause the paper ui did not appear to actually be removing it.
I’m sorry to say that snapshot #1655, which I think for most purposes is equal to the new M2 release, still often requires a bundle restart of the Trådfri binding in order to get Gateway and things online.
OH is running on this HW.
OS is Ubuntu Server 16.04.6 LTS (x86_64), java 1.8.0.201-b09
My network is all wired, Ikea Gateway connected (with non-original 0.5m patch cable) to a Giga-Eth port in the back of my Asus RT-AC87U router (in the cellar).
This router is connected through a 20-30m patch cable to an Asus RT-AC66U running in AP mode. The VivoPC is connected straight to this AP with a 0.5m patch cable. This is the optimal place for my Z-Wave & Zigbee USB sticks. Also separates the Ikea GW and the Conbee for minimal interference.
Whenever the Ikea GW does not connect in OH, ICMP ping works fine.
Sometimes after a VivoPC/OH restart, the Ikea Gateway does connect, but most often not.
Usually when it doesn’t, one restart of the bundle in Karaf is enough, but sometimes I need to do it 5-6 times.
I am in process of switching to deconz, not because I have issues with tradfri beyond one light that intermittently connects. I want to enhance the features of remotes, both my Phillips and ikea remotes.
My gateway has 1.8.26
I have upgraded from 2.4.0. to 2.5.0.M2.
In 2.4.0 I had a couple of addon files in order get it working:
I left this configuration after during and after the upgrade.
The result was that for each OH restart I needed to go to paper-UI and re-enter the security code.
I removed now the addon files and enabled the 2.5.0.M2 TF binding.
Having now exactly the same behavior. Even worse.
Sometimes when entering the security key, the GW goes online and then immediately offline.
I will step back to addon files from 2.4.0.
I asked lots of questions to Ikea support, one of them was this:
OpenHAB needs to re-initialize the binding with the security code every day to stay connected
Answer from Ikea:
This could be mDNS issue which we are working on. Stability fixes are coming in the next Gateway update that is released next week. Additional fixes will come later this fall.
I’ve had this issue for months (april?), but no time to do any troubleshooting. Is it possible to only update the binding to solve this? I’d like to run 2.4 until 2.5 is released…
For me the gateway only came online when I disconnected the gateway from the Ikea Home Smart App.
Took me a long time to figure this out, hadn’t read it on any forum yet.
Every couple hours my gateway goes offline and can not even connect anymore with the ikea app.
All I need to do is power cycle the gateway, restart the binding and then it works for a couple hours.
