Hi All
I’m running a nightly from around 23. March. I also had an older March version with the same issue.
As soon as the openHAB server with the Tradfri binding is on the same network as the Tradfri Gateway (which it has configured), the Gateway starts after some hours/days to get into a reboot loop.
As soon as I unplug the openHAB server, the Gateway remains stable for days. I’ve done this now for the time being.
I also know that Ikea released an update for the gateway around beginning of March, so that might be the reason.
Am I the only one with this problem?
Patrick
All fine here.
Have you changed the lan cable to your gateway?
Known problem…
No, haven’t changed that cable yet. Interestingly it works with Alexa most of the time, while Openhab kills the gateway within a day.
If anybody has other ideas, I’m open for them. Will also try a different network cable.
Strange.
If you have the LAN cable issue, the Ikea phone App stops working as well.
Ikea sometimes kills the LAN cable because they tighten the cable tie too much and/or bend it too sharply.
No, the Ikea App always works, even when the Alexa skill stops working. I think the software update for the gateway 1.3.14 started the issues, or the nightlies. Both was around the same time.
I am seeing something similar. Running OH 2.3 stable and latest ikea firmware (1.3.14). Everything has worked without any issues for the past 4-5 months when I setup the system. But the other day OH went into communication error mode on the gateway thing.
I am not sure when the ikea firmware was applied, or if this is done automatically?
My first observation was that the tradfri gateway was unavailable event for the app, and when it came to live again it had lost all knowledge og light groups and scenes in the app, so I had to reset and re-add everything. In this process I updated OH from 2.2 to 2.3, just to see if that had any effect, but none that I could see.
Now the app works, but OH only works for a few minutes after I re-configure the security code. One the communication error happens it all stops and never re-establish the connection again.
Any ideas what may be causing this ?
One thing I noticed was that one of my GU10 spectrum was registered as a 820 device and not 220. Had to reset and re-add it to get it registered as a 220 light.
Hi
In my case, as I use OH only for testing, I simply removed the ikea binding some weeks ago. So far it’s absolutely stable again.
I have been running for months without any issue. I have to check what firmware I have when I get home.
The one issue with the gateway I did have was due to the router. It kept changing the ip on me. This sounds like you may have some duplicate ip addresses.
What I did was put the gateway host name in my things file.
My dhcp server assign a static IP to the tradfri gateway. So it should not be an IP issue.
Any idea on how to troubleshoot this issue?
@sonni Are you still having the issue only when gateway and openhab connected?
Here is what I would do. Best option reinstall openhab and setup the server to a point it is just running and let it sit on your network. DO NOT INSTALL TRADFRI BINDING . In fact make sure the gateway is not referenced in your *.things file if you have one. Let openhab sit on your network for several days and make sure that you have not issues.
Second Best option Delete Tradfri binding and remove gateway from your *.things file. Reboot openhab server and let sit on your network for several days.
Also, in the process check the ip address of the openhab server using the command “ifconfig” look for the active adapter on your network. You can find by looking for your network ip prefix 192.168.xxx.
Ping the gateway using the hostname “ping gwhostname” this will tell you the ip address of the gateway. Make sure it is what you have set in your router.
Once you have done this work, lets see where you stand and go from there.
@Thedannymullen thanks for your input.
Stange thing are that my setup has been running just fine since december 2017. So you know when or hos i can see when/if the trådfri gateway updated its firmware doing the last week or so.
The ikea lights are some of my primary light in my house, so I simply disabling them is not the best option.
The ikea app however seams to work fairly well, with the exception that it sometimes appear to be reconnection to the gateway.
If there are something which openhab does in its communication, what might this bee?
I could try to setup iptables (running openhabian) only to allow the tradfri gw port traffic.
Is there a way to configure additional debug logging on the tradfri binding. Perhaps it would give me some hints?
Given that my ikea gateway also appeared unstable with the ikea app on android, I went to ikea and got a replacement.
This new gateway came with firmware 1.2.42 which it upgraded to 1.3.14. It was discovered by openhab and I added it as a thing. At this point I did not pair it with any devices. Just wanted to see if it stayed online in openhab, sadly it did not after some time it went offline with communication error. Tried that a couple of times and event added a few devices to see if that made any difference, but none.
I then blocked internet access for the gateway and did a factory reset. I came up with the original 1.2.42 firmware. I can the same test, with the same result - after some time the connection is lost and not re-established.
In this process I removed the trådfri binding from openhab and rebooted openhabian in the pi. Installed the trådfri binding again.
I enabled debug logging and captured the log … see next…
The TradfriOnlineStatus item is just a switch item, which is updated by a rule when the gateway thing is updated.
At 20:02 I update the gateway thing with the security code and at 20:12 gateway communication fails.
Can anyone see what is happening from this log?
I find it strange that there are no more debug logs when the gateway thing goes offline. Am I missing something here ?
openhab.log
2018-06-18 20:02:19.245 [DEBUG] [e.californium.scandium.DTLSConnector] - Re-transmitting flight for [/172.21.2.25:5684], [3] retransmissions left
2018-06-18 20:02:19.260 [DEBUG] [e.californium.scandium.DTLSConnector] - Received Handshake (22) record from peer [/172.21.2.25:5684]
2018-06-18 20:02:19.263 [DEBUG] [e.californium.scandium.DTLSConnector] - Received Handshake (22) record from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.222 [INFO ] [e.californium.scandium.DTLSConnector] - Stopping DTLS connector on [0.0.0.0/0.0.0.0:48216]
2018-06-18 20:02:20.226 [INFO ] [e.californium.scandium.DTLSConnector] - Worker thread [DTLS-Sender-0.0.0.0/0.0.0.0:48216] has terminated
2018-06-18 20:02:20.226 [INFO ] [e.californium.scandium.DTLSConnector] - Worker thread [DTLS-Receiver-0.0.0.0/0.0.0.0:48216] has terminated
2018-06-18 20:02:20.276 [INFO ] [pse.californium.core.network.Matcher] - Matcher uses USE_RANDOM_MID_START=true and TOKEN_SIZE_LIMIT=8
2018-06-18 20:02:20.294 [INFO ] [alifornium.core.network.CoapEndpoint] - Endpoint org.eclipse.californium.core.network.CoapEndpoint@13922c3 requires an executor to start. Using default single-threaded daemon executor.
2018-06-18 20:02:20.312 [INFO ] [e.californium.scandium.DTLSConnector] - Cannot determine MTU of network interface, using minimum MTU [1280] of IPv6 instead
2018-06-18 20:02:20.321 [INFO ] [e.californium.scandium.DTLSConnector] - Starting worker thread [DTLS-Receiver-0.0.0.0/0.0.0.0:59182]
2018-06-18 20:02:20.325 [INFO ] [e.californium.scandium.DTLSConnector] - DTLS connector listening on [0.0.0.0/0.0.0.0:59182] with MTU [1,280] using (inbound) datagram buffer size [16,474 bytes]
2018-06-18 20:02:20.344 [INFO ] [e.californium.scandium.DTLSConnector] - Starting worker thread [DTLS-Sender-0.0.0.0/0.0.0.0:59182]
2018-06-18 20:02:20.348 [INFO ] [.eclipse.californium.core.CoapClient] - Started set client endpoint 0.0.0.0/0.0.0.0:59182
2018-06-18 20:02:20.351 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[25877 for null:0], KeyToken[3b1fc8fd8aa6fc1b]
2018-06-18 20:02:20.356 [DEBUG] [californium.scandium.dtls.Connection] - Handshake with [/172.21.2.25:5684] has been started
2018-06-18 20:02:20.359 [DEBUG] [e.californium.scandium.DTLSConnector] - Received Handshake (22) record from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.373 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processing Handshake (22) message from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.377 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processed HELLO_VERIFY_REQUEST (3) message with sequence no [0] from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.388 [DEBUG] [e.californium.scandium.DTLSConnector] - Received Handshake (22) record from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.391 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processing Handshake (22) message from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.394 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processed SERVER_HELLO (2) message with sequence no [1] from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.402 [DEBUG] [e.californium.scandium.DTLSConnector] - Received Handshake (22) record from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.407 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processing Handshake (22) message from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.427 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processed SERVER_HELLO_DONE (14) message with sequence no [2] from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.451 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processing Change Cipher Spec (20) message from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.454 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processed Change Cipher Spec (20) message from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.457 [DEBUG] [e.californium.scandium.DTLSConnector] - Received Handshake (22) record from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.461 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processing Handshake (22) message from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.475 [DEBUG] [californium.scandium.dtls.Connection] - Session with [/172.21.2.25:5684] has been established
2018-06-18 20:02:20.478 [DEBUG] [californium.scandium.dtls.Connection] - Handshake with [/172.21.2.25:5684] has been completed
2018-06-18 20:02:20.503 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processed FINISHED (20) message with sequence no [3] from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.557 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[25877 for null:0]
2018-06-18 20:02:20.562 [INFO ] [e.californium.scandium.DTLSConnector] - Stopping DTLS connector on [0.0.0.0/0.0.0.0:59182]
2018-06-18 20:02:20.578 [INFO ] [e.californium.scandium.DTLSConnector] - Worker thread [DTLS-Receiver-0.0.0.0/0.0.0.0:59182] has terminated
2018-06-18 20:02:20.584 [INFO ] [e.californium.scandium.DTLSConnector] - Worker thread [DTLS-Sender-0.0.0.0/0.0.0.0:59182] has terminated
2018-06-18 20:02:20.692 [INFO ] [pse.californium.core.network.Matcher] - Matcher uses USE_RANDOM_MID_START=true and TOKEN_SIZE_LIMIT=8
2018-06-18 20:02:20.715 [INFO ] [e.californium.scandium.DTLSConnector] - Cannot determine MTU of network interface, using minimum MTU [1280] of IPv6 instead
2018-06-18 20:02:20.718 [INFO ] [e.californium.scandium.DTLSConnector] - DTLS connector listening on [0.0.0.0/0.0.0.0:36542] with MTU [1,280] using (inbound) datagram buffer size [16,474 bytes]
2018-06-18 20:02:20.720 [INFO ] [.eclipse.californium.core.CoapClient] - Started set client endpoint 0.0.0.0/0.0.0.0:36542
2018-06-18 20:02:20.751 [INFO ] [e.californium.scandium.DTLSConnector] - Starting worker thread [DTLS-Receiver-0.0.0.0/0.0.0.0:36542]
2018-06-18 20:02:20.765 [INFO ] [e.californium.scandium.DTLSConnector] - Starting worker thread [DTLS-Sender-0.0.0.0/0.0.0.0:36542]
2018-06-18 20:02:20.812 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62817 for null:0], KeyToken[2f2133122505]
2018-06-18 20:02:20.815 [DEBUG] [californium.scandium.dtls.Connection] - Handshake with [/172.21.2.25:5684] has been started
2018-06-18 20:02:20.815 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62818 for null:0], KeyToken[daf6877c6326]
2018-06-18 20:02:20.818 [DEBUG] [e.californium.scandium.DTLSConnector] - Received Handshake (22) record from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.823 [DEBUG] [californium.scandium.dtls.Connection] - Handshake with [/172.21.2.25:5684] has been started
2018-06-18 20:02:20.833 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processing Handshake (22) message from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.843 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processed HELLO_VERIFY_REQUEST (3) message with sequence no [0] from peer [/172.21.2.25:5684]
2018-06-18 20:02:20.849 [DEBUG] [e.californium.scandium.DTLSConnector] - Received Handshake (22) record from peer [/172.21.2.25:5684]
2018-06-18 20:02:21.849 [DEBUG] [e.californium.scandium.DTLSConnector] - Re-transmitting flight for [/172.21.2.25:5684], [3] retransmissions left
2018-06-18 20:02:22.850 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62818 for null:0], KeyToken[daf6877c6326]
2018-06-18 20:02:22.852 [DEBUG] [californium.scandium.dtls.Connection] - Handshake with [/172.21.2.25:5684] has been started
2018-06-18 20:02:22.856 [DEBUG] [e.californium.scandium.DTLSConnector] - Received Handshake (22) record from peer [/172.21.2.25:5684]
2018-06-18 20:02:22.864 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processing Handshake (22) message from peer [/172.21.2.25:5684]
2018-06-18 20:02:22.866 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processed HELLO_VERIFY_REQUEST (3) message with sequence no [0] from peer [/172.21.2.25:5684]
2018-06-18 20:02:22.871 [DEBUG] [e.californium.scandium.DTLSConnector] - Received Handshake (22) record from peer [/172.21.2.25:5684]
2018-06-18 20:02:22.873 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processing Handshake (22) message from peer [/172.21.2.25:5684]
2018-06-18 20:02:22.875 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processed SERVER_HELLO (2) message with sequence no [1] from peer [/172.21.2.25:5684]
2018-06-18 20:02:22.876 [DEBUG] [e.californium.scandium.DTLSConnector] - Received Handshake (22) record from peer [/172.21.2.25:5684]
2018-06-18 20:02:22.878 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processing Handshake (22) message from peer [/172.21.2.25:5684]
2018-06-18 20:02:22.883 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processed SERVER_HELLO_DONE (14) message with sequence no [2] from peer [/172.21.2.25:5684]
2018-06-18 20:02:22.886 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processing Change Cipher Spec (20) message from peer [/172.21.2.25:5684]
2018-06-18 20:02:22.887 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processed Change Cipher Spec (20) message from peer [/172.21.2.25:5684]
2018-06-18 20:02:22.889 [DEBUG] [e.californium.scandium.DTLSConnector] - Received Handshake (22) record from peer [/172.21.2.25:5684]
2018-06-18 20:02:22.892 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processing Handshake (22) message from peer [/172.21.2.25:5684]
2018-06-18 20:02:22.894 [DEBUG] [californium.scandium.dtls.Connection] - Session with [/172.21.2.25:5684] has been established
2018-06-18 20:02:22.895 [DEBUG] [californium.scandium.dtls.Connection] - Handshake with [/172.21.2.25:5684] has been completed
2018-06-18 20:02:22.898 [DEBUG] [rnium.scandium.dtls.ClientHandshaker] - Processed FINISHED (20) message with sequence no [3] from peer [/172.21.2.25:5684]
2018-06-18 20:02:22.902 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62818 for null:0]
2018-06-18 20:02:22.916 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62819 for null:0], KeyToken[fd21e5a24745]
2018-06-18 20:02:22.920 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62820 for null:0], KeyToken[0de76b4fea]
2018-06-18 20:02:22.925 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62821 for null:0], KeyToken[38e5e4eb21109e]
2018-06-18 20:02:22.931 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62822 for null:0], KeyToken[f6]
2018-06-18 20:02:22.938 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62823 for null:0], KeyToken[72ee01f7]
2018-06-18 20:02:22.946 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62824 for null:0], KeyToken[b0]
2018-06-18 20:02:22.952 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62819 for null:0]
2018-06-18 20:02:22.974 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62820 for null:0]
2018-06-18 20:02:22.987 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62821 for null:0]
2018-06-18 20:02:23.005 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62822 for null:0]
2018-06-18 20:02:23.016 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62823 for null:0]
2018-06-18 20:02:23.027 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62824 for null:0]
2018-06-18 20:02:23.463 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62817 for null:0], KeyToken[2f2133122505]
2018-06-18 20:02:23.512 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62817 for null:0]
2018-06-18 20:02:25.914 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62825 for null:0], KeyToken[1043]
2018-06-18 20:02:25.918 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62826 for null:0], KeyToken[ad5c24dd]
2018-06-18 20:02:25.920 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62825 for null:0]
2018-06-18 20:02:25.929 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62827 for null:0], KeyToken[93cc10f7]
2018-06-18 20:02:25.931 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62826 for null:0]
2018-06-18 20:02:25.955 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62828 for null:0], KeyToken[2198d646a1]
2018-06-18 20:02:25.959 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62827 for null:0]
2018-06-18 20:02:25.994 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62829 for null:0], KeyToken[7a99ee58]
2018-06-18 20:02:26.004 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62830 for null:0], KeyToken[73]
2018-06-18 20:02:26.009 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62828 for null:0]
2018-06-18 20:02:26.026 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62829 for null:0]
2018-06-18 20:02:26.092 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62830 for null:0]
2018-06-18 20:03:20.811 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62831 for null:0], KeyToken[5de576]
2018-06-18 20:03:20.814 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62832 for null:0], KeyToken[15fe1820a8f7]
2018-06-18 20:03:20.862 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62831 for null:0]
2018-06-18 20:03:20.864 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62832 for null:0]
2018-06-18 20:03:20.912 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62833 for null:0], KeyToken[bd8e771914]
2018-06-18 20:03:20.924 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62834 for null:0], KeyToken[66f42f7408277c]
2018-06-18 20:03:20.928 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62835 for null:0], KeyToken[be25903480]
2018-06-18 20:03:20.941 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62836 for null:0], KeyToken[330d81cfa08c2489]
2018-06-18 20:03:20.949 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62837 for null:0], KeyToken[80e8]
2018-06-18 20:03:20.956 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62838 for null:0], KeyToken[1871c1]
2018-06-18 20:03:20.965 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62833 for null:0]
2018-06-18 20:03:20.981 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62834 for null:0]
2018-06-18 20:03:20.988 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62835 for null:0]
2018-06-18 20:03:21.008 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62836 for null:0]
2018-06-18 20:03:21.019 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62837 for null:0]
2018-06-18 20:03:21.028 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62838 for null:0]
2018-06-18 20:03:23.880 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62839 for null:0], KeyToken[eefd5092f88e97]
2018-06-18 20:03:23.883 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62840 for null:0], KeyToken[2be9]
2018-06-18 20:03:23.885 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62841 for null:0], KeyToken[feee5c]
2018-06-18 20:03:23.887 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62842 for null:0], KeyToken[7b01]
2018-06-18 20:03:23.890 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62839 for null:0]
2018-06-18 20:03:23.901 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62840 for null:0]
2018-06-18 20:03:23.908 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62841 for null:0]
2018-06-18 20:03:23.925 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62842 for null:0]
2018-06-18 20:03:23.935 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62843 for null:0], KeyToken[94ddd9f3aaad]
2018-06-18 20:03:23.938 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62844 for null:0], KeyToken[e88f]
2018-06-18 20:03:23.945 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62843 for null:0]
2018-06-18 20:03:23.959 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62844 for null:0]
2018-06-18 20:04:20.812 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62845 for null:0], KeyToken[1bd1cc]
2018-06-18 20:04:20.815 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62846 for null:0], KeyToken[b537a6]
2018-06-18 20:04:20.864 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62845 for null:0]
2018-06-18 20:04:20.867 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62846 for null:0]
2018-06-18 20:04:20.873 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62847 for null:0], KeyToken[55cf7131526e]
2018-06-18 20:04:20.876 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62848 for null:0], KeyToken[bfdf10bade7287]
2018-06-18 20:04:20.891 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62849 for null:0], KeyToken[5b661f39e36cb812]
2018-06-18 20:04:20.899 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62850 for null:0], KeyToken[ef99]
2018-06-18 20:04:20.907 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62851 for null:0], KeyToken[535615ca47]
2018-06-18 20:04:20.913 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62852 for null:0], KeyToken[8c1fa787]
2018-06-18 20:04:20.919 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62847 for null:0]
2018-06-18 20:04:20.938 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62848 for null:0]
2018-06-18 20:04:20.954 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62849 for null:0]
2018-06-18 20:04:20.986 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62850 for null:0]
2018-06-18 20:04:21.061 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62851 for null:0]
2018-06-18 20:04:21.076 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62852 for null:0]
2018-06-18 20:05:20.814 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62853 for null:0], KeyToken[cb42f8]
2018-06-18 20:05:20.817 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62854 for null:0], KeyToken[59c371b471]
2018-06-18 20:05:20.864 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62853 for null:0]
2018-06-18 20:05:20.866 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62854 for null:0]
2018-06-18 20:05:20.870 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62855 for null:0], KeyToken[d6]
2018-06-18 20:05:20.875 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62856 for null:0], KeyToken[37d21a3482]
2018-06-18 20:05:20.878 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62857 for null:0], KeyToken[08b49b96c615]
2018-06-18 20:05:20.884 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62858 for null:0], KeyToken[c64301948a02]
2018-06-18 20:05:20.888 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62859 for null:0], KeyToken[5f06b960773821c3]
2018-06-18 20:05:20.890 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62860 for null:0], KeyToken[dc2c44981c38]
2018-06-18 20:05:20.895 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62855 for null:0]
2018-06-18 20:05:20.901 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62856 for null:0]
2018-06-18 20:05:20.907 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62857 for null:0]
2018-06-18 20:05:20.913 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62858 for null:0]
2018-06-18 20:05:20.919 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62859 for null:0]
2018-06-18 20:05:20.925 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62860 for null:0]
2018-06-18 20:06:20.816 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62861 for null:0], KeyToken[1ca1121d7d87e94f]
2018-06-18 20:06:20.818 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62862 for null:0], KeyToken[7b90902172b8]
2018-06-18 20:06:20.868 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62861 for null:0]
2018-06-18 20:06:20.871 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62862 for null:0]
2018-06-18 20:06:20.877 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62863 for null:0], KeyToken[7adc536c5d4b]
2018-06-18 20:06:20.891 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62864 for null:0], KeyToken[42ea]
2018-06-18 20:06:20.895 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62865 for null:0], KeyToken[efa13ca6]
2018-06-18 20:06:20.898 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62866 for null:0], KeyToken[d83e3d26e9ea]
2018-06-18 20:06:20.902 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62867 for null:0], KeyToken[c69c3cab38a6cb34]
2018-06-18 20:06:20.907 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62868 for null:0], KeyToken[85f6a4680b2a57c3]
2018-06-18 20:06:20.909 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62863 for null:0]
2018-06-18 20:06:20.930 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62864 for null:0]
2018-06-18 20:06:20.941 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62865 for null:0]
2018-06-18 20:06:20.951 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62866 for null:0]
2018-06-18 20:06:20.967 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62867 for null:0]
2018-06-18 20:06:20.978 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62868 for null:0]
2018-06-18 20:07:20.817 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62869 for null:0], KeyToken[b2]
2018-06-18 20:07:20.820 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62870 for null:0], KeyToken[88ad172f]
2018-06-18 20:07:20.867 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62869 for null:0]
2018-06-18 20:07:20.870 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62870 for null:0]
2018-06-18 20:07:20.876 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62871 for null:0], KeyToken[30523383e953f7]
2018-06-18 20:07:20.879 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62872 for null:0], KeyToken[a84aa92ccf0a300d]
2018-06-18 20:07:20.881 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62873 for null:0], KeyToken[34]
2018-06-18 20:07:20.884 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62874 for null:0], KeyToken[aba9d32c1b16]
2018-06-18 20:07:20.896 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62875 for null:0], KeyToken[8721]
2018-06-18 20:07:20.902 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62876 for null:0], KeyToken[f7732d5cd2]
2018-06-18 20:07:20.908 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62871 for null:0]
2018-06-18 20:07:20.918 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62872 for null:0]
2018-06-18 20:07:20.931 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62873 for null:0]
2018-06-18 20:07:20.938 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62874 for null:0]
2018-06-18 20:07:20.945 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62875 for null:0]
2018-06-18 20:07:20.953 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62876 for null:0]
2018-06-18 20:08:20.819 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62877 for null:0], KeyToken[35e4c812fa3efca2]
2018-06-18 20:08:20.822 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62878 for null:0], KeyToken[ed81]
2018-06-18 20:08:20.871 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62877 for null:0]
2018-06-18 20:08:20.874 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62878 for null:0]
2018-06-18 20:08:20.890 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62879 for null:0], KeyToken[b0f00d]
2018-06-18 20:08:20.893 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62880 for null:0], KeyToken[87c0dd45cb368b]
2018-06-18 20:08:20.898 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62881 for null:0], KeyToken[9812ab1abcfc82]
2018-06-18 20:08:20.903 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62882 for null:0], KeyToken[cf98dadb202f4b]
2018-06-18 20:08:20.908 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62883 for null:0], KeyToken[a21fa2db]
2018-06-18 20:08:20.913 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62884 for null:0], KeyToken[6bd8a3067ee9]
2018-06-18 20:08:20.918 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62879 for null:0]
2018-06-18 20:08:20.928 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62880 for null:0]
2018-06-18 20:08:20.936 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62881 for null:0]
2018-06-18 20:08:20.943 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62882 for null:0]
2018-06-18 20:08:20.951 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62883 for null:0]
2018-06-18 20:08:20.957 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62884 for null:0]
openhab.log part 2
2018-06-18 20:09:20.829 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62886 for null:0], KeyToken[1f3039]
2018-06-18 20:09:20.875 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62885 for null:0]
2018-06-18 20:09:20.879 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62886 for null:0]
2018-06-18 20:09:20.888 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62887 for null:0], KeyToken[18686dccaa96ab]
2018-06-18 20:09:20.892 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62888 for null:0], KeyToken[59535dab0f]
2018-06-18 20:09:20.897 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62889 for null:0], KeyToken[fc61]
2018-06-18 20:09:20.902 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62890 for null:0], KeyToken[afa21e863e]
2018-06-18 20:09:20.906 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62891 for null:0], KeyToken[dfd9]
2018-06-18 20:09:20.910 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62892 for null:0], KeyToken[8bf3b3]
2018-06-18 20:09:20.915 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62887 for null:0]
2018-06-18 20:09:20.926 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62888 for null:0]
2018-06-18 20:09:20.937 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62889 for null:0]
2018-06-18 20:09:20.948 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62890 for null:0]
2018-06-18 20:09:20.958 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62891 for null:0]
2018-06-18 20:09:20.967 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62892 for null:0]
2018-06-18 20:10:20.822 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62893 for null:0], KeyToken[b7]
2018-06-18 20:10:20.827 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62894 for null:0], KeyToken[ce233f]
2018-06-18 20:10:20.872 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62893 for null:0]
2018-06-18 20:10:20.876 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62894 for null:0]
2018-06-18 20:10:20.886 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62895 for null:0], KeyToken[16dea69f950a]
2018-06-18 20:10:20.891 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62896 for null:0], KeyToken[5e317c]
2018-06-18 20:10:20.900 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62897 for null:0], KeyToken[4e511cda]
2018-06-18 20:10:20.906 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62898 for null:0], KeyToken[c33cf732]
2018-06-18 20:10:20.911 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62899 for null:0], KeyToken[8402c2f7]
2018-06-18 20:10:20.915 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62900 for null:0], KeyToken[cf0cfd56124e]
2018-06-18 20:10:20.919 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62895 for null:0]
2018-06-18 20:10:20.943 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62896 for null:0]
2018-06-18 20:10:20.966 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62897 for null:0]
2018-06-18 20:10:20.976 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62898 for null:0]
2018-06-18 20:10:20.985 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62899 for null:0]
2018-06-18 20:10:20.994 [DEBUG] [pse.californium.core.network.Matcher] - Closed open request with KeyMID[62900 for null:0]
2018-06-18 20:11:20.828 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62901 for null:0], KeyToken[0e612d3c1b2abf]
2018-06-18 20:11:20.832 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62902 for null:0], KeyToken[0a55ec2503]
2018-06-18 20:11:22.961 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62901 for null:0], KeyToken[0e612d3c1b2abf]
2018-06-18 20:11:23.829 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62902 for null:0], KeyToken[0a55ec2503]
2018-06-18 20:11:27.225 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62901 for null:0], KeyToken[0e612d3c1b2abf]
2018-06-18 20:11:29.823 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62902 for null:0], KeyToken[0a55ec2503]
2018-06-18 20:11:35.753 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62901 for null:0], KeyToken[0e612d3c1b2abf]
2018-06-18 20:11:41.811 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62902 for null:0], KeyToken[0a55ec2503]
2018-06-18 20:11:52.809 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62901 for null:0], KeyToken[0e612d3c1b2abf]
2018-06-18 20:12:05.788 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62902 for null:0], KeyToken[0a55ec2503]
2018-06-18 20:12:20.829 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62903 for null:0], KeyToken[78221446]
2018-06-18 20:12:20.833 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62904 for null:0], KeyToken[3f690c6037]
2018-06-18 20:12:22.857 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62904 for null:0], KeyToken[3f690c6037]
2018-06-18 20:12:23.706 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62903 for null:0], KeyToken[78221446]
2018-06-18 20:12:26.905 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62904 for null:0], KeyToken[3f690c6037]
2018-06-18 20:12:29.461 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62903 for null:0], KeyToken[78221446]
2018-06-18 20:12:35.002 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62904 for null:0], KeyToken[3f690c6037]
2018-06-18 20:12:40.969 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62903 for null:0], KeyToken[78221446]
2018-06-18 20:12:51.194 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62904 for null:0], KeyToken[3f690c6037]
2018-06-18 20:13:03.986 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62903 for null:0], KeyToken[78221446]
2018-06-18 20:13:20.831 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62905 for null:0], KeyToken[09af39d8ab]
2018-06-18 20:13:20.836 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62906 for null:0], KeyToken[c8ffbd2a1cc8]
2018-06-18 20:13:23.643 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62905 for null:0], KeyToken[09af39d8ab]
2018-06-18 20:13:23.743 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62906 for null:0], KeyToken[c8ffbd2a1cc8]
2018-06-18 20:13:29.266 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62905 for null:0], KeyToken[09af39d8ab]
2018-06-18 20:13:29.556 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62906 for null:0], KeyToken[c8ffbd2a1cc8]
2018-06-18 20:13:40.509 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62905 for null:0], KeyToken[09af39d8ab]
2018-06-18 20:13:41.179 [DEBUG] [pse.californium.core.network.Matcher] - Stored open request by KeyMID[62906 for null:0], KeyToken[c8ffbd2a1cc8]
events.log
2018-06-18 20:02:20.269 [me.event.ThingUpdatedEvent] - Thing 'tradfri:gateway:gwdcefcabcf9df' has been updated.
2018-06-18 20:02:20.667 [me.event.ThingUpdatedEvent] - Thing 'tradfri:gateway:gwdcefcabcf9df' has been updated.
2018-06-18 20:02:20.753 [hingStatusInfoChangedEvent] - 'tradfri:gateway:gwdcefcabcf9df' changed from OFFLINE (COMMUNICATION_ERROR) to UNKNOWN
2018-06-18 20:02:22.910 [hingStatusInfoChangedEvent] - 'tradfri:gateway:gwdcefcabcf9df' changed from UNKNOWN to ONLINE
2018-06-18 20:02:22.928 [hingStatusInfoChangedEvent] - 'tradfri:0830:gwdcefcabcf9df:65536' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-18 20:02:22.936 [hingStatusInfoChangedEvent] - 'tradfri:0830:gwdcefcabcf9df:65536' changed from ONLINE to UNKNOWN
2018-06-18 20:02:22.951 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65540' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-18 20:02:22.963 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65540' changed from ONLINE to UNKNOWN
2018-06-18 20:02:22.979 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65537' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-18 20:02:22.985 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65537' changed from ONLINE to UNKNOWN
2018-06-18 20:02:22.997 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65539' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-18 20:02:23.006 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65538' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-18 20:02:23.018 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65538' changed from ONLINE to UNKNOWN
2018-06-18 20:02:23.028 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65541' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-18 20:02:23.036 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65539' changed from ONLINE to UNKNOWN
2018-06-18 20:02:23.047 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65541' changed from ONLINE to UNKNOWN
2018-06-18 20:02:23.059 [ome.event.ItemCommandEvent] - Item 'TradfriOnline' received command OFF
2018-06-18 20:02:23.069 [ome.event.ItemCommandEvent] - Item 'TradfriOnlineStatus' received command ON
2018-06-18 20:02:23.086 [vent.ItemStateChangedEvent] - TradfriOnlineStatus changed from OFF to ON
2018-06-18 20:02:25.926 [hingStatusInfoChangedEvent] - 'tradfri:0830:gwdcefcabcf9df:65536' changed from UNKNOWN to ONLINE
2018-06-18 20:02:25.940 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65540' changed from UNKNOWN to ONLINE
2018-06-18 20:02:25.982 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65537' changed from UNKNOWN to ONLINE
2018-06-18 20:02:26.019 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65538' changed from UNKNOWN to ONLINE
2018-06-18 20:02:26.038 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65539' changed from UNKNOWN to ONLINE
2018-06-18 20:02:26.109 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65541' changed from UNKNOWN to ONLINE
2018-06-18 20:02:41.924 [hingStatusInfoChangedEvent] - 'tradfri:gateway:gwdcefcabcf9df' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2018-06-18 20:02:41.933 [hingStatusInfoChangedEvent] - 'tradfri:0830:gwdcefcabcf9df:65536' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-18 20:02:41.939 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65540' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-18 20:02:41.942 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65539' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-18 20:02:41.949 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65537' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-18 20:02:41.953 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65541' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-18 20:02:41.955 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65538' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-18 20:02:41.958 [ome.event.ItemCommandEvent] - Item 'TradfriOnline' received command OFF
2018-06-18 20:02:41.962 [ome.event.ItemCommandEvent] - Item 'TradfriOnlineStatus' received command OFF
2018-06-18 20:02:41.982 [vent.ItemStateChangedEvent] - TradfriOnlineStatus changed from ON to OFF
2018-06-18 20:03:20.880 [hingStatusInfoChangedEvent] - 'tradfri:gateway:gwdcefcabcf9df' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2018-06-18 20:03:20.885 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65539' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-18 20:03:20.895 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65539' changed from ONLINE to UNKNOWN
2018-06-18 20:03:20.897 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65540' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-18 20:03:20.899 [hingStatusInfoChangedEvent] - 'tradfri:0830:gwdcefcabcf9df:65536' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-18 20:03:20.901 [hingStatusInfoChangedEvent] - 'tradfri:0830:gwdcefcabcf9df:65536' changed from ONLINE to UNKNOWN
2018-06-18 20:03:20.906 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65540' changed from ONLINE to UNKNOWN
2018-06-18 20:03:20.919 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65537' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-18 20:03:20.932 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65537' changed from ONLINE to UNKNOWN
2018-06-18 20:03:20.947 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65541' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-18 20:03:20.950 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65541' changed from ONLINE to UNKNOWN
2018-06-18 20:03:20.963 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65538' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-18 20:03:20.965 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65538' changed from ONLINE to UNKNOWN
2018-06-18 20:03:20.975 [ome.event.ItemCommandEvent] - Item 'TradfriOnline' received command OFF
2018-06-18 20:03:20.976 [ome.event.ItemCommandEvent] - Item 'TradfriOnlineStatus' received command ON
2018-06-18 20:03:20.989 [vent.ItemStateChangedEvent] - TradfriOnlineStatus changed from OFF to ON
2018-06-18 20:03:23.896 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65539' changed from UNKNOWN to ONLINE
2018-06-18 20:03:23.914 [hingStatusInfoChangedEvent] - 'tradfri:0830:gwdcefcabcf9df:65536' changed from UNKNOWN to ONLINE
2018-06-18 20:03:23.919 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65540' changed from UNKNOWN to ONLINE
2018-06-18 20:03:23.943 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65537' changed from UNKNOWN to ONLINE
2018-06-18 20:03:23.958 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65541' changed from UNKNOWN to ONLINE
2018-06-18 20:03:23.980 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65538' changed from UNKNOWN to ONLINE
2018-06-18 20:12:53.753 [hingStatusInfoChangedEvent] - 'tradfri:gateway:gwdcefcabcf9df' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2018-06-18 20:12:53.761 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65540' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-18 20:12:53.777 [hingStatusInfoChangedEvent] - 'tradfri:0830:gwdcefcabcf9df:65536' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-18 20:12:53.808 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65539' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-18 20:12:53.814 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65541' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-18 20:12:53.824 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65537' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-18 20:12:53.835 [hingStatusInfoChangedEvent] - 'tradfri:0220:gwdcefcabcf9df:65538' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-18 20:12:53.848 [ome.event.ItemCommandEvent] - Item 'TradfriOnline' received command OFF
2018-06-18 20:12:53.866 [ome.event.ItemCommandEvent] - Item 'TradfriOnlineStatus' received command OFF
2018-06-18 20:12:53.886 [vent.ItemStateChangedEvent] - TradfriOnlineStatus changed from ON to OFF
Have you tried with another patch cable?
The one that comes with the gateway has known defects. Search this forum for posts on that.
You can also try changing the USB power supply…
I would look at your router as the possible issue. I have seen the router break many things.
Thanks for your suggestions.
It turned out to be the power supply that was causing the unstable behavior. I was not using the one which came with the gateway, but a different one which powers multiple usb devices.
Strange that it had been working for months…but thats hardware it sometime fails.
Awesome! Glad you fixed it.
