In case someone is still using the tradfri Binding, the following PR14836 is bringing to the Tradfri binding a new Air Purifier (Strakvind) thing.
It supports:
- changing fan mode, controlling LED and locking physical button.
- reading current fan speed, PM2.5 ppm reading, filter uptime, time remaining before next filer check, air quality reading (aligned with Tradfri app) and a Switch to signal when filter needs to be reviewed.
Note: you will still need to run the filter review process through the Tradfri Mobile App.
The JAR for testing on OpenHAB 3.4.3 is available here.
If you have questions or if you find bugs, feel free to shoot.
