Tradfri not working after update to OH2.2
I updated from OH2.1 to OH2.2 on openhabian a few hours ago. Now Tradfri isn’t reliable working for me. After a reboot it seems to work but if I have to change something on the things file and save I get this and I can’t switch my bulbs.
2017-11-17 22:30:40.166 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.things'
2017-11-17 22:30:40.688 [me.event.ThingUpdatedEvent] - Thing 'systeminfo:computer:sh2' has been updated.
2017-11-17 22:30:40.825 [me.event.ThingUpdatedEvent] - Thing 'network:pingdevice:SPMa' has been updated.
2017-11-17 22:30:40.994 [me.event.ThingUpdatedEvent] - Thing 'network:pingdevice:SPWo' has been updated.
2017-11-17 22:30:41.026 [hingStatusInfoChangedEvent] - 'tankerkoenig:webservice:TKWS' changed from ONLINE to UNKNOWN
2017-11-17 22:30:41.032 [hingStatusInfoChangedEvent] - 'tankerkoenig:station:TKWS:Station_FTS' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2017-11-17 22:30:41.041 [me.event.ThingUpdatedEvent] - Thing 'tankerkoenig:webservice:TKWS' has been updated.
2017-11-17 22:30:41.058 [hingStatusInfoChangedEvent] - 'tankerkoenig:station:TKWS:Station_FTS' changed from OFFLINE (BRIDGE_OFFLINE) to UNKNOWN
2017-11-17 22:30:41.066 [me.event.ThingUpdatedEvent] - Thing 'tankerkoenig:station:TKWS:Station_FTS' has been updated.
2017-11-17 22:30:41.142 [WARN ] [radfri.handler.TradfriGatewayHandler] - Gateway with old firmware - please consider upgrading to the latest version.
2017-11-17 22:30:41.604 [vent.ItemStateChangedEvent] - Memory_Available_Percent changed from 66.5 to 66.4
2017-11-17 22:30:41.629 [vent.ItemStateChangedEvent] - CPU_Uptime_Raw changed from 10.1 to 10.5
2017-11-17 22:30:46.097 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while calling thing updated at ThingHandler 'org.eclipse.smarthome.binding.tradfri.handler.TradfriGatewayHandler@1203816': null
java.util.concurrent.TimeoutException: null
	at java.util.concurrent.FutureTask.get(FutureTask.java:205) ~[?:?]
	at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:194) ~[?:?]
	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:83) ~[?:?]
	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:67) ~[?:?]
	at org.eclipse.smarthome.core.thing.internal.ThingManager.thingUpdated(ThingManager.java:423) ~[?:?]
	at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:217) ~[?:?]
	at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutUpdatedElement(ThingRegistryImpl.java:140) ~[?:?]
	at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutUpdatedElement(ThingRegistryImpl.java:1) ~[?:?]
	at org.eclipse.smarthome.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:183) ~[?:?]
	at org.eclipse.smarthome.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:1) ~[?:?]
	at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:57) ~[?:?]
	at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListenersAboutUpdatedElement(AbstractProvider.java:81) ~[?:?]
	at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.lambda$21(GenericThingProvider.java:894) ~[?:?]
	at java.util.ArrayList.forEach(ArrayList.java:1257) ~[?:?]
	at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.createThingsFromModelForThingHandlerFactory(GenericThingProvider.java:901) ~[?:?]
	at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.lambda$3(GenericThingProvider.java:294) ~[?:?]
	at java.lang.Iterable.forEach(Iterable.java:75) [?:?]
	at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.createThingsFromModel(GenericThingProvider.java:296) [133:org.eclipse.smarthome.model.thing:0.9.0.201711151730]
	at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.modelChanged(GenericThingProvider.java:710) [133:org.eclipse.smarthome.model.thing:0.9.0.201711151730]
	at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:309) [122:org.eclipse.smarthome.model.core:0.9.0.201711151730]
	at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:122) [122:org.eclipse.smarthome.model.core:0.9.0.201711151730]
	at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:242) [122:org.eclipse.smarthome.model.core:0.9.0.201711151730]
	at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:306) [122:org.eclipse.smarthome.model.core:0.9.0.201711151730]
	at org.eclipse.smarthome.core.service.WatchQueueReader.run(WatchQueueReader.java:204) [97:org.eclipse.smarthome.core:0.9.0.201711151730]
2017-11-17 22:30:46.240 [me.event.ThingUpdatedEvent] - Thing 'tradfri:gateway:tfgw' has been updated.
2017-11-17 22:30:46.242 [me.event.ThingUpdatedEvent] - Thing 'tradfri:gateway:tfgw' has been updated.
2017-11-17 22:30:46.264 [INFO ] [radfri.handler.TradfriGatewayHandler] - Bridge configuration updated. Updating paired things (if any).
2017-11-17 22:30:46.266 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:FloorLamp' changed from ONLINE to UNKNOWN
2017-11-17 22:30:46.272 [me.event.ThingUpdatedEvent] - Thing 'tradfri:0220:tfgw:FloorLamp' has been updated.
2017-11-17 22:30:46.330 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:DeskLamp' changed from ONLINE to UNKNOWN
2017-11-17 22:30:46.335 [hingStatusInfoChangedEvent] - 'tradfri:gateway:tfgw' changed from ONLINE to UNKNOWN
2017-11-17 22:30:46.340 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:DeskLamp' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE): Gateway offline 'UNKNOWN'
2017-11-17 22:30:46.344 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:FloorLamp' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE): Gateway offline 'UNKNOWN'
2017-11-17 22:30:46.358 [me.event.ThingUpdatedEvent] - Thing 'tradfri:0220:tfgw:DeskLamp' has been updated.
2017-11-17 22:30:46.361 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:DeskLamp' changed from OFFLINE (BRIDGE_OFFLINE): Gateway offline 'UNKNOWN' to UNKNOWN
2017-11-17 22:30:46.368 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:DeskLamp' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE): Gateway offline 'UNKNOWN'
2017-11-17 22:30:56.236 [hingStatusInfoChangedEvent] - 'tankerkoenig:station:TKWS:Station_FTS' changed from UNKNOWN to ONLINE
2017-11-17 22:30:56.244 [hingStatusInfoChangedEvent] - 'tankerkoenig:webservice:TKWS' changed from UNKNOWN to ONLINE
2017-11-17 22:31:03.795 [vent.ItemStateChangedEvent] - LivingRoom_Temp changed from 22.9 to 23.0
2017-11-17 22:31:03.803 [GroupItemStateChangedEvent] - Group_HighestTemp changed from 22.9 to 23.0 through LivingRoom_Temp
2017-11-17 22:31:03.868 [vent.ItemStateChangedEvent] - LivingRoom_TiSt changed from 2017-11-17T22:29:03.781+0100 to 2017-11-17T22:31:03.854+0100
2017-11-17 22:31:07.848 [vent.ItemStateChangedEvent] - Nursery_TiSt changed from 2017-11-17T22:29:07.753+0100 to 2017-11-17T22:31:07.833+0100
2017-11-17 22:31:10.475 [vent.ItemStateChangedEvent] - Kitchen_Temp changed from 20.4 to 20.5
2017-11-17 22:31:10.546 [vent.ItemStateChangedEvent] - Kitchen_TiSt changed from 2017-11-17T22:29:10.472+0100 to 2017-11-17T22:31:10.531+0100
2017-11-17 22:31:18.612 [vent.ItemStateChangedEvent] - Bath_Humi changed from 58 to 59
2017-11-17 22:31:18.640 [vent.ItemStateChangedEvent] - Bath_TiSt changed from 2017-11-17T22:29:18.555+0100 to 2017-11-17T22:31:18.617+0100
2017-11-17 22:31:26.470 [WARN ] [nternal.profiles.ProfileCallbackImpl] - Cannot delegate command '100' for item 'FloorLamp_Brightness' to handler for channel 'tradfri:0220:tfgw:FloorLamp:brightness', because no handler is assigned. Maybe the binding is not installed or not propertly initialized.
2017-11-17 22:31:26.481 [WARN ] [nternal.profiles.ProfileCallbackImpl] - Cannot delegate update '100' for item 'FloorLamp_Brightness' to handler for channel 'tradfri:0220:tfgw:FloorLamp:brightness', because no handler is assigned. Maybe the binding is not installed or not propertly initialized.
2017-11-17 22:31:26.484 [ome.event.ItemCommandEvent] - Item 'FloorLamp_Brightness' received command 100
2017-11-17 22:31:26.504 [vent.ItemStateChangedEvent] - FloorLamp_Brightness changed from 0 to 100
2017-11-17 22:31:26.507 [GroupItemStateChangedEvent] - Group_Lights changed from OFF to UNDEF through FloorLamp_Brightness
2017-11-17 22:31:26.679 [vent.ItemStateChangedEvent] - Bedroom_Temp changed from 19.5 to 19.2
2017-11-17 22:31:26.766 [vent.ItemStateChangedEvent] - Bedroom_TiSt changed from 2017-11-17T22:29:26.666+0100 to 2017-11-17T22:31:26.744+0100
2017-11-17 22:31:32.190 [WARN ] [nternal.profiles.ProfileCallbackImpl] - Cannot delegate command '6' for item 'FloorLamp_Brightness' to handler for channel 'tradfri:0220:tfgw:FloorLamp:brightness', because no handler is assigned. Maybe the binding is not installed or not propertly initialized.
2017-11-17 22:31:32.198 [ome.event.ItemCommandEvent] - Item 'FloorLamp_Brightness' received command 6
2017-11-17 22:31:32.205 [WARN ] [nternal.profiles.ProfileCallbackImpl] - Cannot delegate update '6' for item 'FloorLamp_Brightness' to handler for channel 'tradfri:0220:tfgw:FloorLamp:brightness', because no handler is assigned. Maybe the binding is not installed or not propertly initialized.
2017-11-17 22:31:32.221 [vent.ItemStateChangedEvent] - FloorLamp_Brightness changed from 100 to 6
2017-11-17 22:31:33.028 [vent.ItemStateChangedEvent] - Memory_Available_Percent changed from 66.4 to 66.5
2017-11-17 22:31:36.068 [vent.ItemStateChangedEvent] - Memory_Available_Percent changed from 66.5 to 66.4
2017-11-17 22:31:36.112 [WARN ] [nternal.profiles.ProfileCallbackImpl] - Cannot delegate command '100' for item 'FloorLamp_Brightness' to handler for channel 'tradfri:0220:tfgw:FloorLamp:brightness', because no handler is assigned. Maybe the binding is not installed or not propertly initialized.
2017-11-17 22:31:36.129 [ome.event.ItemCommandEvent] - Item 'FloorLamp_Brightness' received command 100
2017-11-17 22:31:36.130 [WARN ] [nternal.profiles.ProfileCallbackImpl] - Cannot delegate update '100' for item 'FloorLamp_Brightness' to handler for channel 'tradfri:0220:tfgw:FloorLamp:brightness', because no handler is assigned. Maybe the binding is not installed or not propertly initialized.
2017-11-17 22:31:36.145 [vent.ItemStateChangedEvent] - FloorLamp_Brightness changed from 6 to 100
2017-11-17 22:31:41.665 [vent.ItemStateChangedEvent] - CPU_Uptime_Raw changed from 10.5 to 11.5
2017-11-17 22:31:52.614 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:FloorLamp' changed from OFFLINE (BRIDGE_OFFLINE): Gateway offline 'UNKNOWN' to OFFLINE (BRIDGE_OFFLINE)
2017-11-17 22:31:52.626 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:DeskLamp' changed from OFFLINE (BRIDGE_OFFLINE): Gateway offline 'UNKNOWN' to OFFLINE (BRIDGE_OFFLINE)
2017-11-17 22:31:52.619 [hingStatusInfoChangedEvent] - 'tradfri:gateway:tfgw' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR)
2017-11-17 22:31:53.054 [hingStatusInfoChangedEvent] - 'tradfri:gateway:tfgw' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2017-11-17 22:31:53.086 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:FloorLamp' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2017-11-17 22:31:53.101 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:DeskLamp' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2017-11-17 22:31:53.107 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:FloorLamp' changed from ONLINE to UNKNOWN
2017-11-17 22:31:53.112 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:DeskLamp' changed from ONLINE to UNKNOWN
2017-11-17 22:31:56.088 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:FloorLamp' changed from UNKNOWN to ONLINE
2017-11-17 22:31:56.108 [GroupItemStateChangedEvent] - Group_Lights changed from UNDEF to OFF through FloorLamp_Brightness
2017-11-17 22:31:56.116 [vent.ItemStateChangedEvent] - FloorLamp_Brightness changed from 100 to 0
2017-11-17 22:31:56.134 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:DeskLamp' changed from UNKNOWN to ONLINE
2017-11-17 22:32:05.404 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:FloorLamp' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2017-11-17 22:32:15.390 [WARN ] [nternal.profiles.ProfileCallbackImpl] - Cannot delegate command '100' for item 'FloorLamp_Brightness' to handler for channel 'tradfri:0220:tfgw:FloorLamp:brightness', because no handler is assigned. Maybe the binding is not installed or not propertly initialized.
2017-11-17 22:32:15.399 [ome.event.ItemCommandEvent] - Item 'FloorLamp_Brightness' received command 100
2017-11-17 22:32:15.404 [WARN ] [nternal.profiles.ProfileCallbackImpl] - Cannot delegate update '100' for item 'FloorLamp_Brightness' to handler for channel 'tradfri:0220:tfgw:FloorLamp:brightness', because no handler is assigned. Maybe the binding is not installed or not propertly initialized.
2017-11-17 22:32:15.417 [GroupItemStateChangedEvent] - Group_Lights changed from OFF to UNDEF through FloorLamp_Brightness
2017-11-17 22:32:15.427 [vent.ItemStateChangedEvent] - FloorLamp_Brightness changed from 0 to 100
2017-11-17 22:32:15.447 [hingStatusInfoChangedEvent] - 'tradfri:0220:tfgw:FloorLamp' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2017-11-17 22:32:15.470 [vent.ItemStateChangedEvent] - FloorLamp_Brightness changed from 100 to 0
2017-11-17 22:32:15.476 [GroupItemStateChangedEvent] - Group_Lights changed from UNDEF to OFF through FloorLamp_Brightness
2017-11-17 22:32:20.275 [WARN ] [nternal.profiles.ProfileCallbackImpl] - Cannot delegate command '10' for item 'FloorLamp_Brightness' to handler for channel 'tradfri:0220:tfgw:FloorLamp:brightness', because no handler is assigned. Maybe the binding is not installed or not propertly initialized.
2017-11-17 22:32:20.282 [ome.event.ItemCommandEvent] - Item 'FloorLamp_Brightness' received command 10
2017-11-17 22:32:20.282 [WARN ] [nternal.profiles.ProfileCallbackImpl] - Cannot delegate update '10' for item 'FloorLamp_Brightness' to handler for channel 'tradfri:0220:tfgw:FloorLamp:brightness', because no handler is assigned. Maybe the binding is not installed or not propertly initialized.
2017-11-17 22:32:20.298 [vent.ItemStateChangedEvent] - FloorLamp_Brightness changed from 0 to 10
2017-11-17 22:32:20.304 [GroupItemStateChangedEvent] - Group_Lights changed from OFF to UNDEF through FloorLamp_Brightness
2017-11-17 22:32:21.087 [vent.ItemStateChangedEvent] - SWU_Temperature changed from 3.40 to 3.30
2017-11-17 22:32:26.594 [vent.ItemStateChangedEvent] - Basement_TiSt changed from 2017-11-17T22:30:26.502+0100 to 2017-11-17T22:32:26.578+0100
2017-11-17 22:32:26.600 [WARN ] [nternal.profiles.ProfileCallbackImpl] - Cannot delegate command '100' for item 'FloorLamp_Brightness' to handler for channel 'tradfri:0220:tfgw:FloorLamp:brightness', because no handler is assigned. Maybe the binding is not installed or not propertly initialized.
2017-11-17 22:32:26.609 [ome.event.ItemCommandEvent] - Item 'FloorLamp_Brightness' received command 100
2017-11-17 22:32:26.615 [WARN ] [nternal.profiles.ProfileCallbackImpl] - Cannot delegate update '100' for item 'FloorLamp_Brightness' to handler for channel 'tradfri:0220:tfgw:FloorLamp:brightness', because no handler is assigned. Maybe the binding is not installed or not propertly initialized.
2017-11-17 22:32:26.634 [vent.ItemStateChangedEvent] - FloorLamp_Brightness changed from 10 to 100
Disconnect the Item*s from the Tradfri Bulbs und reconnect… that should fix the Problem …
I think the Problem is related to this Issue …
That worked. Thank you.
