Hello guys,
I have seen a couple of similar topic - but no answers yet. Not sure if I have a very special setup. So - here it comes.
I run IOBroker on a Raspi4 with the basic zigbee-Adapter.
I run OpenHAB on another Raspi which basically is used for the mobile frontend.
I run MQTT client and server Adapter
I do NOT use a Tradfri Gateway or Binding.
I added a few Tradfri Bulbs to zigbee (the more zigbee items, the better), grouped them and want to control them through MQTT
Options for MQTT are set on the Tradfri Objects on brightness, color, colortemp and state
MQTT subscribe channel is zigbee/0/group1/color, zigbee/0/group1/state - and so on.
Created a generic MQTT thing STATE - and am able to turn on/off
Created a generic MQTT thing brightness - and am able to change that in the UI
Failed to use the color-picker
When changing through the color-picker the log shows the following:
Item ‘Tradfri_Color_item’ received command 7.253140006695458,5.516775805954667,20.000000298023224
It also updates something in the MQTT object on IOBroker (but only rubbish with special characters and no nice RGB number like 33FF45) - manually editing the Objects field works and changes the color.
Somehow I need to get the “received command” with the float number and transform it and get it into the objects-are in IOBroker. Any clue?
