Is there a way to transform a whole range of numbers. Something like a map() function in arduino.
For example to transform the numbers from 234 to 833 into a range from 0 to 100.
I guess MAP will not work and I can’t find ANY documentation or examples of SCALE.
The SCALE transform is unlikely to do what you want, but I wanted you be aware of where to find the docs in case you need it again. For what you need, you will either need to write a rule or use the javascript transform as indicated above.
