- Platform information:
- Hardware: RPi4B/8GB/SSD over USB3
- OS: Raspbian GNU/Linux 10 (buster) with docker. Openhab in container.
- Java Runtime Environment: openjdk version “1.8.0_265”
- openHAB version: 2.4.0 (in docker container)
Issue: I try to use the function ‘transform’ in an openhab rule, to get a value out of a json string. I cannot get this function to produce any output other then the json string on input itself.
With the rule below, I run an InfluxDB query for which I didn’t find a pure openhab solution. I had the same challenge and applied the solution as in [closed][unsolved]Influxdb sumSince not working for switches
rule “abc”
Time cron “0 * * * * ?”
var String answer = sendHttpGetRequest(“http://localhost:8086/query?db=openhab_db&q=select%20sum(value)%20from%20PushButton%20where%20time%20>%20now()%20-5d;”)
val eventCount = transform(“JSONPATH”, “$.results.[0].series.[0].values.[0].[1]”, answer)
logInfo(“rules”, "abc answer: " + answer)
logInfo(“rules”, "abc eventCount: " + eventCount)
The http requests replies with a json string and I need to extract one element from this string. In the data below, I need to extract the number 61 out of the json string
These are the generated log data:
2021-01-17 11:59:00.027 [INFO ] [eclipse.smarthome.model.script.rules] - abc answer: {“results”:[{“statement_id”:0,“series”:[{“name”:“PushButton”,“columns”:[“time”,“sum”],“values”:[[“2021-01-12T10:59:00.012434503Z”,61]]}]}]}
2021-01-17 11:59:00.031 [INFO ] [eclipse.smarthome.model.script.rules] - abc eventCount: {“results”:[{“statement_id”:0,“series”:[{“name”:“PushButton”,“columns”:[“time”,“sum”],“values”:[[“2021-01-12T10:59:00.012434503Z”,61]]}]}]}
The jsonpath parsing string seems correct to me. I used the online “Jayway jsonpath evaluator” at https://jsonpath.herokuapp.com/ to validate this and there it works correctly. The result is 61.
I also tried many alternative jsonpath strings. But never obtained any result. The output of the transform function (val eventCount) always remains equal to the input (var answer).
Can anyone advise?
