if I have a value such as “OL CHRG” and I want to Transform this to “Online Charging” how do I deal with the space between the current values?
I tried ‘’ and “” but it fails to work
12:26:09.715 [WARN ] [orm.AbstractFileTransformationService] - Could not transform 'OL CHRG' with the file 'en.map' : Target value not found in map for 'OL CHRG'
I read nothing which says “When dealing with spaces in the key, use an escape sequence like this example”
Clearly if there was a post on this (which I failed to find) other users also are having problems with the documentation.
Remember not all of us are maintainers or developers so we don’t always get the way people explain things in the documentation
I read nothing which indicated my issue, hence the post. Anyway, its working now and ill submit a revision to the documentation to help others as youve helped me.
