- Platform information:
- Hardware: Raspberry Pi 3B+
- OS: _ Raspbian GNU/Linux 11 (bullseye) - Linux 5.15.32-v7+
- Java Runtime Environment: which java platform is used and what version
- openHAB version: 3.3.0
- Issue of the topic:
After upgrading from OH version 3.2.0 to 3.3.0 the transform:SCALE which is stated in the items file is no longer processed. The windspeed is read from Openweathermap (as logged) but the item is not changed.
the lines in the item file:
Number Weer_Amst_buitentemp "Buitentemp [%.1f °C]" <temperature> (Weer) { channel="openweathermap:weather-and-forecast:api:amst:current#temperature" }
Number Weer_Amst_wind "Wind [%d Bft]" <wind> (Weer) { channel="openweathermap:weather-and-forecast:api:amst:current#wind-speed" [profile="transform:SCALE", function="beaufort.scale"] }
Log file shows:
2022-09-01 12:43:16.380 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âWeer_Amst_buitentempâ changed from 23.22 to 23.4
2022-09-01 12:43:16.411 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âWeatherandForecast_OutdoorTemperatureâ changed from 23.22 °C to 23.4 °C
2022-09-01 12:43:16.424 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âWeatherandForecast_WindSpeedâ changed from 18.504 km/h to 24.084 km/h
The temperature value is assigned to the item, the windspeed, including transform:scale is not. The windspeed item remains value 1, even though the windspeed varies between 3 and 4 today.
This non-functioning was -I think- introduced after upgrading to version 3.3.0
Anyone any suggestions on what could be the problem and how to resolve?
Thanks !
The file beaufort.scale:
[..1.85[=0
[1.85..7.41[=1
[7.41..12.96[=2
[12.96..20.37[=3
[20.37..29.63[=4
[29.63..40.74[=5
[40.74..51.86[=6
[51.86..62.97[=7
[62.97..75.93[=8
[75.93..88.90[=9
[88.90..103.71[=10
[103.71..118.53[=11
[118.53..]=12
