after update to 2.5.10 java script transformation doesn’t work correctly. Before upgrade from 2.5.6 everything works correctly.
There is my system configuration:
RPI4, Ubuntu 20.04.1 LTS
openjdk version “11.0.9.1” 2020-11-04
OpenJDK Runtime Environment (build 11.0.9.1+1-Ubuntu-0ubuntu1.20.04)
OpenJDK 64-Bit Server VM (build 11.0.9.1+1-Ubuntu-0ubuntu1.20.04, mixed mode)
Log from using JavaScript Transformation Service :
09:50:33.130 [ERROR] [org.openhab.transform.javascript ] - bundle org.openhab.transform.javascript:2.5.10 (305)[org.openhab.transform.javascript.internal.JavaScriptEngineManager(331)] : Error during instantiation of the implementation object
java.lang.reflect.InvocationTargetException: null
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:490) ~[?:?]
at org.apache.felix.scr.impl.inject.ComponentConstructor.newInstance(ComponentConstructor.java:309) ~[bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:277) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:982) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:955) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:900) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [org.eclipse.osgi-3.12.100.jar:?]
at java.security.AccessController.doPrivileged(Native Method) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:86) [bundleFile:?]
at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.prebind(DependencyManager.java:1154) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1568) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1029) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:935) [bundleFile:?]
at org.eclipse.smarthome.core.transform.TransformationHelper.getTransformationService(TransformationHelper.java:69) [bundleFile:?]
at org.openhab.binding.mqtt.generic.internal.MqttThingHandlerFactory.getTransformationService(MqttThingHandlerFactory.java:88) [bundleFile:?]
at org.openhab.binding.mqtt.generic.ChannelStateTransformation.processValue(ChannelStateTransformation.java:82) [bundleFile:?]
at org.openhab.binding.mqtt.generic.ChannelState.publishValue(ChannelState.java:358) [bundleFile:?]
at org.openhab.binding.mqtt.generic.AbstractMQTTThingHandler.handleCommand(AbstractMQTTThingHandler.java:148) [bundleFile:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy193.handleCommand(Unknown Source) [?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:74) [bundleFile:?]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
Caused by: java.lang.NoClassDefFoundError: javax/script/ScriptEngineFactory
at java.lang.ClassLoader.findBootstrapClass(Native Method) ~[?:?]
at java.lang.ClassLoader.findBootstrapClassOrNull(ClassLoader.java:1258) ~[?:?]
at java.lang.System$2.findBootstrapClassOrNull(System.java:2134) ~[?:?]
at jdk.internal.loader.ClassLoaders$BootClassLoader.loadClassOrNull(ClassLoaders.java:118) ~[?:?]
at jdk.internal.loader.BuiltinClassLoader.loadClassOrNull(BuiltinClassLoader.java:616) ~[?:?]
at jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:579) ~[?:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:522) ~[?:?]
at org.eclipse.osgi.internal.framework.ContextFinder.loadClass(ContextFinder.java:127) ~[org.eclipse.osgi-3.12.100.jar:?]
at java.lang.Class.forName0(Native Method) ~[?:?]
at java.lang.Class.forName(Class.java:398) ~[?:?]
at java.util.ServiceLoader$LazyClassPathLookupIterator.nextProviderClass(ServiceLoader.java:1209) ~[?:?]
at java.util.ServiceLoader$LazyClassPathLookupIterator.hasNextService(ServiceLoader.java:1220) ~[?:?]
at java.util.ServiceLoader$LazyClassPathLookupIterator.hasNext(ServiceLoader.java:1264) ~[?:?]
at java.util.ServiceLoader$2.hasNext(ServiceLoader.java:1299) ~[?:?]
at java.util.ServiceLoader$3.hasNext(ServiceLoader.java:1384) ~[?:?]
at javax.script.ScriptEngineManager.initEngines(ScriptEngineManager.java:123) ~[java.scripting:?]
at javax.script.ScriptEngineManager.init(ScriptEngineManager.java:87) ~[java.scripting:?]
at javax.script.ScriptEngineManager.(ScriptEngineManager.java:62) ~[java.scripting:?]
at org.openhab.transform.javascript.internal.JavaScriptEngineManager.(JavaScriptEngineManager.java:46) ~[?:?]
… 59 more
09:50:33.144 [WARN ] [tt.generic.ChannelStateTransformation] - Transformation service JS for pattern out.js not found!
09:50:33.154 [INFO ] [smarthome.event.ItemStateChangedEvent] - Curtain1 changed from NULL to ON
Log from installing JavaScript Transformation Service (after uninstall):
9:27:55.848 [ERROR] [org.openhab.transform.javascript ] - bundle org.openhab.transform.javascript:2.5.10 (305)[org.openhab.transform.javascript.internal.JavaScriptEngineManager(331)] : Error during instantiation of the implementation object
at
