Transformation service JS for pattern div100.js not found
Hardware : RPI4
Distro : Openhabian ( Bullseye )
I have run a update from Openhab 3.4.1 to 4.0.2. had made a fresh install as my RPI was still running Disto Buster instead of Bullseye. But with a Backup and restore as described it was pretty fast running again. But I have some trouble with the state transformation of some Things. I can’t figure it out.
I have the following log warning. ( and the thing doesn’t give a value ). It’s for my thermostaat.
[WARN ] [.transform.SingleValueTransformation] - Transformation service JS for pattern div100.js not found!
It is used by my Thermostat with the following HTTP request
channels:
  - id: currentSetpoint
    channelTypeUID: http:number
    label: Toon Current Setpoint
    description: null
    configuration:
      commandTransformation: JS:tim100.js
      stateExtension: ?action=getThermostatInfo
      commandExtension: ?action=setSetpoint&Setpoint=%2$s
      stateTransformation: JSONPATH:$.currentSetpoint∩JS:div100.js
The div100.js file is located in the Transform folder. And has the following content.
(function(i){
	return parseInt(i)/100;
})(input)
I have installed the JSON transformation Path Add-On
It was working in Openhab 3. but I know there are changes in the transformation and in the Javaschript language NashornJS to GraalJS. Maybe it has something to with this.
But to make a long story not to long. Does anyone have any idea how I can fix this ? Probably I need an other approach now ?
Thanks ik advanced.
Install the JS Scripting add-on.
Thanks,
I had the feeling it was something I had completely overlook it.
