Have you tried increasing the timeout to 10 seconds or maybe more?
How can I do this ?
How can I do this ?
Change the 5000 to 10000
Switch videoprojector1 "CCC-PROJ-01 ON/OFF" (All, Projector) {exec="<[/usr/local/bin/pjlink -p CCC-PROJ-01:4352 power:10000:JS(parseEpson.js)] >[ON:/usr/local/bin/pjlink -p CCC-PROJ-01:4352 power on] >[OFF:/usr/local/bin/pjlink -p CCC-PROJ-01:4352 power off]"}
Ok that’s what I thought. I do that. I’ll let you know in a few days, thank you Vincent
Or, you could find out, what’s returned on a time out and deal with it in your transform.
I haven’t been following this thread that closely so I apologize if this has already been mentioned.
What if i !== 'on'
and i !== 'off'
? The transform doesn’t return anything. I can easily see that causing an error. I’d at least add an else and return something meaningful for the case when i doesn’t match either if clause.
Hello rlkoshak
No because at the beginning of the problem I had an ELSE for this situation.
For the lasted test I have removed it but I think It’s better with a ELSE.
Dear all,
For the moment I have removed the line with parseEpson.js
But this morning new problem without the line :
2018-10-12 22:47:43.139 [WARN ] [lipse.jetty.server.AbstractConnector] -
java.io.IOException: Too many open files
Maybe there is a link between parseEpson.js error and this error
$ ulimit -a
core file size (blocks, -c) 0
data seg size (kbytes, -d) unlimited
file size (blocks, -f) unlimited
max locked memory (kbytes, -l) unlimited
max memory size (kbytes, -m) unlimited
open files (-n) 256
pipe size (512 bytes, -p) 1
stack size (kbytes, -s) 8192
cpu time (seconds, -t) unlimited
max user processes (-u) 1418
virtual memory (kbytes, -v) unlimited
I’m on Mac Sierra OS.
I think if I increase the number of max file I probably stop the error of parseEpson.js
I will do it Monday !
I will let you know if it corrects the problem.
It seems to work very well.
It was a problem with ulimit -a on mac OS
Thanks for all
Dear all,
OMG, the problem is always present.
It seems to be a bug only with BasicUI
