I was investigating excessive TCP traffic on my network (2GB more Internet traffic per day as usual), when I stumbled over very frequent calls to transform/duration.js. This script converts ISO dates to a more legible format on time timestamps on the sitemap.
I think this is one you will have to experiment to find the best solution. I would imagine doing the conversions in a Rule would reduce the traffic.
But one has to an why you are using a transform for this. Typically if you have an iso date you would use a DateTime Item and label formatting to display the date how ever you want.
Are you reinventing the wheel or is there a detail that is missing to explain why lable formatting won’t work.
