What’s your default sitemap? Make sure the file name and the site map tag both are the same. Then go to the iOS app settings, select sitemap, and make sure it’s selected.
A search of the forum shows other people are experiencing error 500 over sitemap issues so I suspect your problem might be there.
It might have just been a typo, but make sure you use a closed curly brace after your frame.
You could always try the demo sitemap, just to rule out sitemap issues.
Does your sitemap load properly in basicui from a browser with no errors in the log? Newer versions of openHAB are more strict than older ones in handling minor syntax errors.
Are you sure your router isn’t blocking the port? And that the phone is connected to the right network? I once spent an hour troubleshoot the iOS app before I realized I had wifi turned off, so don’t be offended by my asking.
Did you try the rest of the things I suggested? You didn’t say so whether you did or not. I would try getting the demo sitemap working first to ensure it’s not network related.
I am able to fix the issue.
Map transformation was having issue. Map transformation should be %s not %d. One of mine had %d. took a while.
If you are having issues with iOS app not displaying sitemap
Please check http://hostname:port/rest/items/ in your browser. If you get complete list of items in rest format then iOS app will display sitemap, if not disable map transformation, check logs
