Normally, you’d create an Item like Trigger_my_Rule unlinked to any devices, put a button on your widget that sends ON to that, and have a rule listening for commands to it. The rule can then do whatever.
Anything you send from UI has to go to a single Item, so there aren’t that many choices.
Search this forum for “alarm clock” and similar for scheduling UI ideas. Use the Ephemeris feature for more complex working, like different each day.
I’ve got some stuff on a very crude system; an Item holds “minute of day” as an integer, a transform displays this on UI in HH:MM “clock” form, a setpoint widget allows to bump and down in 10 minute intervals, and a rule does the actual scheduling/re-scheduling when the Item gets a command, or at boot time.
