I got it already working that I can switch some Power Plugs on and off via Google Home Assistant. But I dont know how I can directly trigger a rule when I say for example that I’m leaving home. I can setup in the Google Home App some routines for that and Google triggers the Items directly. But I want to trigger just my own rule (or an virtual Item that can trigger a rule) because I wanna use Wake on Lan and Remote Shutdown abilities.
Can you help me please?
PS for your understanding: Remote Shutdown and WOL is already working but not through the speech assistant
MDAR
2
Hi
That sounds like it should work.
Get Google Assistant to switch “on” a virtual item.
Create a rule that triggers when the virtual item changes to ON
And at the end of that rule, switch your virtual item OFF.
I selected the items ZuHause and Wach in the cloud connector and I can see them in my Google Home App. But when I say for example that I am going to bed that Google cannot reach the items. I see them and can trigger it in the App but nothing happens. Can you help me?
MDAR
4
Oh I see…
Have you added the “Switchable” tag to the items you want Google Assistant to switch?
And now it work for me. Is it a bug or does it work as designed that you can’t multitag items for Home Assistant? Otherwise I have no idea why it do work now.
MDAR
6
