In your post you stated that you want to create rule for “this event” (“4_TASTER_1_PressShort changed from OFF to ON”), but in your rule you used an other event…
Thats true. It was a try because in the events.log I can see two lines, one with “OFF to ON” and because of the button release one from “ON to OFF” - so both should be true according to the log entries.
Never the less: Even if I change the trigger to “OFF to ON” it does not work.
rule "rollershutters"
Item 4_TASTER_1_PressShort changed from ON to OFF
logInfo("Test", "it triggers!")
sendCommand(SZ_ACT_ROLLO_NORDEN_1_Level, UP)
please try to add a debug (logInfo) text and watch if it’s in the openhab.log
Time cron "0 0/3 * 1/1 * ? *" or
Item 4BUTTON_2_PressShort changed from OFF to ON
Now all 3 minutes the log get’s a new entry and my shutter moves - what’s wrong with the button?! It gets logged in events.log so OH should be able to use it, right?!
