miholtz
(Miholtz)
#1
Hello all,
i’m pretty new to openhab. At present i’m a little bit playing around with the astro-bindings addon.
Is it possible to trigger channel-events manually for testing purposes?
I defined a rule with an if-statement :
Channel 'astro:sun:home:set#event' triggered START
So, i want to trigger astro:sun:home:set#event, manually …
Best regards
Michel
vzorglub
(Vincent Regaud)
#2
If you want to test your rule, you can just add another trigger to it:
Create a dummy switch
Switch DummyTest
Your rule:
Channel 'astro:sun:home:set#event' triggered START or
DummyTest received command ON
Will execute the rule when you switch the DummyTest switch ON, via REST or UI
miholtz
(Miholtz)
#3
Ok, thtat’s a good way to at least test the rule.
For me it seems, that the event isn’t triggered, so it would have been nice to trigger it manually …
But thank you for your participation.
