triggeringChannel equivalent in ECMAScript
I have a physical switch with four buttons and currently four rules to handle the button presses.
Now I want to create one rule per switch that triggers for all four buttons. As “Then” I use ECMAScript. How do I know which button has been pressed? I’d like to have something like
switch (trigger) {
  case 'top-left':
    # top left button has been pressed
    break;
  case 'top-right':
    # top rightbutton has been pressed
    break;
For the old school rules there’s the keyword triggeringChannel , but is there an equivalent in ECMAScript?
There are the three events that you can use. Not sure how you detect which button has been pressed as I don’t know the setup of your button:
event.itemName
event.channel
event.event
In some of my things it is even a particular channel that tells me which button was pressed by providing a scene number.
Thanks. Is there a place to look up such things?
Yes, here: GitHub - openhab/openhab-js: openHAB JavaScript Library for JavaScript Scripting Automation
