I recently bought a couple of the new Aeotec ZW130 WallMote Quad. Since this is a fairly new device, it is not in the z-wave device database. The problem I’m having is that the devices doesn’t seem to create an XML-config file. I have woken up the device several times, and the thing is showing up as expected in Paper UI and Habmin,
This is the output from http://localhost:8080/rest/things/zwave:device:904d0572:node34
"statusInfo": {
"status": "ONLINE",
"statusDetail": "NONE"
"label": "Controlpanel kitchen",
"bridgeUID": "zwave:serial_zstick:904d0572",
"configuration": {},
"properties": {
"zwave_class_basic": "ROUTING_SLAVE",
"zwave_class_generic": "REMOTE_SWITCH_2",
"zwave_frequent": "false",
"zwave_neighbours": "5,9,20,32",
"zwave_nodeid": "34",
"zwave_version": "0.0",
"zwave_listening": "false",
"zwave_routing": "true",
"zwave_beaming": "true",
"zwave_class_specific": "SWITCH_REMOTE2_MULTILEVEL",
"zwave_wakeup_time": "2017-02-13T19:49:11Z"
"UID": "zwave:device:904d0572:node34",
"thingTypeUID": "zwave:device",
"channels": []
A config is available in OpenZWave and from the Z-wave Alliance database, but I’m not sure how to proceed in order to add it to the database.
Does anyone else have this device and is able to provide the node.xml-file?
