Platform information:
Hardware: Inter Atom CE5335/1024MB/4TB(Mirrored)
OS: DSM6.2.2-24922 Update 4
Java Runtime Environment: 8.0.212-0018
openHAB version:openHAB-2.4.0.002-syno-noarch-0.001.spk
Issue of the topic:
Trying to install, getting the error “Port undefined configured for this package is either used by another service or reserved for system. Please disable or modify the conflicting service, or contact the developer to modify the package configuration”
Looked for openHAB logs in /var/log butr none found.followed steps describein the next lenk, but no luck. Pretty stuck here.
TIA
Hans
Kennet
(Kennet)
November 23, 2019, 4:13pm
#2
Sounds like a permissions issue did you read the article on serial ports
https://www.openhab.org/docs/administration/serial.html
You will most likely need to do some setup via ssh
You can also read this.
Kennet, maybe: at least I followed the steps th set access for the ports but it did not help.
But removing zarafa.sc (I uninstalled zarafa a long time ago and this file obviously was a leftover) as mentioned here
I would like to install OpenHAB-2.1.0.002-SNAPSHOT-DSM6-syno-noarch-0.001.spk on my synology.
I get an error:
“port undeffined configured for this package is either used by another service or reserved for system use. Please disable or modify the conflicting service, or contact the developer to modify the package configuration.”
I use DS1815+ with bunch of software on.
In the link below looks like it helps if I would uninstall Cloud Station, but I need it…
Is there any way to install…
did the trick
Thanks for the swift reply anyway!
