Hi All,
I am attempting the move from KNX 1.x to 2.3.0 and having some issues with the heating control. The current heating value is not shown, and I’m at a loss what to try next. When I go to the site map on my iphone or BasicUI I see the correct page, the dimmer works fine, but it just displays the text with no value for the temperature. I haven’t started yet with trying to get set point and valve position in. Any help to fix this would be great as I’m starting to get worried with it getting colder and the heating not working…
The items file from my 1.x set-up was:
Number Temperature_EG_WZ_Actual “Temperatur Ist [%.1f C]” (EG_Wohnzimmer) {knx="+<12/3/20"}
Number Temperature_EG_WZ_SP “Temperatur Soll [%.1f C]” (EG_Wohnzimmer) {knx="+<12/3/25"}
Number Valve_EG_WZ_Pos “Stellwert [%d %%]” (EG_Wohnzimmer) {knx="+<5.001:12/3/22"}
With my 2.3.0 set up I have:
Things:
Bridge knx:ip:bridge [
ipAddress=“10.47.xx.xxx”,
portNumber=3671,
localIp=“192.168.xx.xx”,
type=“TUNNEL”,
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=1,
localSourceAddr=“1.1.242” ]
Thing device knx [
Type dimmer: TreppenhausTreppenhausLichtStufenuntenDALI “Lower Steps” [ switch=“4/1/22+<4/1/28”, position=“4/1/24+<4/1/29”, increaseDecrease=“4/1/23” ]
Type number: TempWohnung “Temperature” [ knx="+<12/3/20" ]
Items:
Dimmer TreppenhausTreppenhausLichtStufenuntenDALI “Lower Steps [%d %%]” <light> (Treppenhaus, Beleuchtung) { channel=“knx:device:bridge:knx:TreppenhausTreppenhausLichtStufenuntenDALI” }
Number TempWohnung “Temperature [%.1f °C]” { channel=“knx:device:bridge:knx:TempWohnung” }
// END
Sitemap:
sitemap knx label=“My House” {
//Main House
Frame label=“House” {
Group item=2OG icon=attic
Group item=1OG icon=firstfloor
Group item=EG icon=groundfloor
Group item=KG icon=cellar
Group item=Treppenhaus
Group item=garage icon=garage
Group item=garden icon=garden
// Functions
Frame label=“Functions” {
Group item=Heizung icon=temperature
Group item=BWM icon=motion
Frame label=“Test” {
Text item=TempWohnung
My system:
Release = Raspbian GNU/Linux 8 (jessie)
Kernel = Linux 4.9.35-v7+
Platform = Raspberry Pi 3 Model B Rev 1.2
Uptime = 2 day(s). 5:19:36
CPU Usage = 23.5 % avg over 4 cpu(s) (4 core(s) x 1 socket(s))
OH Build 2.3.0-1
binding-knx - 2.3.0
KNX set-up:
Address Name Description Data Type Length Last Value
12/3/0 Zentral Zentrale Funktionen 0-20
12/3/20 Temperaturmesswert Wohnen Wohnen Fussbodenheizung temperature (°C) 2 bytes 0C 5F | 22.38 °C
12/3/21 Sperren Wohnen Wohnen Fussbodenheizung enable 1 bit
12/3/22 Status Stellwert Wohnen Wohnen Fussbodenheizung percentage (0…100%) 1 byte $00 | 0 %
12/3/23 Zwangsstellung Wohnen Wohnen Fussbodenheizung enable 1 bit
12/3/24 Sollwert Komfort Wohnen Wohnen Fussbodenheizung temperature (°C) 2 bytes 0C 1A | 21 °C
12/3/25 Aktueller Sollwert Wohnen Wohnen Fussbodenheizung temperature (°C) 2 bytes 0C 1A | 21 °C
12/3/26 Betriebsartvorwahl Wohnen Wohnen Fussbodenheizung HVAC mode 1 byte
12/3/27 HVAC Status Wohnen Wohnen Fussbodenheizung HVAC mode 1 byte $01 | Comfort
12/3/28 RHCC Status Wohnen Wohnen Fussbodenheizung RHCC status 2 bytes
12/3/29 Betriebsart Komfort Wohnen Wohnen Fussbodenheizung switch
12/3/30 Betriebsart Nacht Wohnen Wohnen Fussbodenheizung switch
12/3/31 Betriebsart Frostschutz Wohnen Wohnen Fussbodenheizung switch
12/3/32 Frostalarm Wohnen Wohnen Fussbodenheizung alarm 1 bit
12/3/33 Hitzealarm Wohnen Wohnen Fussbodenheizung alarm 1 bit
12/3/34 Sollwertverschiebung (1=+/0=-) Wohnen Wohnen Fussbodenheizung step 1 bit
12/3/35 Diagnosetext Wohnen Wohnen Fussbodenheizung Character String (ASCII) 14 bytes
