Hello I want to devlop my binding further and resolve some issues. But if I start the demo app for debugging in the eclipse environment I don’t see the changed code I still see the old code and not the new one. So i am guessing it takes the code from the official repository how can i change it to take the local changed binding?
You need to change the following line in launch/app/pom.xml
from
<version>2.5.9-SNAPSHOT</version>
to
<version>2.5.10-SNAPSHOT</version>
Getting now this error:
18:43:20.067 [qtp913451234-55] WARN o.e.s.c.t.internal.ThingRegistryImpl:261 - Cannot create thing. No binding found that supports creating a thing of type 'yioremote:yioRemoteDock'.
How should I answer when I don‘t know your code ?
What aadons codebase are you using?
I’ve seen this error when the binding id defined in your *Constants.java
file doesn’t match the thing definition in your thing.xml
file.
But as @hmerk says, it’s really hard to say without seeing your code.
