- Platform information:
- Hardware: _CPUArchitecture/RAM/storage_Intel I7/32GB Ram/500GB SSD/10TB HD for data
- OS: _what OS is used and which version_Ubuntu 20.00
- Java Runtime Environment: _which java platform is used and what version_Latest
- openHAB version:3.0
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
I am having difficulty adding my AEON Z-Stick (Older ver, not Gen5). I seem to have the correct Serial Port Set but I get an Error: Bridge. And I am unable to add any z-wave devices.
I have successfully added other things such as the Sonos binding and thng that don’t depend upon the Z-Stick. Any thoughts of things to try or do you have other info. I should provide you before answering? Thanks. Tim
