First off I’m completely new to OpenHAB so I apologize in advance if this is something simple. First question I have is about using the Insteon Hub as the PLM or the USB 2413U. I purchased a 2413U and added it to my Windows PC (VM). It was installed on COM3 so I edited the insteonplm.cfg file to use that COM port and it was found but it never seemed to discover anything. So i added the HUB2 instead and it found my three devices. Before I go further is it better to use the USB, once i get it working, or use the HUB2? My next question is how do i add these devices to an insteon.items file? Device 3F.E2.11 is a plugin ON/OFF module. So I created a file called insteon.items and added this line.
Plugin OnOffModule “KatrinaPlugin1” {insteonplm=“3F:E2:11:F00.00.1B#OnOff Module”}
And then created a site map called home.sitemap and added the below.
sitemap demo label=“Main Menu” {
Frame label=“Date” {
Text item=Date
Frame label=“Katrina” {
Text label=“Plugin 1” icon=“1stfloor” {
Switch item=OnOffModule
I ran both of these inside of smarthome designer and corrected some errors that it highlighted. But still nothing shows up in OpenHAB paper UI. Not sure what I’m doing wrong. Any help would be greatly appreciated.
2017-02-07 11:14:37.331 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - config: port_0 -> /hub2/xxxxxx:xxxxx@x.x.x.x:25105,poll_time=1000
2017-02-07 11:14:37.336 [INFO ] [b.core.service.AbstractActiveService] - InsteonPLM has been started
2017-02-07 11:14:37.338 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - devices: 0 configured, 0 polling, msgs received: 0
2017-02-07 11:14:37.341 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - config: refresh -> 600000
2017-02-07 11:14:37.342 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - config: service.pid -> org.openhab.insteonplm
2017-02-07 11:14:47.466 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - modem database has 4 entries!
2017-02-07 11:14:47.467 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - device 3F.E2.68 found in the modem database, but is not configured as an item and the modem controls groups [0x00,0x02] and responds to groups [0x01].
2017-02-07 11:14:47.467 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - device 42.05.D1 found in the modem database, but is not configured as an item and the modem controls groups [0x01,0x04] and responds to groups [0x01].
2017-02-07 11:14:47.467 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - device 3F.E2.11 found in the modem database, but is not configured as an item and the modem controls groups [0x00,0x02] and responds to groups [0x01].
2017-02-07 11:23:47.876 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'Insteon.items’
2017-02-07 11:23:57.891 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.sitemap’
2017-02-07 11:24:37.340 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - devices: 0 configured, 0 polling, msgs received: 9
