Trying to add Kwikset Lock and cant get it to secure connect
HI all I have the Zooz ZST10 700 usb zwave dongle on OH 3.1 and i have even tried setting all devices secure inclusion in the zwave settings.
This is my second install at another location and i have gotten this to work before on the same lock model. I can discover the door lock but it never finished. Just the node number and no channels.
When i pull the logs i am getting
17:18:17.818 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY check internal
17:18:17.818 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 3: Command Class COMMAND_CLASS_SECURITY is NOT required to be secured
17:18:17.819 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 3: sendTransaction org.openhab
Is there a way to force Security to be required outside of the zwave bridge settings?
2021-08-28 19:00:59.706 [INFO ] [alization.ZWaveNodeInitStageAdvancer] - NODE 7: SECURITY_INC State=FAILED, Reason=GET_SCHEME
2021-08-28 19:00:59.735 [WARN ] [.serialmessage.ZWaveCommandProcessor] - SerialMessage class null is not implemented!
2021-08-28 19:00:59.736 [WARN ] [.serialmessage.ZWaveCommandProcessor] - SerialMessage class null is not implemented!
2021-08-28 19:00:59.736 [WARN ] [ve.internal.protocol.ZWaveController] - TODO: Implement processing of Request Message = – (0xa8)
2021-08-28 19:01:07.174 [WARN ] [.serialmessage.ZWaveCommandProcessor] - SerialMessage class null is not implemented!
2021-08-28 19:01:07.175 [WARN ] [.serialmessage.ZWaveCommandProcessor] - SerialMessage class null is not implemented!
2021-08-28 19:01:07.175 [WARN ] [ve.internal.protocol.ZWaveController] - TODO: Implement processing of Request Message = – (0xa8)
adding some more logs
One problem is the 700 series dongle is not supported. There are threads in the forum from more authoritative sources. Don’t know if this is causing the secure discovery problem.
Bob
thanks for the heads up… ill pick up another 500 series and see how it goes.
