It’s the third reinstall
No luck with using string instead of number:
How can I start mqtt broker? Reinstalling again mqtt?
please set the log level of the mqtt to trace!
org.openhab.binding.mqtt
org.openhab.io.transport.mqtt
add this to your org.ops4j.pax.logging.cfg
in /var/lib/openhab2/etc
log4j2.logger.mqtt1.name = org.openhab.binding.mqtt
log4j2.logger.mqtt1.level = TRACE
log4j2.logger.mqtt2.name = org.openhab.io.transport.mqtt
log4j2.logger.mqtt2.level = TRACE
or use Karaf console
https://docs.openhab.org/administration/logging.html
2018-03-07 00:51:44.936 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2018-03-07 00:51:54.277 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STOPPING - org.openhab.io.transport.mqtt
2018-03-07 00:51:54.279 [DEBUG] [org.openhab.io.transport.mqtt ] - ServiceEvent UNREGISTERING - {org.openhab.io.transport.mqtt.MqttService, org.osgi.service.cm.ManagedService}={service.pid=org.openhab.mqtt, component.name=MQTT Connection Service, component.id=186, service.id=307, service.bundleid=208, service.scope=bundle} - org.openhab.io.transport.mqtt
2018-03-07 00:51:54.283 [DEBUG] [penhab.io.transport.mqtt.MqttService] - Stopping MQTT Service...
2018-03-07 00:51:54.285 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'mosquitto'
2018-03-07 00:51:54.287 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Closing connection to broker 'mosquitto'
2018-03-07 00:51:54.289 [DEBUG] [penhab.io.transport.mqtt.MqttService] - MQTT Service stopped.
2018-03-07 00:51:54.294 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STOPPED - org.openhab.io.transport.mqtt
2018-03-07 00:51:54.803 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2018-03-07 00:51:54.822 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-03-07 00:51:54.833 [INFO ] [er.internal.HomeBuilderDashboardTile] - Stopped Home Builder
2018-03-07 00:51:54.853 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
2018-03-07 00:52:22.272 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-03-07 00:52:22.957 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.0.108:8080
2018-03-07 00:52:22.969 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.0.108:8443
2018-03-07 00:52:37.748 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'temperatura.items'
2018-03-07 00:52:42.568 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-03-07 00:52:43.140 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'temperatura.sitemap'
2018-03-07 00:52:45.709 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-03-07 00:52:45.795 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-03-07 00:52:45.883 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-03-07 00:52:46.193 [DEBUG] [penhab.io.transport.mqtt.MqttService] - Starting MQTT Service...
2018-03-07 00:52:46.197 [DEBUG] [org.openhab.io.transport.mqtt ] - ServiceEvent REGISTERED - {org.openhab.io.transport.mqtt.MqttService, org.osgi.service.cm.ManagedService}={service.pid=org.openhab.mqtt, component.name=MQTT Connection Service, component.id=186, service.id=307, service.bundleid=208, service.scope=bundle} - org.openhab.io.transport.mqtt
2018-03-07 00:52:46.216 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STARTING - org.openhab.io.transport.mqtt
2018-03-07 00:52:46.221 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STARTED - org.openhab.io.transport.mqtt
2018-03-07 00:52:46.242 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:broker
2018-03-07 00:52:46.244 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:topic
2018-03-07 00:52:46.246 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:message
2018-03-07 00:56:39.645 [DEBUG] [.binding.mqtt.internal.MqttActivator] - MQTT binding has been started.
2018-03-07 00:56:39.697 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler}={event.topics=openhab/*, component.name=org.openhab.binding.mqtt.MqttItemBinding, component.id=191, service.id=316, service.bundleid=212, service.scope=bundle} - org.openhab.binding.mqtt
2018-03-07 00:56:39.700 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.mqtt.MqttBindingProvider}={component.name=org.openhab.binding.mqtt.genericbindingprovider, component.id=192, service.id=315, service.bundleid=212, service.scope=bundle} - org.openhab.binding.mqtt
2018-03-07 00:56:39.713 [TRACE] [.internal.MqttGenericBindingProvider] - Starting to load MQTT config for item Attic_Temperature
2018-03-07 00:56:39.724 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'Attic_Temperature' : 1 subscribers, 0 publishers
2018-03-07 00:56:39.755 [DEBUG] [ng.mqtt.internal.MqttEventBusBinding] - MQTT: Activating event bus binding.
2018-03-07 00:56:39.759 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={event.topics=openhab/*, service.pid=org.openhab.mqtt-eventbus, component.name=org.openhab.binding.mqtt.eventbus, component.id=193, service.id=318, service.bundleid=212, service.scope=bundle} - org.openhab.binding.mqtt
2018-03-07 00:56:39.771 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STARTED - org.openhab.binding.mqtt
2018-03-07 00:56:39.770 [TRACE] [ng.mqtt.internal.MqttEventBusBinding] - No mqtt-eventbus properties configured.
2018-03-07 00:57:37.716 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-airquality'
2018-03-07 00:58:06.951 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2018-03-07 00:58:17.302 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent UNREGISTERING - {org.osgi.service.event.EventHandler}={event.topics=openhab/*, component.name=org.openhab.binding.mqtt.MqttItemBinding, component.id=191, service.id=316, service.bundleid=212, service.scope=bundle} - org.openhab.binding.mqtt
2018-03-07 00:58:17.312 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent UNREGISTERING - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.mqtt.MqttBindingProvider}={component.name=org.openhab.binding.mqtt.genericbindingprovider, component.id=192, service.id=315, service.bundleid=212, service.scope=bundle} - org.openhab.binding.mqtt
2018-03-07 00:58:17.333 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent UNREGISTERING - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={event.topics=openhab/*, service.pid=org.openhab.mqtt-eventbus, component.name=org.openhab.binding.mqtt.eventbus, component.id=193, service.id=318, service.bundleid=212, service.scope=bundle} - org.openhab.binding.mqtt
2018-03-07 00:58:17.344 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STOPPING - org.openhab.binding.mqtt
2018-03-07 00:58:17.346 [DEBUG] [.binding.mqtt.internal.MqttActivator] - MQTT binding has been stopped.
2018-03-07 00:58:17.355 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STOPPED - org.openhab.binding.mqtt
2018-03-07 00:58:17.372 [DEBUG] [org.openhab.io.transport.mqtt ] - ServiceEvent UNREGISTERING - {org.openhab.io.transport.mqtt.MqttService, org.osgi.service.cm.ManagedService}={service.pid=org.openhab.mqtt, component.name=MQTT Connection Service, component.id=186, service.id=307, service.bundleid=208, service.scope=bundle} - org.openhab.io.transport.mqtt
2018-03-07 00:58:17.374 [DEBUG] [penhab.io.transport.mqtt.MqttService] - Stopping MQTT Service...
2018-03-07 00:58:17.376 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'mosquitto'
2018-03-07 00:58:17.379 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Closing connection to broker 'mosquitto'
2018-03-07 00:58:17.380 [DEBUG] [penhab.io.transport.mqtt.MqttService] - MQTT Service stopped.
2018-03-07 00:58:17.384 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STOPPING - org.openhab.io.transport.mqtt
2018-03-07 00:58:17.387 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STOPPED - org.openhab.io.transport.mqtt
2018-03-07 00:58:17.925 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2018-03-07 00:58:17.945 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-03-07 00:58:17.957 [INFO ] [er.internal.HomeBuilderDashboardTile] - Stopped Home Builder
2018-03-07 00:58:17.977 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
2018-03-07 00:58:45.555 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-03-07 00:58:46.373 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.0.108:8080
2018-03-07 00:58:46.379 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.0.108:8443
2018-03-07 00:59:01.032 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'temperatura.items'
2018-03-07 00:59:06.039 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-03-07 00:59:06.644 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'temperatura.sitemap'
2018-03-07 00:59:09.722 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-03-07 00:59:09.810 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-03-07 00:59:09.912 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-03-07 00:59:10.199 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STARTING - org.openhab.io.transport.mqtt
2018-03-07 00:59:10.212 [DEBUG] [org.openhab.io.transport.mqtt ] - ServiceEvent REGISTERED - {org.openhab.io.transport.mqtt.MqttService, org.osgi.service.cm.ManagedService}={service.pid=org.openhab.mqtt, component.name=MQTT Connection Service, component.id=186, service.id=307, service.bundleid=208, service.scope=bundle} - org.openhab.io.transport.mqtt
2018-03-07 00:59:10.227 [DEBUG] [penhab.io.transport.mqtt.MqttService] - Starting MQTT Service...
2018-03-07 00:59:10.252 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STARTED - org.openhab.io.transport.mqtt
2018-03-07 00:59:10.275 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:broker
2018-03-07 00:59:10.279 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:topic
2018-03-07 00:59:10.282 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:message
2018-03-07 00:59:10.300 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STARTING - org.openhab.binding.mqtt
2018-03-07 00:59:10.306 [DEBUG] [.binding.mqtt.internal.MqttActivator] - MQTT binding has been started.
2018-03-07 00:59:10.309 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STARTED - org.openhab.binding.mqtt
2018-03-07 00:59:10.328 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.mqtt.MqttBindingProvider}={component.name=org.openhab.binding.mqtt.genericbindingprovider, component.id=189, service.id=312, service.bundleid=212, service.scope=bundle} - org.openhab.binding.mqtt
2018-03-07 00:59:10.357 [TRACE] [.internal.MqttGenericBindingProvider] - Starting to load MQTT config for item Attic_Temperature
2018-03-07 00:59:10.369 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'Attic_Temperature' : 1 subscribers, 0 publishers
2018-03-07 00:59:10.389 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler}={event.topics=openhab/*, component.name=org.openhab.binding.mqtt.MqttItemBinding, component.id=188, service.id=314, service.bundleid=212, service.scope=bundle} - org.openhab.binding.mqtt
2018-03-07 00:59:10.409 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={event.topics=openhab/*, service.pid=org.openhab.mqtt-eventbus, component.name=org.openhab.binding.mqtt.eventbus, component.id=190, service.id=315, service.bundleid=212, service.scope=bundle} - org.openhab.binding.mqtt
2018-03-07 00:59:10.421 [DEBUG] [ng.mqtt.internal.MqttEventBusBinding] - MQTT: Activating event bus binding.
2018-03-07 00:59:10.431 [TRACE] [ng.mqtt.internal.MqttEventBusBinding] - No mqtt-eventbus properties configured.
Any advice about how to configure the system?
There is no setup and connecting to the broker in your log or you did not post it. Make sure the mqtt.cfg is configured and restart.
