- Platform information:
- Hardware: Helios 4 SoC. CPU: Marvell Armada 380/385 (armv7l), RAM: 2GB, Storage: 7G free on main drive (which is the only one OpenHAB should be using)
- OS: Armbian Buster.
uname -a
:Linux helios4.local 5.10.60-mvebu #21.08.1 SMP Wed Aug 25 18:44:04 UTC 2021 armv7l GNU/Linux
- Java Runtime Environment:
openjdk 11.0.12 2021-07-20
OpenJDK Runtime Environment (build 11.0.12+7-post-Debian-2deb10u1)
OpenJDK Server VM (build 11.0.12+7-post-Debian-2deb10u1, mixed mode)
- openHAB version:
3.1.0-1
- Issue of the topic: please be detailed explaining your issue
I’m trying to connect ZemiSmart blinds via Zigbee, using a HUSBZB-1 (Ember) coordinator. Trying to do so gives me this result:
I’ve confirmed that my coordinator setup works with a Samsung motion sensor, and that the blinds work with their included remote. It looks like it is supported by Zigbee2MQTT (see also blakadder’s compat page), but I’d rather connect it directly to OpenHAB than buy additional hardware. What are my next steps from here?
- Please post configurations (if applicable):
- Items configuration related to the issue
- Zigbee coordinator: Ember coordinator, software flow control, 57600baud, normal ncp config & transmit power, 1 day child timeout, small network size
- If logs where generated please post these here using code fences:
after increasing logging per the instructions,
dump from tail -f /var/log/openhab/openhab.log
when trying to connect it:
2021-10-09 20:47:03.187 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame to receive queue. Queue length 0
2021-10-09 20:47:03.189 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 0
2021-10-09 20:47:03.190 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=7, notRdy=false]
2021-10-09 20:47:04.179 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2021-10-09 20:47:04.181 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=7, ackNum=7, reTx=false, data=14 00 18]
2021-10-09 20:47:04.187 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=7, ackNum=0, reTx=false, data=14 80 18 02]
2021-10-09 20:47:04.189 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=7, ackNum=7, reTx=false, data=14 00 18]
2021-10-09 20:47:04.190 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame to receive queue. Queue length 0
2021-10-09 20:47:04.191 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 0
2021-10-09 20:47:04.193 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=0, notRdy=false]
2021-10-09 20:48:48.491 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B4E3F9FFFE0C5045: Handler dispose.
2021-10-09 20:48:48.493 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker removed for thingUID=zigbee:device:c6b9e12b5d:b4e3f9fffe0c5045
2021-10-09 20:48:53.969 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B4E3F9FFFE0C5045: Initializing ZigBee thing handler zigbee:device:c6b9e12b5d:b4e3f9fffe0c5045
2021-10-09 20:48:53.973 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B4E3F9FFFE0C5045: Coordinator status changed to ONLINE.
2021-10-09 20:48:53.975 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B4E3F9FFFE0C5045: Coordinator is ONLINE. Starting device initialisation.
2021-10-09 20:48:53.981 [DEBUG] [pp.discovery.ZigBeeNetworkDiscoverer] - B4E3F9FFFE0C5045: NWK Discovery starting node rediscovery
2021-10-09 20:48:53.984 [DEBUG] [pp.discovery.ZigBeeNetworkDiscoverer] - B4E3F9FFFE0C5045: NWK Discovery: Rediscovery using unicast to E2B0
2021-10-09 20:48:53.988 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - B4E3F9FFFE0C5045: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=B4E3F9FFFE0C5045 queueTime=0, state=WAITING, sendCnt=0, command=NetworkAddressRequest [0000/0 -> E2B0/0, cluster=0000, TID=--, ieeeAddr=B4E3F9FFFE0C5045, requestType=0, startIndex=0]]
2021-10-09 20:48:53.990 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=0, outstandingQueues=1, sleepy=0/3
2021-10-09 20:48:53.991 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B4E3F9FFFE0C5045: Start initialising ZigBee Thing handler
2021-10-09 20:48:53.993 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - B4E3F9FFFE0C5045: ZigBee node property discovery start
2021-10-09 20:48:53.993 [DEBUG] [transaction.ZigBeeTransactionManager] - E2B0/0: Sending ZigBeeTransaction [ieeeAddress=B4E3F9FFFE0C5045 queueTime=6, state=WAITING, sendCnt=0, command=NetworkAddressRequest [0000/0 -> E2B0/0, cluster=0000, TID=3A, ieeeAddr=B4E3F9FFFE0C5045, requestType=0, startIndex=0]]
2021-10-09 20:48:53.996 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - B4E3F9FFFE0C5045: ZigBee node property discovery using basic cluster on endpoint E2B0/1
2021-10-09 20:48:54.000 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2021-10-09 20:48:54.001 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - B4E3F9FFFE0C5045: ZigBee node property discovery using OTA cluster on endpoint E2B0/1
2021-10-09 20:48:54.003 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: NetworkAddressRequest [0000/0 -> E2B0/0, cluster=0000, TID=3A, ieeeAddr=B4E3F9FFFE0C5045, requestType=0, startIndex=0]
2021-10-09 20:48:54.005 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=E2B0/0, profile=0000, cluster=0000, addressMode=DEVICE, radius=8, apsSecurity=false, ackRequest=true, apsCounter=63, rssi=--, lqi=--, payload=3A 45 50 0C FE FF F9 E3 B4 00 00]
2021-10-09 20:48:54.008 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - B4E3F9FFFE0C5045: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=B4E3F9FFFE0C5045 queueTime=0, state=WAITING, sendCnt=0, command=ReadAttributesCommand [Ota Upgrade: 0000/0 -> E2B0/1, cluster=0019, TID=--, identifiers=[2]]]
2021-10-09 20:48:54.010 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=1, outstandingQueues=1, sleepy=0/3
2021-10-09 20:48:54.021 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=80]
2021-10-09 20:48:54.043 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=1, outstandingQueues=1, sleepy=0/3
2021-10-09 20:48:54.043 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteRecordHandler [networkId=0, source=E2B0, sourceEui=B4E3F9FFFE0C5045, lastHopLqi=255, lastHopRssi=-51, relayList=]
2021-10-09 20:48:54.045 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteRecordHandler [networkId=0, source=E2B0, sourceEui=B4E3F9FFFE0C5045, lastHopLqi=255, lastHopRssi=-51, relayList=]
2021-10-09 20:48:54.095 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0000, clusterId=8000, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=63], lastHopLqi=255, lastHopRssi=-51, sender=E2B0, bindingIndex=255, addressIndex=255, messageContents=3A 00 45 50 0C FE FF F9 E3 B4 B0 E2]
2021-10-09 20:48:54.098 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=E2B0/0, destinationAddress=0000/0, profile=0000, cluster=8000, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=63, rssi=-51, lqi=FF, payload=3A 00 45 50 0C FE FF F9 E3 B4 B0 E2]
2021-10-09 20:48:54.100 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - B4E3F9FFFE0C5045: Node update. NWK Address=E2B0
2021-10-09 20:48:54.102 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - B4E3F9FFFE0C5045: Node E2B0 is not updated
2021-10-09 20:48:54.104 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: NetworkAddressResponse [E2B0/0 -> 0000/0, cluster=8000, TID=3A, status=SUCCESS, ieeeAddrRemoteDev=B4E3F9FFFE0C5045, nwkAddrRemoteDev=E2B0, startIndex=null, nwkAddrAssocDevList=[]]
2021-10-09 20:48:54.106 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: NetworkAddressResponse [E2B0/0 -> 0000/0, cluster=8000, TID=3A, status=SUCCESS, ieeeAddrRemoteDev=B4E3F9FFFE0C5045, nwkAddrRemoteDev=E2B0, startIndex=null, nwkAddrAssocDevList=[]]
2021-10-09 20:48:54.109 [DEBUG] [pp.discovery.ZigBeeNetworkDiscoverer] - B4E3F9FFFE0C5045: NWK Discovery NetworkAddressRequest returned from NetworkAddressResponse [E2B0/0 -> 0000/0, cluster=8000, TID=3A, status=SUCCESS, ieeeAddrRemoteDev=B4E3F9FFFE0C5045, nwkAddrRemoteDev=E2B0, startIndex=null, nwkAddrAssocDevList=[]]
2021-10-09 20:48:54.109 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=B4E3F9FFFE0C5045 queueTime=122, state=COMPLETE, sendCnt=1, command=NetworkAddressRequest [0000/0 -> E2B0/0, cluster=0000, TID=3A, ieeeAddr=B4E3F9FFFE0C5045, requestType=0, startIndex=0]]
2021-10-09 20:48:54.111 [DEBUG] [pp.discovery.ZigBeeNetworkDiscoverer] - B4E3F9FFFE0C5045: NWK Discovery: Rediscovery found network address to E2B0
2021-10-09 20:48:54.111 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2021-10-09 20:48:54.113 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - B4E3F9FFFE0C5045: transactionComplete, state=COMPLETE, outstanding=0
2021-10-09 20:48:54.114 [DEBUG] [pp.discovery.ZigBeeNetworkDiscoverer] - B4E3F9FFFE0C5045: NWK Discovery add node E2B0
2021-10-09 20:48:54.114 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=0, outstandingQueues=1, sleepy=0/3
2021-10-09 20:48:54.116 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - B4E3F9FFFE0C5045: Updating node NWK=E2B0
2021-10-09 20:48:54.116 [DEBUG] [transaction.ZigBeeTransactionManager] - E2B0/1: Sending ZigBeeTransaction [ieeeAddress=B4E3F9FFFE0C5045 queueTime=109, state=WAITING, sendCnt=0, command=ReadAttributesCommand [Ota Upgrade: 0000/0 -> E2B0/1, cluster=0019, TID=3B, identifiers=[2]]]
2021-10-09 20:48:54.118 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_DIRECT, indexOrDestination=E2B0, apsFrame=EmberApsFrame [profileId=0000, clusterId=0000, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=80], messageTag=3A, status=EMBER_SUCCESS, messageContents=]
2021-10-09 20:48:54.119 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2021-10-09 20:48:54.120 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=3A state=RX_ACK
2021-10-09 20:48:54.121 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=3A, state=RX_ACK, outstanding=1
2021-10-09 20:48:54.121 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - B4E3F9FFFE0C5045: Node update. NWK Address=E2B0
2021-10-09 20:48:54.123 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ReadAttributesCommand [Ota Upgrade: 0000/0 -> E2B0/1, cluster=0019, TID=3B, identifiers=[2]]
2021-10-09 20:48:54.125 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=59, commandId=0]
2021-10-09 20:48:54.126 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - B4E3F9FFFE0C5045: Node E2B0 is not updated
2021-10-09 20:48:54.127 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=E2B0/1, profile=0104, cluster=0019, addressMode=DEVICE, radius=8, apsSecurity=false, ackRequest=true, apsCounter=64, rssi=--, lqi=--, payload=08 3B 00 02 00]
2021-10-09 20:48:54.139 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=81]
2021-10-09 20:48:54.161 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteRecordHandler [networkId=0, source=E2B0, sourceEui=B4E3F9FFFE0C5045, lastHopLqi=255, lastHopRssi=-51, relayList=]
2021-10-09 20:48:54.163 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteRecordHandler [networkId=0, source=E2B0, sourceEui=B4E3F9FFFE0C5045, lastHopLqi=255, lastHopRssi=-51, relayList=]
2021-10-09 20:48:54.212 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0104, clusterId=0019, sourceEndpoint=1, destinationEndpoint=1, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=64], lastHopLqi=255, lastHopRssi=-51, sender=E2B0, bindingIndex=255, addressIndex=255, messageContents=10 3B 01 02 00 86]
2021-10-09 20:48:54.214 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=E2B0/1, destinationAddress=0000/1, profile=0104, cluster=0019, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=64, rssi=-51, lqi=FF, payload=10 3B 01 02 00 86]
2021-10-09 20:48:54.216 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - B4E3F9FFFE0C5045: Node update. NWK Address=E2B0
2021-10-09 20:48:54.218 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - B4E3F9FFFE0C5045: Node E2B0 is not updated
2021-10-09 20:48:54.220 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=59, commandId=1]
2021-10-09 20:48:54.222 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ReadAttributesResponse [Ota Upgrade: E2B0/1 -> 0000/1, cluster=0019, TID=3B, records=[ReadAttributeStatusRecord [status=UNSUPPORTED_ATTRIBUTE, attributeIdentifier=2]]]
2021-10-09 20:48:54.224 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: ReadAttributesResponse [Ota Upgrade: E2B0/1 -> 0000/1, cluster=0019, TID=3B, records=[ReadAttributeStatusRecord [status=UNSUPPORTED_ATTRIBUTE, attributeIdentifier=2]]]
2021-10-09 20:48:54.226 [DEBUG] [.zsmartsystems.zigbee.zcl.retsulClcZ] - E2B0/1: Error reading client attribute 2 in cluster 25 - UNSUPPORTED_ATTRIBUTE
2021-10-09 20:48:54.228 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - B4E3F9FFFE0C5045: Could not get OTA firmware version from device
2021-10-09 20:48:54.228 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=B4E3F9FFFE0C5045 queueTime=220, state=COMPLETE, sendCnt=1, command=ReadAttributesCommand [Ota Upgrade: 0000/0 -> E2B0/1, cluster=0019, TID=3B, identifiers=[2]]]
2021-10-09 20:48:54.229 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2021-10-09 20:48:54.230 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - B4E3F9FFFE0C5045: ZigBee node property discovery complete: {zigbee_logicaltype=ROUTER, zigbee_powerlevel=FULL, zigbee_manufacturercode=0x1002, modelId=TS0601, zigbee_networkaddress=58032, zigbee_powersource=MAINS, zigbee_stkversion=0, zigbee_datecode=, zigbee_zclversion=3, vendor=_TZE200_xaabybja, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[MAINS], hardwareVersion=1, zigbee_applicationVersion=82, zigbee_device_initialised=true}
2021-10-09 20:48:54.231 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - B4E3F9FFFE0C5045: transactionComplete, state=COMPLETE, outstanding=0
2021-10-09 20:48:54.233 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=0, outstandingQueues=0, sleepy=0/3
2021-10-09 20:48:54.236 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_DIRECT, indexOrDestination=E2B0, apsFrame=EmberApsFrame [profileId=0104, clusterId=0019, sourceEndpoint=1, destinationEndpoint=1, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=81], messageTag=3B, status=EMBER_SUCCESS, messageContents=]
2021-10-09 20:48:54.238 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=3B state=RX_ACK
2021-10-09 20:48:54.238 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B4E3F9FFFE0C5045: Checking endpoint 1 channels
2021-10-09 20:48:54.240 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=3B, state=RX_ACK, outstanding=0
2021-10-09 20:48:54.247 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B4E3F9FFFE0C5045: Dynamically created 0 channels
2021-10-09 20:48:54.250 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B4E3F9FFFE0C5045: Device initialization will be skipped as the device is already initialized
2021-10-09 20:48:54.253 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B4E3F9FFFE0C5045: Channel initialisation complete
2021-10-09 20:48:54.255 [WARN ] [ng.zigbee.handler.ZigBeeThingHandler] - B4E3F9FFFE0C5045: No supported clusters found
