Trying to extract furnace runtime
Hello all,
Trying to figure out how to return/display the furnace runtime.
I’ve added a call to the furnace in my http binding:
http:tstat2.url=http://192.168.224.50/tstat/datalog
http:tstat2.updateInterval=3600000
And then I created an item to display the entire string returned.
String Tstat2_Ystrdy “Yesterday runtime [%s]” { http="<[tstat2:600000:JSONPATH($.yesterday)]" }
And then this in my sitemap:
Text item=Tstat2_Ystrdy
And it returns the data as expected:
But what I’d like to get it to look like is:
Yesterday runtime 3hrs, 21min
How do I parse the string and format it like that?
Use JS(yesterdayRuntime.js) instead of JSONPATH. Make transform/yesterdayRuntime.js:
(function(json) {
  var datalog = JSON.parse(json);
  return "Yesterday runtime " + datalog.yesterday.heat_runtime.hour + "hrs, " +
    datalog.yesterday.heat_runtime.minute + "min";
})(input)
Thanks for that, but where do I put it???
Unfortunately you’re talking above my head…
You would create a text file named yesterdayRuntime.js in the /etc/openhab/configurations/transform directory on your openHAB server (assuming you installed openHAB via the official apt-get instructions; otherwise, wherever your transform directory is on your installation). The file would contain:
(function(json) {
  return "" + datalog.yesterday.heat_runtime.hour + "hrs, " +
})(input)
You would then change your Tstat2_Ystrdy item configuration to look like this:
String Tstat2_Ystrdy "Yesterday runtime [%s]" { http="<[tstat2:600000:JS(yesterdayRuntime.js)]" }
That makes sense and work perfectly! Appreciate the lesson today.
Have a Merry Christmas and Happy New Year!
