Hi - I am running 3.1M3 on a RaspberryPi installed via openhabian.
I’ve gone back and forth with Jython and HabAPP with the intent on trying to retire my DSL rules and move some external python scripts into a more managed environment.
I installed HabAPP through openhabian-config, and I can get the ‘that was easy’ rule outputting to the console of my server running interactively:
/opt/habapp/bin/habapp -c /etc/openhab/habapp
But I can’t get either of the first two samples that interact with a real OpenHAB item to either respond to a change or state that the item is constant.
If I look at the logs, I see that it has connected to the bus successfully and it looks like it doesn’t like that I’m using a string item from OH instead of a HABApp item so clearly I don’t understand how it is really supposed to read items from OH. What am I missing.
[2021-04-05 21:24:25,595] [ HABApp.Rules] ERROR | cls = <class 'HABApp.core.items.item.Item'>
[2021-04-05 21:24:25,595] [ HABApp.Rules] ERROR | name = 'T_TestString'
[2021-04-05 21:24:25,595] [ HABApp.Rules] ERROR | initial_value = None
[2021-04-05 21:24:25,595] [ HABApp.Rules] ERROR | HABApp.core.Items.ItemNotFoundException = <class 'HABApp.core.Items.ItemNotFoundException'>
[2021-04-05 21:24:25,595] [ HABApp.Rules] ERROR | item = <StringItem name: T_TestString, value: 98, last_change: 2021-04-05 21:24:05.940186, last_update: 2021-04-05 21:24:05.940186>
[2021-04-05 21:24:25,596] [ HABApp.Rules] ERROR | HABApp.core.Items.add_item = <function 'add_item' Items.py:46>
[2021-04-05 21:24:25,596] [ HABApp.Rules] ERROR | ..................................................
[2021-04-05 21:24:25,596] [ HABApp.Rules] ERROR | ---- (full traceback above) ----
[2021-04-05 21:24:25,596] [ HABApp.Rules] ERROR | File "/opt/habapp/lib/python3.7/site-packages/HABApp/rule_manager/rule_file.py", line 79, in load
[2021-04-05 21:24:25,597] [ HABApp.Rules] ERROR | self.create_rules(created_rules)
[2021-04-05 21:24:25,597] [ HABApp.Rules] ERROR | File "/opt/habapp/lib/python3.7/site-packages/HABApp/rule_manager/rule_file.py", line 68, in create_rules
[2021-04-05 21:24:25,597] [ HABApp.Rules] ERROR | '__HABAPP__RULES': created_rules,
[2021-04-05 21:24:25,597] [ HABApp.Rules] ERROR | File "/usr/lib/python3.7/runpy.py", line 263, in run_path
[2021-04-05 21:24:25,597] [ HABApp.Rules] ERROR | pkg_name=pkg_name, script_name=fname)
[2021-04-05 21:24:25,598] [ HABApp.Rules] ERROR | File "/usr/lib/python3.7/runpy.py", line 96, in _run_module_code
[2021-04-05 21:24:25,598] [ HABApp.Rules] ERROR | mod_name, mod_spec, pkg_name, script_name)
[2021-04-05 21:24:25,598] [ HABApp.Rules] ERROR | File "/usr/lib/python3.7/runpy.py", line 85, in _run_code
[2021-04-05 21:24:25,598] [ HABApp.Rules] ERROR | exec(code, run_globals)
[2021-04-05 21:24:25,599] [ HABApp.Rules] ERROR | File "/etc/openhab/habapp/rules/test.py", line 31, in test.py
[2021-04-05 21:24:25,599] [ HABApp.Rules] ERROR | MyFirstRule()
[2021-04-05 21:24:25,599] [ HABApp.Rules] ERROR | File "/etc/openhab/habapp/rules/test.py", line 10, in __init__
[2021-04-05 21:24:25,599] [ HABApp.Rules] ERROR | self.my_item = Item.get_create_item('T_TestString')
[2021-04-05 21:24:25,599] [ HABApp.Rules] ERROR | File "/opt/habapp/lib/python3.7/site-packages/HABApp/core/items/item.py", line 24, in get_create_item
[2021-04-05 21:24:25,600] [ HABApp.Rules] ERROR | assert isinstance(item, cls), f'{cls} != {type(item)}'
[2021-04-05 21:24:25,600] [ HABApp.Rules] ERROR | AssertionError: <class 'HABApp.core.items.item.Item'> != <class 'HABApp.openhab.items.string_item.StringItem'>
[2021-04-05 21:24:25,600] [ HABApp.Rules] WARNING | Failed to load /etc/openhab/habapp/rules/test.py!
