I will give up. Actually I have the problem that the timer switches the coffee maker after a random time off, but inside the time range of the set timer value. To reduce the failure possibilities I simplify the rule to:
rule "Kaffeemaschine auto off"
Item Wallplug1_Switch changed
if (Wallplug1_Switch.state==OFF) {
myTimer_Kaffeemaschine.cancel
myTimer_Kaffeemaschine = null
logInfo("rules","Timer Kaffeemaschine cancelled")
else if (Wallplug1_Switch.state==ON) {
logInfo("rules","Timer Kaffeemaschine start and set to: "+minutes_auto_off_kaffee.state+" minutes")}
myTimer_Kaffeemaschine = createTimer(now.plusMinutes((minutes_auto_off_kaffee.state as DecimalType).intValue)) [|
sendCommand(Wallplug1_Switch, OFF)
But the problem still exists. Sometimes it happens, that the log shows a state change, but the reale plug doesn’t change the state, but I don’ t have any connection issues with the z-wave plug. Every second or third try the timer operates correct.
Actually I have no imports inside my rules file.
Can somebody help me please!
