I turned on the zwave debugging previously in trying to troubleshoot some issues recently, and Chis is amazing for for his help and patience with everything.
But how to turn off debugging? I have stopped and restarted OH2, and each time, it continues with all of the Debug entries.
Thanks Russell. So just to confirm, you basically set the logging level back to INFO?
Also, is there any way to access the Karaf Console when OH2 is already running as a service? It seems having to stop OH2, then restart it manually to access the Console to enable logging seems counterproductive.
You then may often be stopping OH2 again after setting the DEBUG logging to only restart as a service
