Hi All,
recently we got our house with mainly Eltako actuators(FAM14 - F4SR14-LED - F4HK14 - FSB14). I’m using USB300 and so far I was able to do the pairing(learning stuff). I have the bridge also one Switching/Dimming Actuator configured. I’m able to turn on the light with the switch however the turn off action do nothing. I checked the logs and for turning on I see this:
[INFO ] [openhab.event.ItemCommandEvent ] - Item ‘SwitchingDimmingActuator_Switch’ received command ON
[INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘SwitchingDimmingActuator_Switch’ predicted to become ON
however I get nothing when I turn off it. I also checked the FAM14 with PCT and there is no signal there as well(using detection)
For bridge I use ESP3. Here is the config for switch:
UID: enocean:centralCommand:xyz
label: Switching/Dimming Actuator
thingTypeUID: enocean:centralCommand
configuration:
enoceanId: xyz
senderIdOffset: 1
suppressRepeating: false
sendingEEPId: A5_38_08_01
receivingEEPId: F6_00_00
broadcastMessages: true
bridgeUID: enocean:bridge:xyz
If I use Dimming (A5_38_08_02) I can turn it off at point 0 however the dimming is not really working (it only works at 100 or 0.
Q1. Can I still configure it in the way that it behaves like ON and OFF?
Q2. Why dimming functionality is not working when I set the lvl to something between 0 to 100?
many thanks in advance for the help
Hamid
- Platform information:
- Hardware: raspberry pi 3
- OS: openhabian
- openHAB version: 3
