I’m using OpenHab 2 together with Homegear to control my MAX! devices via CUL, as there is no working MAXCUL Binding for OpenHab 2.
This setup was working fine so far. I was using a simple hysteresis for controlling the heater. To turn off/on the radiator vents, I used the values 4.5 and 30.5 as parameter for the SendCommand instruction. But I updated the system a few days ago and this values are no longer accepted by Homegear (I guess it is Homegear).
Can anyone please tell me how to set the MAX! radiator thermostats to “ON” or “OFF”?
Thank you for your reply. It was liks this in past, 4.5°C for “OFF” and 30.5°C for “ON”, but unfortunately this has been changed. Could be the Homeatic Binding or Homegear. I can’t find any documentation about it.
I think I found the solution. I use a MAX!Cube, which is flashed with culfw. Homegear is my bridge between OH2 and the device.
When I tried to change the temperature (from 5.0°C to 4.5°C, it din’t work. Instead it went back to 5.0°C:
2019-10-16 21:50:33.257 [ome.event.ItemCommandEvent] - Item 'wr_set' received command 4.5
2019-10-16 21:50:33.261 [nt.ItemStatePredictedEvent] - wr_set predicted to become 4.5
2019-10-16 21:50:33.263 [vent.ItemStateChangedEvent] - wr_set changed from 5.00 to 4.5
2019-10-16 21:50:34.504 [vent.ItemStateChangedEvent] - wr_set changed from 4.5 to 5.00
So it seems homegear isn’t accepting the command. I Googled around w/o success. Then I searched in the homegear configuration files. This is what I found. In the directory
/etc/homegear/devices/4
there are XML definitions for the supported MAX! devices. The BC-RT-TRX… are the different types of thermostates:
That is what did the trick. Restart homegear service, and you can switch the MAX! thermostate to OFF!
2019-10-16 21:55:51.081 [ome.event.ItemCommandEvent] - Item 'wr_set' received command 4.5
2019-10-16 21:55:51.087 [nt.ItemStatePredictedEvent] - wr_set predicted to become 4.5
2019-10-16 21:55:51.088 [vent.ItemStateChangedEvent] - wr_set changed from 5.00 to 4.5
2019-10-16 21:55:52.361 [vent.ItemStateChangedEvent] - homematic_HG_BC_RT_TRX_CyG_9d3f5b39_KEQ0406314_1_SET_TEMPERATURE changed from 5.00 °C to 4.50 °C
