Tuya device not being properly recognized in the binding? Modification needed in the Tuya Binding maybe?
I am trying this device which connects perfectly fine with Tuya and was easily discovered in OH.
Problem is, the Thing added now reports:
HANDLER_INITIALIZING_ERROR
A unit hint must not be set if the item type is not a number with dimension!
I’ve even tried to add it manually, by adding a Generic Tuya device and inserting all necessary data, but unfortunately it gives me the exact message.
Any suggestion on how I can “override” this somehow?
While using the Tuya IoT Platform, I can see for this device this information regarding the Standard Status Set:
temp_current	Integer
  "unit": "℃",
  "min": -550,
  "max": 1250,
  "scale": 1,
  "step": 1
humidity_value	Integer
  "unit": "%",
  "min": 0,
  "max": 1000,
  "scale": 1,
  "step": 1
battery_state	Enum
  "range": [
    "low",
    "middle",
    "high"
charge_state	Boolean
"{true,false}"
temp_unit_convert	Enum
  "range": [
    "c",
    "f"
maxtemp_set	Integer
  "unit": "℃",
  "min": -550,
  "max": 1250,
  "scale": 1,
  "step": 1
minitemp_set	Integer
  "unit": "℃",
  "min": -550,
  "max": 1250,
  "scale": 1,
  "step": 1
maxhum_set	Integer
  "unit": "%",
  "min": 0,
  "max": 1000,
  "scale": 1,
  "step": 1
minihum_set	Integer
  "unit": "%",
  "min": 0,
  "max": 1000,
  "scale": 1,
  "step": 1
temp_alarm	Enum
  "range": [
    "loweralarm",
    "upperalarm",
    "cancel"
hum_alarm	Enum
  "range": [
    "loweralarm",
    "upperalarm",
    "cancel"
bright_value	Integer
  "unit": "%",
  "min": 0,
  "max": 100,
  "scale": 0,
  "step": 1
temp_periodic_report	Integer
  "unit": "秒",
  "min": 30,
  "max": 3600,
  "scale": 0,
  "step": 1
switch	Boolean
"{true,false}"
temp_calibration	Integer
  "unit": "℃",
  "min": -30,
  "max": 30,
  "scale": 1,
  "step": 1
hum_calibration	Integer
  "unit": "%",
  "min": -200,
  "max": 200,
  "scale": 1,
  "step": 1
alarm_time	Integer
  "unit": "秒",
  "min": 1,
  "max": 3600,
  "scale": 0,
  "step": 1
beep	Boolean
"{true,false}"
I can also see the Standard Instruction Set:
  "range": [
    "c",
    "f"
maxtemp_set	Integer
  "unit": "℃",
  "min": -550,
  "max": 1250,
  "scale": 1,
  "step": 1
  "unit": "℃",
  "min": -550,
  "max": 1250,
  "scale": 1,
  "step": 1
maxhum_set	Integer
  "unit": "%",
  "min": 0,
  "max": 1000,
  "scale": 1,
  "step": 1
minihum_set	Integer
  "unit": "%",
  "min": 0,
  "max": 1000,
  "scale": 1,
  "step": 1
  "unit": "秒",
  "min": 30,
  "max": 3600,
  "scale": 0,
  "step": 1
switch	Boolean
"{true,false}"
  "unit": "℃",
  "min": -30,
  "max": 30,
  "scale": 1,
  "step": 1
  "unit": "%",
  "min": -200,
  "max": 200,
  "scale": 1,
  "step": 1
alarm_time	Integer
  "unit": "秒",
  "min": 1,
  "max": 3600,
  "scale": 0,
  "step": 1
beep	Boolean
"{true,false}"
In the JSON editor, I have these options:
    "code": "temp_unit_convert",
    "value": "c"
    "code": "maxtemp_set",
    "value": 1250
    "code": "minitemp_set",
    "value": -400
    "code": "maxhum_set",
    "value": 1000
    "code": "minihum_set",
    "value": 0
    "code": "temp_periodic_report",
    "value": 60
    "code": "switch",
    "value": true
    "code": "temp_calibration",
    "value": 0
    "code": "hum_calibration",
    "value": 0
    "code": "alarm_time",
    "value": 15
    "code": "beep",
    "value": true
Product name appears like so: (停产)WIFI温湿度报警器
If any other information might be needed in order to fix the binding, please let me know so I can pass that and make it work properly.
Thank you very much!
Open an issue not a thread. And check the logs. There’s likely to be an entry “Channel … has unit … but openHAB doesn’t know the dimension” or “Unknown unit from pattern …”.
Although the current Tuya binding should convert both the Chinese for seconds and the single-glyph degrees Celsius to something the openHAB core understands so be sure to provide version numbers too.
I have the same problem and opened an issue.
I was just about to open an issue. I will post more information in there regarding my device.
EDIT: For future reference, this is the issue.
EDIT2: Problem solved here.
Hi Pedro,
Did you also unload the official Tuya binding and put the jar in the addons and noticed the netty features were missing?
I have put the missing netty jars also in the addons folder to get it resolved.
What did you do to get it to work?
I first uninstalled the binding, then went to openhab console via terminal and installed the binding from there, starting it in the end and that’s it, it just worked. :slight_smile:
Aha. You probably had another binding which installed the netty bundles. After removing the official Tuya binding my Netty bundles were gone. That why I had to reinstall the Netty bundles using jars.
Did you already install the Milestone version where the repaired binding was merged into?
