Tuya Devices constantly toggle between ONLINE and ONLINE: Waiting for device wake up after update to openHAB 5.1.0
Hi everyone,
I’m experiencing a serious issue with the Tuya Binding after upgrading from openHAB 5.0.3 to 5.1.0.
After the upgrade, all Tuya Things start constantly toggling between:
ONLINE
and
This happens every 1–2 seconds and continues indefinitely. During this time, the Things are not usable at all.
Example log output:
[INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘tuya:tuyaDevice:XXXXXXXXXXXX’ changed from ONLINE to ONLINE: Waiting for device wake up
[INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘tuya:tuyaDevice:XXXXXXXXXXXX’ changed from ONLINE: Waiting for device wake up to ONLINE
No configuration changes were made besides the openHAB upgrade.
Important finding:
I downgraded back to openHAB 5.0.3, and immediately everything started working again without any changes.
So this looks like a clear regression introduced in openHAB 5.1.0.
System details (working state – 5.0.3):
  • openHAB version: 5.0.3 (Release Build)
  • Java:
    • Version: 21.0.9
    • Vendor: Eclipse Adoptium (Temurin)
  • OS:
    • Linux 6.12.47+rpt-rpi-2712
    • Architecture: aarch64
    • Hardware: Raspberry Pi
  • Tuya Binding:
    • binding-tuya (official)
  • Locale: en-DE
Installed addons include (excerpt):
  • binding-tuya
  • binding-mqtt
  • binding-http
  • binding-miio
  • misc-homekit
  • voice-picotts
  • persistence-influxdb
All Tuya devices are online and working normally in the Tuya app.
This issue affects all Tuya Things, not just a single device.
As soon as I upgrade to 5.1.0 again, the ONLINE / Waiting for device wake up loop starts immediately.
Has anyone else seen this with openHAB 5.1.0?
Is this a known issue or already tracked somewhere?
Thanks!
@mjagdis - FYI
It seems likely to be related to:
So should I raise a ticket there?
The Tuya binding is an important part for me. Thanks for pointing this out. I think I should wait and will not update to 5.1.0 now.
I have just updated without any issue. Was concerned when i saw this but tested and all ok.
Thank you for the feedback! Let me clarify my specific setup where I experienced the issues:
Device Details
Problematic devices (constantly cycling ONLINE ↔ “Waiting for device wake up” in 5.1.0):
∙ 3x Guirled LED String Lights (mains powered, not battery)
∙ 2x Create ceiling fans (mains powered)
All devices:
∙ Connected via SmartLife app (Cloud integration via Tuya IoT Platform)
∙ Protocol: 3.1 (fans) and 3.3 (string lights)
∙ Configuration: Local IP addresses set, localKeys configured
Tried the update. All Tuya devices became online and stayed online. Nevertheless, it seems that some channels changed. I have to investigate further. But not today.
Merry Christmas
Harald
@Mark_VG and @Harald_Pott may I ask which devices you are using and if you initial used the tuya App or the smart life app?
I used the Tuya App and just have a light configured.
Using both apps. Three devices: a motor for a blind, a heater and a clock.
Just raised an issue here:
ONLINE on its own means the binding has a connection to the device. ONLINE - waiting for device means the binding does not have a connection to the device. (No, that’s not the same as OFFLINE.)
If devices are bouncing between states that implies the binding is constantly connecting and disconnecting. In previous versions I don’t think this was visible at the UI.
Enable trace logging to capture what is actually happening from the binding’s perspective.
Note that Tuya devices are generally limited to something like 3 simultaneous connections so you generally have to make a choice between using openHAB (or Home Assistant, or …) or the Tuya app(s) otherwise you will get frequent disconnects.
@Anpro What do you mean, “During this time the Things are not usable at all?”. If there’s no device connection there’ll be no updates (the binding is local-only, it doesn’t ask the Tuya cloud). Nor will commands to the device work - there’s no queuing in the binding and commands are just dropped if there’s no connection to send them on.
@mjagdis Thank you for the explanation!
Clarification on Usage
To be precise: I only use openHAB for controlling these devices in production. I do have Home Assistant running, but only for two integrations completely unrelated to Tuya.
The devices are normally on an isolated IoT subnet (192.168.20.x) with no internet access. I only temporarily moved them to the main network to test whether they were still controllable via the SmartLife app - they were. But in production, only openHAB connects to them.
“Not usable” clarification
By “during this time the Things are not usable at all” I meant: While running openHAB 5.1.0, the devices:
  • Did not accept any commands sent from openHAB
  • Did not report any status updates to openHAB
Even though they were cycling ONLINE ↔ “Waiting for device wake up” every second, they were effectively non-functional from openHAB’s perspective.
Trace Logging
I understand you need trace logs to see what’s happening. However, I’ll need to upgrade back to 5.1.0 to capture these logs, which I can only do after the holidays (I have only this one production installation and don’t want family issues over Christmas :wink:).
I’ll provide detailed trace logs as soon as possible. Just to confirm - to enable trace logging for the Tuya binding, I would use:
log:set TRACE org.openhab.binding.tuya
Correct?
Question
Is there anything specific in the logs you’re looking for, or should I just capture the full trace output during device connection/disconnection cycles?
Merry Christmas!
That’s right. Or you can set TRACE via the UI if you go to the Tuya binding in add-ons and click the gear icon.
It might be worth grabbing a trace from 5.0.3 as well. Partly to see if that is bouncing silently and partly to compare with 5.1. It may even be sufficient on its own but I can’t remember how effective the trace logging was in 5.0.
ok maybe this already helps:
2025-12-24 15:04:56.706 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Received encoded '000055AA0000000000000023000000BC...[ENCRYPTED]...0000AA55'
2025-12-24 15:04:56.706 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Protocol version '3.1'
2025-12-24 15:04:56.706 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Decoded raw payload: [HEX DATA]
2025-12-24 15:04:56.707 [DEBUG] [.internal.local.handlers.TuyaDecoder] - udpListener: Received MessageWrapper{commandType=BROADCAST_LPV34, content='DiscoveryMessage{ip='192.168.1.220', deviceId='bf04f6821e15db0a4arkij', active=2, ability=0, mode=0, encrypt=true, productKey='p8z27***', version='3.4', token=true, wf_cfg=true}'}
2025-12-24 15:04:56.814 [DEBUG] [.internal.local.handlers.TuyaDecoder] - udpListener: Received MessageWrapper{commandType=BROADCAST_LPV34, content='DiscoveryMessage{ip='192.168.1.12', deviceId='bf3e12bb0d710bc6ffgaja', active=2, ability=0, mode=0, encrypt=true, productKey='ifj19h***', version='3.4', token=true, wf_cfg=true}'}
2025-12-24 15:04:57.924 [TRACE] [rnal.local.handlers.HeartbeatHandler] - bf3e12bb0d710bc6ffgaja/192.168.1.12:6668: Sending ping
2025-12-24 15:04:57.925 [DEBUG] [.internal.local.handlers.TuyaEncoder] - bf3e12bb0d710bc6ffgaja/192.168.1.12:6668: Sending HEART_BEAT, payload {protocol=5, t=1766585097, data={ctype=0, dps=, cid=bf3e12bb0d710bc6ffgaja}}
2025-12-24 15:04:57.937 [DEBUG] [.internal.local.handlers.TuyaDecoder] - bf3e12bb0d710bc6ffgaja/192.168.1.12:6668: Received MessageWrapper{commandType=HEART_BEAT, content='[B@55d5ae60'}
2025-12-24 15:04:57.937 [TRACE] [rnal.local.handlers.HeartbeatHandler] - bf3e12bb0d710bc6ffgaja/192.168.1.12:6668: Received pong
2025-12-24 15:04:58.938 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending DP_REFRESH, payload {devId=41014556483fda1c6101, uid=41014556483fda1c6101, t=1766585098, dpId=[3, 1], gwId=41014556483fda1c6101}
2025-12-24 15:04:58.938 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_REFRESH, payload {devId=310002588caab562aee4, uid=310002588caab562aee4, t=1766585098, dpId=[3, 1], gwId=310002588caab562aee4}
2025-12-24 15:04:58.991 [DEBUG] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Received MessageWrapper{commandType=DP_QUERY, content='TcpStatusPayload{protocol=-1, devId='41014556483fda1c6101', gwId='', uid='', t=0, dps={1=false, 3=28.0}, data=Data{dps={}}}'}
2025-12-24 15:04:58.991 [TRACE] [a.internal.handler.TuyaDeviceHandler] - 'tuya:tuyaDevice:41014556483fda1c6101' received status message '{1=false, 3=28.0}'
2025-12-24 15:04:58.992 [DEBUG] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Received MessageWrapper{commandType=DP_QUERY, content='TcpStatusPayload{protocol=-1, devId='310002588caab562aee4', gwId='', uid='', t=0, dps={1=false, 3=28.0}, data=Data{dps={}}}'}
2025-12-24 15:04:58.992 [TRACE] [a.internal.handler.TuyaDeviceHandler] - 'tuya:tuyaDevice:310002588caab562aee4' received status message '{1=false, 3=28.0}'
2025-12-24 15:04:59.104 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending DP_REFRESH, payload {devId=41014556483fda1cee4e, uid=41014556483fda1cee4e, t=1766585099, dpId=[3, 1], gwId=41014556483fda1cee4e}
2025-12-24 15:04:59.312 [DEBUG] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1cee4e/192.168.20.38:6668: Received MessageWrapper{commandType=DP_QUERY, content='TcpStatusPayload{protocol=-1, devId='41014556483fda1cee4e', gwId='', uid='', t=0, dps={1=false, 3=28.0}, data=Data{dps={}}}'}
2025-12-24 15:04:59.312 [TRACE] [a.internal.handler.TuyaDeviceHandler] - 'tuya:tuyaDevice:41014556483fda1cee4e' received status message '{1=false, 3=28.0}'
2025-12-24 15:04:59.326 [TRACE] [rnal.local.handlers.HeartbeatHandler] - bf04f6821e15db0a4arkij/192.168.1.220:6668: Sending ping
2025-12-24 15:04:59.332 [DEBUG] [.internal.local.handlers.TuyaDecoder] - bf04f6821e15db0a4arkij/192.168.1.220:6668: Received MessageWrapper{commandType=HEART_BEAT, content='[B@20b191bb'}
2025-12-24 15:04:59.332 [TRACE] [rnal.local.handlers.HeartbeatHandler] - bf04f6821e15db0a4arkij/192.168.1.220:6668: Received pong
2025-12-24 15:05:00.040 [DEBUG] [.internal.local.handlers.TuyaEncoder] - udpDiscoverySender: Sending REQ_DEVINFO, payload {from=app, ip=192.168.1.206}
2025-12-24 15:05:01.712 [DEBUG] [.internal.local.handlers.TuyaDecoder] - udpListener: Received MessageWrapper{commandType=BROADCAST_LPV34, content='DiscoveryMessage{ip='192.168.1.220', deviceId='bf04f6821e15db0a4arkij', active=2, ability=0, mode=0, encrypt=true, productKey='p8z27***', version='3.4', token=true, wf_cfg=true}'}
2025-12-24 15:05:01.809 [DEBUG] [.internal.local.handlers.TuyaDecoder] - udpListener: Received MessageWrapper{commandType=BROADCAST_LPV34, content='DiscoveryMessage{ip='192.168.1.12', deviceId='bf3e12bb0d710bc6ffgaja', active=2, ability=0, mode=0, encrypt=true, productKey='ifj19h***', version='3.4', token=true, wf_cfg=true}'}
I’ve made a build for 5.1 and posted it here:
The forum doesn’t let me upload anything bigger than 1 MB, so I couldn’t upload it here.
I’m not sure if this can only be dropped in the addons folder (after unzipping) or not. I suspect that the original bundle must first be stopped, and then this one manually started after dropping it in the addons folder, but there are others who know the Karaf stuff bettter than me.
It would be very helpful if somebody that has this problem could test the bundle I uploaded at GitHub, as it would show if the suspected change is the cause or not.
Will do!
Thx and Merry Christmas!
Hi @Nadahar & @mjagdis,
I upgraded again to openhab 5.1 and tried the new jar file @Nadahar provided but the error still exists:
2025-12-24 21:57:35.550 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1cee4e' changed from ONLINE to ONLINE: Waiting for device wake up
2025-12-24 21:57:35.935 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1c6101' changed from ONLINE: Waiting for device wake up to ONLINE
2025-12-24 21:57:36.557 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1cee4e' changed from ONLINE: Waiting for device wake up to ONLINE
2025-12-24 21:57:36.804 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4192.168.20.166: Connection seems to be dead.
2025-12-24 21:57:36.805 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4/192.168.20.166:6668: channel closed
2025-12-24 21:57:36.805 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 310002588caab562aee4: disconnected
2025-12-24 21:57:36.807 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:36.809 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:310002588caab562aee4' changed from ONLINE to ONLINE: Waiting for device wake up
2025-12-24 21:57:36.810 [TRACE] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending encoded '000055AA000000030000001200000018D954A34ED454BEF188CEEC3FD5713E27C42CB7AE0000AA55'
2025-12-24 21:57:36.874 [TRACE] [nding.tuya.internal.util.NetworkUtil] - Local IPv4 address is: 192.168.1.206
2025-12-24 21:57:36.874 [TRACE] [.internal.local.handlers.TuyaEncoder] - udpDiscoverySender: Sending REQ_DEVINFO, payload {from=app, ip=192.168.1.206}
2025-12-24 21:57:36.875 [TRACE] [.internal.local.handlers.TuyaEncoder] - udpDiscoverySendernull: Sending encoded '00006699000000000001000000250000003F27AC315EEAB04DDDBD91D8A1EF2C522807F23FD80F62C8B4FF3F9478101B483627FB294E30D32F0013B03C64C9173C07FF9F6D325B47C53E1BECCD130EAC8B00009966'
2025-12-24 21:57:36.876 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Received encoded '00006699000000000001000000250000003F27AC315EEAB04DDDBD91D8A1EF2C522807F23FD80F62C8B4FF3F9478101B483627FB294E30D32F0013B03C64C9173C07FF9F6D325B47C53E1BECCD130EAC8B00009966'
2025-12-24 21:57:36.876 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Protocol version '3.5'
2025-12-24 21:57:36.881 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Decoded raw payload: 6F6D223A22617070222C226970223A223139322E3136382E312E323036227D
2025-12-24 21:57:36.882 [DEBUG] [.internal.local.handlers.TuyaDecoder] - udpListener: Received MessageWrapper{commandType=REQ_DEVINFO, content='om":"app","ip":"192.168.1.206"}'}
2025-12-24 21:57:37.808 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4/192.168.20.166:6668: reconnect
2025-12-24 21:57:37.809 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4: connecting
2025-12-24 21:57:37.812 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Received encoded '000055AA0000000000000023000000BC00000000D09766676F3369EB10B5E9F132FD802A7FBF3BA4B7BA6F0D689546C57F5F9F00995AEABF4FDAC881A4304220A5A678B428BDD461C14C52B49CB7652765FD722D7256F992EF0BB3C9946F6CA8E2E148532E0DBC9A92C3317286EBF238BE579786842E044C221F202FCBFDF20F6A158C4782874F9F203CE14EA9850DB1A8DAC9236FBDAC3E9DD4C59ED6077A3713A1F534C5F75CC69C6A0E153160A17BC40ACC9BF710AAE30275845704B34769A7F2181A13505BF00000AA55'
2025-12-24 21:57:37.812 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Protocol version '3.1'
2025-12-24 21:57:37.812 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Decoded raw payload: 7B226970223A223139322E3136382E312E323230222C2267774964223A22626630346636383231653135646230613461726B696A222C22616374697665223A322C2261626C696C7974223A302C22656E6372797074223A747275652C2270726F647563744B6579223A22[MASKED]222C2276657273696F6E223A22332E34222C22746F6B656E223A747275652C2277665F636667223A747275657D090909090909090909
2025-12-24 21:57:37.824 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4/192.168.20.166:6668: channel connected
2025-12-24 21:57:37.825 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 310002588caab562aee4: connected
2025-12-24 21:57:37.825 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_QUERY, payload {devId=310002588caab562aee4, uid=310002588caab562aee4, t=1766609857, dps=[], gwId=310002588caab562aee4}
2025-12-24 21:57:37.825 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:310002588caab562aee4' changed from ONLINE: Waiting for device wake up to ONLINE
2025-12-24 21:57:37.827 [TRACE] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending encoded '000055AA000000010000000A00000088321424E2EFA44085CBF9538B441F099970BF70F153A4840ADE6052A99317088EE576E1EDFDE905E8F44E4E714CA668466C20FB105238EB5538F0AF458405BD0E8C29378F1141220FCD2E423E57CDA010B31CABA2694EB7998845A5EB6C60BC302A285A201390233C32F298C3EE11FAE00A989910075F48197D2A82174E1511FF7B3136AF0000AA55'
2025-12-24 21:57:37.830 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Received MessageWrapper{commandType=BROADCAST_LPV34, content='DiscoveryMessage{ip='192.168.1.220', deviceId='bf04f6821e15db0a4arkij', active=2, ability=0, mode=0, encrypt=true, productKey='[MASKED]', version='3.4', token= true, wf_cfg=true}'}
2025-12-24 21:57:37.872 [TRACE] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Received encoded '000055AA000000010000000A0000004C00000000321424E2EFA44085CBF9538B441F099970BF70F153A4840ADE6052A99317088E537F284B2133B5353E6116CEA5B2CC668ECE88C80ADCC43A619AFDC88DFB88D0FE1931CB0000AA55'
2025-12-24 21:57:37.872 [TRACE] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Protocol version '3.3'
2025-12-24 21:57:37.873 [TRACE] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Decoded raw payload: 7B226465764964223A223331303030323538386361616235363261656534222C22647073223A7B2231223A66616C73652C2233223A32387D7D07070707070707
2025-12-24 21:57:37.878 [DEBUG] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Received MessageWrapper{commandType=DP_QUERY, content='TcpStatusPayload{protocol=-1, devId='310002588caab562aee4', gwId='', uid='', t=0, dps={1=false, 3=28.0}, data=Data{dps={}}}'}
2025-12-24 21:57:38.011 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:38.011 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending encoded '000055AA000000030000001200000018F4E3EC6CA1F29FAE8149E8122285587ED770BB720000AA55'
2025-12-24 21:57:38.013 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101192.168.20.7: Connection seems to be dead.
2025-12-24 21:57:38.014 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101/192.168.20.7:6668: channel closed
2025-12-24 21:57:38.014 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1c6101: disconnected
2025-12-24 21:57:38.014 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1c6101' changed from ONLINE to ONLINE: Waiting for device wake up
2025-12-24 21:57:38.586 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:38.587 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending encoded '000055AA0000000300000012000000185D085D580690B047172174707ADB03499C72A81F0000AA55'
2025-12-24 21:57:38.587 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e192.168.20.38: Connection seems to be dead.
2025-12-24 21:57:38.587 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e/192.168.20.38:6668: channel closed
2025-12-24 21:57:38.587 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1cee4e: disconnected
2025-12-24 21:57:38.588 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1cee4e' changed from ONLINE to ONLINE: Waiting for device wake up
2025-12-24 21:57:38.879 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:38.880 [TRACE] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending encoded '000055AA000000020000001200000018D954A34ED454BEF188CEEC3FD5713E2761A727A00000AA55'
2025-12-24 21:57:39.015 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101/192.168.20.7:6668: reconnect
2025-12-24 21:57:39.016 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101: connecting
2025-12-24 21:57:39.024 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101/192.168.20.7:6668: channel connected
2025-12-24 21:57:39.025 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1c6101: connected
2025-12-24 21:57:39.025 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending DP_QUERY, payload {devId=41014556483fda1c6101, uid=41014556483fda1c6101, t=1766609859, dps=[], gwId=41014556483fda1c6101}
2025-12-24 21:57:39.025 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending encoded '000055AA000000010000000A000000888272BDCD908ED703905E66BB340B579E38407C83A0A30F9468E45B9B05A63A5B14A1C81C84BF6C28C0F1202BB02F836040F419CA30DB5C04BA555939FC0DED984AC6E2E434BE2A8574EC8B5444BAA57951537886692F5E83FF7FA136DADC98D73EEDAB3105AD52B80A39F8CBB88D1C08EC2EA584A34CD2947464A1FB91A9F6BAD74E76390000AA55'
2025-12-24 21:57:39.026 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1c6101' changed from ONLINE: Waiting for device wake up to ONLINE
2025-12-24 21:57:39.067 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Received encoded '000055AA000000010000000A0000004C000000008272BDCD908ED703905E66BB340B579E38407C83A0A30F9468E45B9B05A63A5B6411FE5E4EB6E5774928E35BFCA121E9DFEBDD3EECC07B53EF85C33238A17B454CA1FF350000AA55'
2025-12-24 21:57:39.068 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Protocol version '3.3'
2025-12-24 21:57:39.068 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Decoded raw payload: 7B226465764964223A223431303134353536343833666461316336313031222C22647073223A7B2231223A66616C73652C2233223A32387D7D07070707070707
2025-12-24 21:57:39.068 [DEBUG] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Received MessageWrapper{commandType=DP_QUERY, content='TcpStatusPayload{protocol=-1, devId='41014556483fda1c6101', gwId='', uid='', t=0, dps={1=false, 3=28.0}, data=Data{dps={}}}'}
2025-12-24 21:57:39.589 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e/192.168.20.38:6668: reconnect
2025-12-24 21:57:39.590 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e: connecting
2025-12-24 21:57:39.614 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e/192.168.20.38:6668: channel connected
2025-12-24 21:57:39.614 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1cee4e: connected
2025-12-24 21:57:39.614 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending DP_QUERY, payload {devId=41014556483fda1cee4e, uid=41014556483fda1cee4e, t=1766609859, dps=[], gwId=41014556483fda1cee4e}
2025-12-24 21:57:39.615 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1cee4e' changed from ONLINE: Waiting for device wake up to ONLINE
2025-12-24 21:57:39.615 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending encoded '000055AA000000010000000A00000088E88186DEDB6A4003BE3A327AD9F960C84C2DCDAC812C04EF15A55F0D55BEB851CD998C98F5F005D38A69FE2AD128EDA3D5893426C3C0797271EDB71B84038580ED01BCD09BF0E7092FEF989BFBECBC6179E4E2EF9BCAB5CB64A297FA5FFDD0427C52F50DF99F835F757D87348EE530BC98FD59B1D1BDBB27C3D032AD7590E4AE216AA9270000AA55'
2025-12-24 21:57:39.645 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1cee4e/192.168.20.38:6668: Received encoded '000055AA000000010000000A0000004C00000000E88186DEDB6A4003BE3A327AD9F960C84C2DCDAC812C04EF15A55F0D55BEB851B0071805B3347F14ED5CC694B98CC17EFB96A183BEF8636A35DE90B257863B30E8561BCD0000AA55'
2025-12-24 21:57:39.645 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1cee4e/192.168.20.38:6668: Protocol version '3.3'
2025-12-24 21:57:39.645 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1cee4e/192.168.20.38:6668: Decoded raw payload: 7B226465764964223A223431303134353536343833666461316365653465222C22647073223A7B2231223A66616C73652C2233223A32387D7D07070707070707
2025-12-24 21:57:39.645 [DEBUG] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1cee4e/192.168.20.38:6668: Received MessageWrapper{commandType=DP_QUERY, content='TcpStatusPayload{protocol=-1, devId='41014556483fda1cee4e', gwId='', uid='', t=0, dps={1=false, 3=28.0}, data=Data{dps={}}}'}
2025-12-24 21:57:39.879 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:39.879 [TRACE] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending encoded '000055AA000000030000001200000018D954A34ED454BEF188CEEC3FD5713E27C42CB7AE0000AA55'
2025-12-24 21:57:39.879 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4192.168.20.166: Connection seems to be dead.
2025-12-24 21:57:39.880 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4/192.168.20.166:6668: channel closed
2025-12-24 21:57:39.880 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 310002588caab562aee4: disconnected
2025-12-24 21:57:39.880 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:310002588caab562aee4' changed from ONLINE to ONLINE: Waiting for device wake up
2025-12-24 21:57:39.883 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Received encoded '000055AA0000000000000023000000BC00000000D09766676F3369EB10B5E9F132FD802ABC9CD9E46759B27EEC90C6D6F8A71362A3F6A39869EE560AE5DFA3B1DD140744A73248F5F18E1A63680D8A0F0A479182C2FB8459B1155FC75D4BF6699F92CBA4C0BA520148045E7605FA0498DFEA5AABC50DE74620E65BDCDE5E1C9600B988824215B2ABEE9F123C63CE4A9DCA574FC20616CD44036F7601AB71F0AA8391A55CE0913A793742322B90964948DAD4B60CC0097B6CDCAA5A148223B3246686A12ECF796A1E0000AA55'
2025-12-24 21:57:39.883 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Protocol version '3.1'
2025-12-24 21:57:39.884 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Decoded raw payload: 7B226970223A223139322E3136382E312E3132222C2267774964223A2262663365313262623064373130626336666667616A61222C22616374697665223A322C2261626C696C697479223A302C22656E6372797074223A747275652C2270726F647563744B6579223A22[MASKED]222C2276657273696F6E223A22332E34222C22746F6B656E223A747275652C2277665F636667223A747275657D0A0A0A0A0A0A0A0A0A0A
2025-12-24 21:57:39.884 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Received MessageWrapper{commandType=BROADCAST_LPV34, content='DiscoveryMessage{ip='192.168.1.12', deviceId='bf3e12bb0d710bc6ffgaja', active=2, ability=0, mode=0, encrypt=true, productKey='[MASKED]', version='3.4', token= true, wf_cfg=true}'}
2025-12-24 21:57:40.069 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:40.069 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending encoded '000055AA000000020000001200000018F4E3EC6CA1F29FAE8149E8122285587E72FB2B7C0000AA55'
2025-12-24 21:57:40.646 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:40.646 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending encoded '000055AA0000000200000012000000185D085D580690B047172174707ADB034939F938110000AA55'
2025-12-24 21:57:40.882 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4/192.168.20.166:6668: reconnect
2025-12-24 21:57:40.882 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4: connecting
2025-12-24 21:57:40.887 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4/192.168.20.166:6668: channel connected
2025-12-24 21:57:40.888 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 310002588caab562aee4: connected
2025-12-24 21:57:40.888 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:310002588caab562aee4' changed from ONLINE: Waiting for device wake up to ONLINE
2025-12-24 21:57:40.889 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_QUERY, payload {devId=310002588caab562aee4, uid=310002588caab562aee4, t=1766609860, dps=[], gwId=310002588caab562aee4}
2025-12-24 21:57:40.889 [TRACE] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending encoded '000055AA000000010000000A00000088321424E2EFA44085CBF9538B441F099970BF70F153A4840ADE6052A99317088EE576E1EDFDE905E8F44E4E714CA668466C20FB105238EB5538F0AF458405BD0EE4BE3D001E76EF4F53473167EF8216C4B31CABA2694EB7998845A5EB6C60BC302A285A201390233C32F298C3EE11FAE00A989910075F48197D2A82174E1511FF92EC27980000AA55'
2025-12-24 21:57:40.923 [TRACE] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Received encoded '000055AA000000010000000A0000004C00000000321424E2EFA44085CBF9538B441F099970BF70F153A4840ADE6052A99317088E537F284B2133B5353E6116CEA5B2CC668ECE88C80ADCC43A619AFDC88DFB88D0FE1931CB0000AA55'
2025-12-24 21:57:40.923 [TRACE] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Protocol version '3.3'
2025-12-24 21:57:40.924 [TRACE] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Decoded raw payload: 7B226465764964223A223331303030323538386361616235363261656534222C22647073223A7B2231223A66616C73652C2233223A32387D7D07070707070707
2025-12-24 21:57:40.924 [DEBUG] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Received MessageWrapper{commandType=DP_QUERY, content='TcpStatusPayload{protocol=-1, devId='310002588caab562aee4', gwId='', uid='', t=0, dps={1=false, 3=28.0}, data=Data{dps={}}}'}
2025-12-24 21:57:41.069 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:41.069 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending encoded '000055AA000000030000001200000018F4E3EC6CA1F29FAE8149E8122285587ED770BB720000AA55'
2025-12-24 21:57:41.069 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101192.168.20.7: Connection seems to be dead.
2025-12-24 21:57:41.070 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101/192.168.20.7:6668: channel closed
2025-12-24 21:57:41.070 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1c6101: disconnected
2025-12-24 21:57:41.070 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1c6101' changed from ONLINE to ONLINE: Waiting for device wake up
2025-12-24 21:57:41.646 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:41.646 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending encoded '000055AA0000000300000012000000185D085D580690B047172174707ADB03499C72A81F0000AA55'
2025-12-24 21:57:41.646 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e192.168.20.38: Connection seems to be dead.
2025-12-24 21:57:41.647 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e/192.168.20.38:6668: channel closed
2025-12-24 21:57:41.647 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1cee4e: disconnected
2025-12-24 21:57:41.647 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1cee4e' changed from ONLINE to ONLINE: Waiting for device wake up
2025-12-24 21:57:41.924 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:41.925 [TRACE] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending encoded '000055AA000000020000001200000018D954A34ED454BEF188CEEC3FD5713E2761A727A00000AA55'
2025-12-24 21:57:42.071 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101/192.168.20.7:6668: reconnect
2025-12-24 21:57:42.071 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101: connecting
2025-12-24 21:57:42.079 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101/192.168.20.7:6668: channel connected
2025-12-24 21:57:42.080 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1c6101: connected
2025-12-24 21:57:42.080 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending DP_QUERY, payload {devId=41014556483fda1c6101, uid=41014556483fda1c6101, t=1766609862, dps=[], gwId=41014556483fda1c6101}
2025-12-24 21:57:42.080 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1c6101' changed from ONLINE: Waiting for device wake up to ONLINE
2025-12-24 21:57:42.081 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending encoded '000055AA000000010000000A000000888272BDCD908ED703905E66BB340B579E38407C83A0A30F9468E45B9B05A63A5B14A1C81C84BF6C28C0F1202BB02F836040F419CA30DB5C04BA555939FC0DED98FDDC3EB4F165AA584ECC21506B20531F51537886692F5E83FF7FA136DADC98D73EEDAB3105AD52B80A39F8CBB88D1C08EC2EA584A34CD2947464A1FB91A9F6BA305E9E2E0000AA55'
2025-12-24 21:57:42.110 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Received encoded '000055AA000000010000000A0000004C000000008272BDCD908ED703905E66BB340B579E38407C83A0A30F9468E45B9B05A63A5B6411FE5E4EB6E5774928E35BFCA121E9DFEBDD3EECC07B53EF85C33238A17B454CA1FF350000AA55'
2025-12-24 21:57:42.110 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Protocol version '3.3'
2025-12-24 21:57:42.111 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Decoded raw payload: 7B226465764964223A223431303134353536343833666461316336313031222C22647073223A7B2231223A66616C73652C2233223A32387D7D07070707070707
2025-12-24 21:57:42.111 [DEBUG] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Received MessageWrapper{commandType=DP_QUERY, content='TcpStatusPayload{protocol=-1, devId='41014556483fda1c6101', gwId='', uid='', t=0, dps={1=false, 3=28.0}, data=Data{dps={}}}'}
2025-12-24 21:57:42.648 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e/192.168.20.38:6668: reconnect
2025-12-24 21:57:42.648 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e: connecting
2025-12-24 21:57:42.660 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e/192.168.20.38:6668: channel connected
2025-12-24 21:57:42.661 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1cee4e: connected
2025-12-24 21:57:42.661 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending DP_QUERY, payload {devId=41014556483fda1cee4e, uid=41014556483fda1cee4e, t=1766609862, dps=[], gwId=41014556483fda1cee4e}
2025-12-24 21:57:42.662 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1cee4e' changed from ONLINE: Waiting for device wake up to ONLINE
2025-12-24 21:57:42.662 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending encoded '000055AA000000010000000A00000088E88186DEDB6A4003BE3A327AD9F960C84C2DCDAC812C04EF15A55F0D55BEB851CD998C98F5F005D38A69FE2AD128EDA3D5893426C3C0797271EDB71B840385808FF76D0D1CF5E150B86F386F6BC4770079E4E2EF9BCAB5CB64A297FA5FFDD0427C52F50DF99F835F757D87348EE530BC98FD59B1D1BDBB27C3D032AD7590E4AEF40762090000AA55'
2025-12-24 21:57:42.691 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1cee4e/192.168.20.38:6668: Received encoded '000055AA000000010000000A0000004C00000000E88186DEDB6A4003BE3A327AD9F960C84C2DCDAC812C04EF15A55F0D55BEB851B0071805B3347F14ED5CC694B98CC17EFB96A183BEF8636A35DE90B257863B30E8561BCD0000AA55'
2025-12-24 21:57:42.692 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1cee4e/192.168.20.38:6668: Protocol version '3.3'
2025-12-24 21:57:42.692 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1cee4e/192.168.20.38:6668: Decoded raw payload: 7B226465764964223A223431303134353536343833666461316365653465222C22647073223A7B2231223A66616C73652C2233223A32387D7D07070707070707
2025-12-24 21:57:42.692 [DEBUG] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1cee4e/192.168.20.38:6668: Received MessageWrapper{commandType=DP_QUERY, content='TcpStatusPayload{protocol=-1, devId='41014556483fda1cee4e', gwId='', uid='', t=0, dps={1=false, 3=28.0}, data=Data{dps={}}}'}
2025-12-24 21:57:42.833 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Received encoded '000055AA0000000000000023000000BC00000000D09766676F3369EB10B5E9F132FD802A7FBF3BA4B7BA6F0D689546C57F5F9F00995AEABF4FDAC881A4304220A5A678B428BDD461C14C52B49CB7652765FD722D7256F992EF0BB3C9946F6CA8E2E148532E0DBC9A92C3317286EBF238BE579786842E044C221F202FCBFDF20F6A158C4782874F9F203CE14EA9850DB1A8DAC9236FBDAC3E9DD4C59ED6077A3713A1F534C5F75CC69C6A0E153160A17BC40ACC9BF710AAE30275845704B34769A7F2181A13505BF00000AA55'
2025-12-24 21:57:42.834 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Protocol version '3.1'
2025-12-24 21:57:42.834 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Decoded raw payload: 7B226970223A223139322E3136382E312E323230222C2267774964223A22626630346636383231653135646230613461726B696A222C22616374697665223A322C2261626C696C697479223A302C22656E6372797074223A747275652C2270726F647563744B6579223A22[MASKED]222C2276657273696F6E223A22332E34222C22746F6B656E223A747275652C2277665F636667223A747275657D090909090909090909
2025-12-24 21:57:42.834 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Received MessageWrapper{commandType=BROADCAST_LPV34, content='DiscoveryMessage{ip='192.168.1.220', deviceId='bf04f6821e15db0a4arkij', active=2, ability=0, mode=0, encrypt=true, productKey='[MASKED]', version='3.4', token= true, wf_cfg=true}'}
2025-12-24 21:57:42.924 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:42.925 [TRACE] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending encoded '000055AA000000030000001200000018D954A34ED454BEF188CEEC3FD5713E27C42CB7AE0000AA55'
2025-12-24 21:57:42.925 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4192.168.20.166: Connection seems to be dead.
2025-12-24 21:57:42.925 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4/192.168.20.166:6668: channel closed
2025-12-24 21:57:42.925 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 310002588caab562aee4: disconnected
2025-12-24 21:57:42.929 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:310002588caab562aee4' changed from ONLINE to ONLINE: Waiting for device wake up
2025-12-24 21:57:43.112 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:43.112 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending encoded '000055AA000000020000001200000018F4E3EC6CA1F29FAE8149E8122285587E72FB2B7C0000AA55'
2025-12-24 21:57:43.693 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:43.693 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending encoded '000055AA0000000200000012000000185D085D580690B047172174707ADB034939F938110000AA55'
2025-12-24 21:57:43.927 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4/192.168.20.166:6668: reconnect
2025-12-24 21:57:43.927 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4: connecting
2025-12-24 21:57:43.932 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4/192.168.20.166:6668: channel connected
2025-12-24 21:57:43.932 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 310002588caab562aee4: connected
2025-12-24 21:57:43.933 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_QUERY, payload {devId=310002588caab562aee4, uid=310002588caab562aee4, t=1766609863, dps=[], gwId=310002588caab562aee4}
2025-12-24 21:57:43.933 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:310002588caab562aee4' changed from ONLINE: Waiting for device wake up to ONLINE
2025-12-24 21:57:43.933 [TRACE] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending encoded '000055AA000000010000000A00000088321424E2EFA44085CBF9538B441F099970BF70F153A4840ADE6052A99317088EE576E1EDFDE905E8F44E4E714CA668466C20FB105238EB5538F0AF458405BD0E57747D5E3CAE05262E4D6F871E476BBAB31CABA2694EB7998845A5EB6C60BC302A285A201390233C32F298C3EE11FAE00A989910075F48197D2A82174E1511FFE38799750000AA55'
2025-12-24 21:57:43.965 [TRACE] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Received encoded '000055AA000000010000000A0000004C00000000321424E2EFA44085CBF9538B441F099970BF70F153A4840ADE6052A99317088E537F284B2133B5353E6116CEA5B2CC668ECE88C80ADCC43A619AFDC88DFB88D0FE1931CB0000AA55'
2025-12-24 21:57:43.966 [TRACE] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Protocol version '3.3'
2025-12-24 21:57:43.966 [TRACE] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Decoded raw payload: 7B226465764964223A223331303030323538386361616235363261656534222C22647073223A7B2231223A66616C73652C2233223A32387D7D07070707070707
2025-12-24 21:57:43.966 [DEBUG] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Received MessageWrapper{commandType=DP_QUERY, content='TcpStatusPayload{protocol=-1, devId='310002588caab562aee4', gwId='', uid='', t=0, dps={1=false, 3=28.0}, data=Data{dps={}}}'}
2025-12-24 21:57:44.124 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101192.168.20.7: Connection seems to be dead.
2025-12-24 21:57:44.124 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101/192.168.20.7:6668: channel closed
2025-12-24 21:57:44.124 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1c6101: disconnected
2025-12-24 21:57:44.130 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1c6101' changed from ONLINE to ONLINE: Waiting for device wake up
2025-12-24 21:57:44.693 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:44.693 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending encoded '000055AA0000000300000012000000185D085D580690B047172174707ADB03499C72A81F0000AA55'
2025-12-24 21:57:44.694 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e192.168.20.38: Connection seems to be dead.
2025-12-24 21:57:44.694 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e/192.168.20.38:6668: channel closed
2025-12-24 21:57:44.694 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1cee4e: disconnected
2025-12-24 21:57:44.694 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1cee4e' changed from ONLINE to ONLINE: Waiting for device wake up
2025-12-24 21:57:44.880 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Received encoded '000055AA0000000000000023000000BC00000000D09766676F3369EB10B5E9F132FD802ABC9CD9E46759B27EEC90C6D6F8A71362A3F6A39869EE560AE5DFA3B1DD140744A73248F5F18E1A63680D8A0F0A479182C2FB8459B1155FC75D4BF6699F92CBA4C0BA520148045E7605FA0498DFEA5AABC50DE74620E65BDCDE5E1C9600B988824215B2ABEE9F123C63CE4A9DCA574FC20616CD44036F7601AB71F0AA8391A55CE0913A793742322B90964948DAD4B60CC0097B6CDCAA5A148223B3246686A12ECF796A1E0000AA55'
2025-12-24 21:57:44.881 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Protocol version '3.1'
2025-12-24 21:57:44.881 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Decoded raw payload: 7B226970223A223139322E3136382E312E3132222C2267774964223A2262663365313262623064373130626336666667616A61222C22616374697665223A322C2261626C696C697479223A302C22656E6372797074223A747275652C2270726F647563744B6579223A22[MASKED]222C2276657273696F6E223A22332E34222C22746F6B656E223A747275652C2277665F636667223A747275657D0A0A0A0A0A0A0A0A0A0A
2025-12-24 21:57:44.881 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Received MessageWrapper{commandType=BROADCAST_LPV34, content='DiscoveryMessage{ip='192.168.1.12', deviceId='bf3e12bb0d710bc6ffgaja', active=2, ability=0, mode=0, encrypt=true, productKey='[MASKED]', version='3.4', token= true, wf_cfg=true}'}
2025-12-24 21:57:44.967 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:44.967 [TRACE] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending encoded '000055AA000000020000001200000018D954A34ED454BEF188CEEC3FD5713E2761A727A00000AA55'
2025-12-24 21:57:45.126 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101/192.168.20.7:6668: reconnect
2025-12-24 21:57:45.126 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101: connecting
2025-12-24 21:57:45.147 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101/192.168.20.7:6668: channel connected
2025-12-24 21:57:45.147 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1c6101: connected
2025-12-24 21:57:45.147 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending DP_QUERY, payload {devId=41014556483fda1c6101, uid=41014556483fda1c6101, t=1766609865, dps=[], gwId=41014556483fda1c6101}
2025-12-24 21:57:45.147 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1c6101' changed from ONLINE: Waiting for device wake up to ONLINE
2025-12-24 21:57:45.148 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending encoded '000055AA000000010000000A000000888272BDCD908ED703905E66BB340B579E38407C83A0A30F9468E45B9B05A63A5B14A1C81C84BF6C28C0F1202BB02F836040F419CA30DB5C04BA555939FC0DED984F5AEDDDEB58A9EA5D38C43AF3B78E6D51537886692F5E83FF7FA136DADC98D73EEDAB3105AD52B80A39F8CBB88D1C08EC2EA584A34CD2947464A1FB91A9F6BAB081C5560000AA55'
2025-12-24 21:57:45.178 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Received encoded '000055AA000000010000000A0000004C000000008272BDCD908ED703905E66BB340B579E38407C83A0A30F9468E45B9B05A63A5B6411FE5E4EB6E5774928E35BFCA121E9DFEBDD3EECC07B53EF85C33238A17B454CA1FF350000AA55'
2025-12-24 21:57:45.179 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Protocol version '3.3'
2025-12-24 21:57:45.179 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Decoded raw payload: 7B226465764964223A223431303134353536343833666461316336313031222C22647073223A7B2231223A66616C73652C2233223A32387D7D07070707070707
2025-12-24 21:57:45.179 [DEBUG] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Received MessageWrapper{commandType=DP_QUERY, content='TcpStatusPayload{protocol=-1, devId='41014556483fda1c6101', gwId='', uid='', t=0, dps={1=false, 3=28.0}, data=Data{dps={}}}'}
2025-12-24 21:57:45.606 [TRACE] [nding.tuya.internal.local.TuyaDevice] - bf04f6821e15db0a4arkij192.168.1.220: Sending heart beat
2025-12-24 21:57:45.606 [TRACE] [.internal.local.handlers.TuyaEncoder] - bf04f6821e15db0a4arkij/192.168.1.220:6668: Sending HEART_BEAT, payload {protocol=5, t=1766609865, data={ctype=0, dps=, cid=bf04f6821e15db0a4arkij}}
2025-12-24 21:57:45.607 [TRACE] [.internal.local.handlers.TuyaEncoder] - bf04f6821e15db0a4arkij/192.168.1.220:6668: Sending encoded '000055AA00000016000000090000008409B92BF412BAA2774D0D7428B23E08000D933185FBD2A14F8A41E092EB1C415980C2CE5BD98E9E9069B2FB3B10ED0C6597356B17F8F87466E0CF400D9D8AEA6CD34AC08E9B0F10A4A26E5DDA2E8ED8FAADF9C41EBDA8842AFAB3BE9BD06E4D3FAAAE940E97163AC9E744C8D06E27A518ED9E18AA4A9C5D7C8DA12D3D24F126E40000AA55'
2025-12-24 21:57:45.643 [TRACE] [.internal.local.handlers.TuyaDecoder] - bf04f6821e15db0a4arkij/192.168.1.220:6668: Received encoded '000055AA00006CC4000000090000002800000000CFA6E01C4D01223B640AFC76C0A263133D9200ED285C310F19E7D2EACA09CCB30000AA55'
2025-12-24 21:57:45.643 [TRACE] [.internal.local.handlers.TuyaDecoder] - bf04f6821e15db0a4arkij/192.168.1.220:6668: Protocol version '3.4'
2025-12-24 21:57:45.643 [TRACE] [.internal.local.handlers.TuyaDecoder] - bf04f6821e15db0a4arkij/192.168.1.220:6668: Decoded raw payload:
2025-12-24 21:57:45.643 [TRACE] [.internal.local.handlers.TuyaDecoder] - bf04f6821e15db0a4arkij/192.168.1.220:6668: Received MessageWrapper{commandType=HEART_BEAT, content=''}
2025-12-24 21:57:45.695 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e/192.168.20.38:6668: reconnect
2025-12-24 21:57:45.695 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e: connecting
2025-12-24 21:57:45.967 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:45.967 [TRACE] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending encoded '000055AA000000030000001200000018D954A34ED454BEF188CEEC3FD5713E27C42CB7AE0000AA55'
2025-12-24 21:57:45.967 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4192.168.20.166: Connection seems to be dead.
2025-12-24 21:57:45.968 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4/192.168.20.166:6668: channel closed
2025-12-24 21:57:45.968 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 310002588caab562aee4: disconnected
2025-12-24 21:57:45.968 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:310002588caab562aee4' changed from ONLINE to ONLINE: Waiting for device wake up
2025-12-24 21:57:46.180 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:46.180 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending encoded '000055AA000000020000001200000018F4E3EC6CA1F29FAE8149E8122285587E72FB2B7C0000AA55'
2025-12-24 21:57:46.697 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e/192.168.20.38:6668: Failed to connect: connection timed out after 1000 ms: /192.168.20.38:6668
2025-12-24 21:57:46.875 [TRACE] [nding.tuya.internal.util.NetworkUtil] - Local IPv4 address is: 192.168.1.206
2025-12-24 21:57:46.876 [TRACE] [.internal.local.handlers.TuyaEncoder] - udpDiscoverySender: Sending REQ_DEVINFO, payload {from=app, ip=192.168.1.206}
2025-12-24 21:57:46.876 [TRACE] [.internal.local.handlers.TuyaEncoder] - udpDiscoverySendernull: Sending encoded '00006699000000000001000000250000003FDDAC847096B35A8D5F5557F9EC77B99FBAE38F59ED27575504ACDEE7AC28F53DB930E590CA35773D50538A2530E4148E0C304A0F5E5686388D3A79EC1C915000009966'
2025-12-24 21:57:46.877 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Received encoded '00006699000000000001000000250000003FDDAC847096B35A8D5F5557F9EC77B99FBAE38F59ED27575504ACDEE7AC28F53DB930E590CA35773D50538A2530E4148E0C304A0F5E5686388D3A79EC1C915000009966'
2025-12-24 21:57:46.877 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Protocol version '3.5'
2025-12-24 21:57:46.877 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Decoded raw payload: 6F6D223A22617070222C226970223A223139322E3136382E312E323036227D
2025-12-24 21:57:46.878 [DEBUG] [.internal.local.handlers.TuyaDecoder] - udpListener: Received MessageWrapper{commandType=REQ_DEVINFO, content='om":"app","ip":"192.168.1.206"}'}
2025-12-24 21:57:46.969 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4/192.168.20.166:6668: reconnect
2025-12-24 21:57:46.969 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4: connecting
2025-12-24 21:57:46.987 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4/192.168.20.166:6668: channel connected
2025-12-24 21:57:46.987 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 310002588caab562aee4: connected
2025-12-24 21:57:46.988 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_QUERY, payload {devId=310002588caab562aee4, uid=310002588caab562aee4, t=1766609866, dps=[], gwId=310002588caab562aee4}
2025-12-24 21:57:46.988 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:310002588caab562aee4' changed from ONLINE: Waiting for device wake up to ONLINE
2025-12-24 21:57:46.988 [TRACE] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending encoded '000055AA000000010000000A00000088321424E2EFA44085CBF9538B441F099970BF70F153A4840ADE6052A99317088EE576E1EDFDE905E8F44E4E714CA668466C20FB105238EB5538F0AF458405BD0E9F0FBF6666C788C7D1381B07D1CCB928B31CABA2694EB7998845A5EB6C60BC302A285A201390233C32F298C3EE11FAE00A989910075F48197D2A82174E1511FFF82E192E0000AA55'
2025-12-24 21:57:47.019 [TRACE] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Received encoded '000055AA000000010000000A0000004C00000000321424E2EFA44085CBF9538B441F099970BF70F153A4840ADE6052A99317088E537F284B2133B5353E6116CEA5B2CC668ECE88C80ADCC43A619AFDC88DFB88D0FE1931CB0000AA55'
2025-12-24 21:57:47.020 [TRACE] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Protocol version '3.3'
2025-12-24 21:57:47.020 [TRACE] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Decoded raw payload: 7B226465764964223A223331303030323538386361616235363261656534222C22647073223A7B2231223A66616C73652C2233223A32387D7D07070707070707
2025-12-24 21:57:47.020 [DEBUG] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Received MessageWrapper{commandType=DP_QUERY, content='TcpStatusPayload{protocol=-1, devId='310002588caab562aee4', gwId='', uid='', t=0, dps={1=false, 3=28.0}, data=Data{dps={}}}'}
2025-12-24 21:57:47.180 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:47.180 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending encoded '000055AA000000030000001200000018F4E3EC6CA1F29FAE8149E8122285587ED770BB720000AA55'
2025-12-24 21:57:47.180 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101192.168.20.7: Connection seems to be dead.
2025-12-24 21:57:47.181 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101/192.168.20.7:6668: channel closed
2025-12-24 21:57:47.181 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1c6101: disconnected
2025-12-24 21:57:47.181 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1c6101' changed from ONLINE to ONLINE: Waiting for device wake up
2025-12-24 21:57:47.699 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e: connecting
2025-12-24 21:57:47.814 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Received encoded '000055AA0000000000000023000000BC00000000D09766676F3369EB10B5E9F132FD802A7FBF3BA4B7BA6F0D689546C57F5F9F00995AEABF4FDAC881A4304220A5A678B428BDD461C14C52B49CB7652765FD722D7256F992EF0BB3C9946F6CA8E2E148532E0DBC9A92C3317286EBF238BE579786842E044C221F202FCBFDF20F6A158C4782874F9F203CE14EA9850DB1A8DAC9236FBDAC3E9DD4C59ED6077A3713A1F534C5F75CC69C6A0E153160A17BC40ACC9BF710AAE30275845704B34769A7F2181A13505BF00000AA55'
2025-12-24 21:57:47.814 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Protocol version '3.1'
2025-12-24 21:57:47.815 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Decoded raw payload: 7B226970223A223139322E3136382E312E323230222C2267774964223A22626630346636383231653135646230613461726B696A222C22616374697665223A322C2261626C696C697479223A302C22656E6372797074223A747275652C2270726F647563744B6579223A22[MASKED]222C2276657273696F6E223A22332E34222C22746F6B656E223A747275652C2277665F636667223A747275657D090909090909090909
2025-12-24 21:57:47.815 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Received MessageWrapper{commandType=BROADCAST_LPV34, content='DiscoveryMessage{ip='192.168.1.220', deviceId='bf04f6821e15db0a4arkij', active=2, ability=0, mode=0, encrypt=true, productKey='[MASKED]', version='3.4', token= true, wf_cfg=true}'}
2025-12-24 21:57:48.021 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:48.021 [TRACE] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending encoded '000055AA000000020000001200000018D954A34ED454BEF188CEEC3FD5713E2761A727A00000AA55'
2025-12-24 21:57:48.182 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101/192.168.20.7:6668: reconnect
2025-12-24 21:57:48.183 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101: connecting
2025-12-24 21:57:48.219 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101/192.168.20.7:6668: channel connected
2025-12-24 21:57:48.219 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1c6101: connected
2025-12-24 21:57:48.220 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending DP_QUERY, payload {devId=41014556483fda1c6101, uid=41014556483fda1c6101, t=1766609868, dps=[], gwId=41014556483fda1c6101}
2025-12-24 21:57:48.220 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1c6101' changed from ONLINE: Waiting for device wake up to ONLINE
2025-12-24 21:57:48.220 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending encoded '000055AA000000010000000A000000888272BDCD908ED703905E66BB340B579E38407C83A0A30F9468E45B9B05A63A5B14A1C81C84BF6C28C0F1202BB02F836040F419CA30DB5C04BA555939FC0DED980142CB5115FDE03FDC594C743B8C4C1351537886692F5E83FF7FA136DADC98D73EEDAB3105AD52B80A39F8CBB88D1C08EC2EA584A34CD2947464A1FB91A9F6BA48ACC2920000AA55'
2025-12-24 21:57:48.250 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Received encoded '000055AA000000010000000A0000004C000000008272BDCD908ED703905E66BB340B579E38407C83A0A30F9468E45B9B05A63A5B6411FE5E4EB6E5774928E35BFCA121E9DFEBDD3EECC07B53EF85C33238A17B454CA1FF350000AA55'
2025-12-24 21:57:48.251 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Protocol version '3.3'
2025-12-24 21:57:48.251 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Decoded raw payload: 7B226465764964223A223431303134353536343833666461316336313031222C22647073223A7B2231223A66616C73652C2233223A32387D7D07070707070707
2025-12-24 21:57:48.251 [DEBUG] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Received MessageWrapper{commandType=DP_QUERY, content='TcpStatusPayload{protocol=-1, devId='41014556483fda1c6101', gwId='', uid='', t=0, dps={1=false, 3=28.0}, data=Data{dps={}}}'}
2025-12-24 21:57:48.700 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e/192.168.20.38:6668: Failed to connect: connection timed out after 1000 ms: /192.168.20.38:6668
2025-12-24 21:57:49.021 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:49.021 [TRACE] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending encoded '000055AA000000030000001200000018D954A34ED454BEF188CEEC3FD5713E27C42CB7AE0000AA55'
2025-12-24 21:57:49.021 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4192.168.20.166: Connection seems to be dead.
2025-12-24 21:57:49.022 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4/192.168.20.166:6668: channel closed
2025-12-24 21:57:49.022 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 310002588caab562aee4: disconnected
2025-12-24 21:57:49.022 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:310002588caab562aee4' changed from ONLINE to ONLINE: Waiting for device wake up
2025-12-24 21:57:49.251 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:49.252 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending encoded '000055AA000000020000001200000018F4E3EC6CA1F29FAE8149E8122285587E72FB2B7C0000AA55'
2025-12-24 21:57:49.702 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e: connecting
2025-12-24 21:57:49.882 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Received encoded '000055AA0000000000000023000000BC00000000D09766676F3369EB10B5E9F132FD802ABC9CD9E46759B27EEC90C6D6F8A71362A3F6A39869EE560AE5DFA3B1DD140744A73248F5F18E1A63680D8A0F0A479182C2FB8459B1155FC75D4BF6699F92CBA4C0BA520148045E7605FA0498DFEA5AABC50DE74620E65BDCDE5E1C9600B988824215B2ABEE9F123C63CE4A9DCA574FC20616CD44036F7601AB71F0AA8391A55CE0913A793742322B90964948DAD4B60CC0097B6CDCAA5A148223B3246686A12ECF796A1E0000AA55'
2025-12-24 21:57:49.882 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Protocol version '3.1'
2025-12-24 21:57:49.882 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Decoded raw payload: 7B226970223A223139322E3136382E312E3132222C2267774964223A2262663365313262623064373130626336666667616A61222C22616374697665223A322C2261626C696C697479223A302C22656E6372797074223A747275652C2270726F647563744B6579223A22[MASKED]222C2276657273696F6E223A22332E34222C22746F6B656E223A747275652C2277665F636667223A747275657D0A0A0A0A0A0A0A0A0A0A
2025-12-24 21:57:49.883 [TRACE] [.internal.local.handlers.TuyaDecoder] - udpListener: Received MessageWrapper{commandType=BROADCAST_LPV34, content='DiscoveryMessage{ip='192.168.1.12', deviceId='bf3e12bb0d710bc6ffgaja', active=2, ability=0, mode=0, encrypt=true, productKey='[MASKED]', version='3.4', token= true, wf_cfg=true}'}
2025-12-24 21:57:50.023 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4/192.168.20.166:6668: reconnect
2025-12-24 21:57:50.023 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4: connecting
2025-12-24 21:57:50.085 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 310002588caab562aee4/192.168.20.166:6668: channel connected
2025-12-24 21:57:50.085 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 310002588caab562aee4: connected
2025-12-24 21:57:50.085 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:310002588caab562aee4' changed from ONLINE: Waiting for device wake up to ONLINE
2025-12-24 21:57:50.085 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_QUERY, payload {devId=310002588caab562aee4, uid=310002588caab562aee4, t=1766609870, dps=[], gwId=310002588caab562aee4}
2025-12-24 21:57:50.085 [TRACE] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending encoded '000055AA000000010000000A00000088321424E2EFA44085CBF9538B441F099970BF70F153A4840ADE6052A99317088EE576E1EDFDE905E8F44E4E714CA668466C20FB105238EB5538F0AF458405BD0E27587687809F70DA50ED9770F5FD91E0B31CABA2694EB7998845A5EB6C60BC302A285A201390233C32F298C3EE11FAE00A989910075F48197D2A82174E1511FF31C2D1EC0000AA55'
2025-12-24 21:57:50.130 [TRACE] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Received encoded '000055AA000000010000000A0000004C00000000321424E2EFA44085CBF9538B441F099970BF70F153A4840ADE6052A99317088E537F284B2133B5353E6116CEA5B2CC668ECE88C80ADCC43A619AFDC88DFB88D0FE1931CB0000AA55'
2025-12-24 21:57:50.130 [TRACE] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Protocol version '3.3'
2025-12-24 21:57:50.130 [TRACE] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Decoded raw payload: 7B226465764964223A223331303030323538386361616235363261656534222C22647073223A7B2231223A66616C73652C2233223A32387D7D07070707070707
2025-12-24 21:57:50.131 [DEBUG] [.internal.local.handlers.TuyaDecoder] - 310002588caab562aee4/192.168.20.166:6668: Received MessageWrapper{commandType=DP_QUERY, content='TcpStatusPayload{protocol=-1, devId='310002588caab562aee4', gwId='', uid='', t=0, dps={1=false, 3=28.0}, data=Data{dps={}}}'}
2025-12-24 21:57:50.177 [TRACE] [nding.tuya.internal.local.TuyaDevice] - bf3e12bb0d710bc6ffgaja192.168.1.12: Sending heart beat
2025-12-24 21:57:50.177 [TRACE] [.internal.local.handlers.TuyaEncoder] - bf3e12bb0d710bc6ffgaja/192.168.1.12:6668: Sending HEART_BEAT, payload {protocol=5, t=1766609870, data={ctype=0, dps=, cid=bf3e12bb0d710bc6ffgaja}}
2025-12-24 21:57:50.178 [TRACE] [.internal.local.handlers.TuyaEncoder] - bf3e12bb0d710bc6ffgaja/192.168.1.12:6668: Sending encoded '000055AA0000001B0000000900000084DA2C0738FE3E9158A749B198AA94DCDF11665B7E310E15B752841A187171E3C37EF70A75462FFF2F8372E16DEDCFF216CDDC84217E97744E104B3783200438BA7DEB00F43982CF7D4956374C0A4E4E5635644E7A63FCA2BBDD610E50FEB041F47C373C853AD7935302E74D8DB686BC26E45B392FD2C096C6AB80A095B8CBA4720000AA55'
2025-12-24 21:57:50.184 [TRACE] [.internal.local.handlers.TuyaDecoder] - bf3e12bb0d710bc6ffgaja/192.168.1.12:6668: Received encoded '000055AA000013F1000000090000002800000000042A77B0735A1D994A5CD715EADBBD22BAE4046816AE41968F6BA5C95D5EE3AC0000AA55'
2025-12-24 21:57:50.184 [TRACE] [.internal.local.handlers.TuyaDecoder] - bf3e12bb0d710bc6ffgaja/192.168.1.12:6668: Protocol version '3.4'
2025-12-24 21:57:50.184 [TRACE] [.internal.local.handlers.TuyaDecoder] - bf3e12bb0d710bc6ffgaja/192.168.1.12:6668: Decoded raw payload:
2025-12-24 21:57:50.184 [TRACE] [.internal.local.handlers.TuyaDecoder] - bf3e12bb0d710bc6ffgaja/192.168.1.12:6668: Received MessageWrapper{commandType=HEART_BEAT, content=''}
2025-12-24 21:57:50.252 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:50.252 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending encoded '000055AA000000030000001200000018F4E3EC6CA1F29FAE8149E8122285587ED770BB720000AA55'
2025-12-24 21:57:50.252 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101192.168.20.7: Connection seems to be dead.
2025-12-24 21:57:50.252 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101/192.168.20.7:6668: channel closed
2025-12-24 21:57:50.252 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1c6101: disconnected
2025-12-24 21:57:50.253 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:41014556483fda1c6101' changed from ONLINE to ONLINE: Waiting for device wake up
2025-12-24 21:57:50.703 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e/192.168.20.38:6668: Failed to connect: connection timed out after 1000 ms: /192.168.20.38:6668
2025-12-24 21:57:51.131 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending DP_REFRESH, payload {dpId=[]}
2025-12-24 21:57:51.132 [TRACE] [.internal.local.handlers.TuyaEncoder] - 310002588caab562aee4/192.168.20.166:6668: Sending encoded '000055AA000000020000001200000018D954A34ED454BEF188CEEC3FD5713E2761A727A00000AA55'
2025-12-24 21:57:51.254 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101/192.168.20.7:6668: reconnect
2025-12-24 21:57:51.255 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101: connecting
2025-12-24 21:57:51.291 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1c6101/192.168.20.7:6668: channel connected
2025-12-24 21:57:51.291 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1c6101: connected
2025-12-24 21:57:51.292 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending DP_QUERY, payload {devId=41014556483fda1c6101, uid=41014556483fda1c6101, t=1766609871, dps=[], gwId=41014556483fda1c6101}
2025-12-24 21:57:51.292 [TRACE] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1c6101/192.168.20.7:6668: Sending encoded '000055AA000000010000000A000000888272BDCD908ED703905E66BB340B579E38407C83A0A30F9468E45B9B05A63A5B14A1C81C84BF6C28C0F1202BB02F836040F419CA30DB5C04BA555939FC0DED9847322C84E077176B74B130FA6E6C047751537886692F5E83FF7FA136DADC98D73EEDAB3105AD52B80A39F8CBB88D1C08EC2EA584A34CD2947464A1FB91A9F6BAB19F91750000AA55'
2025-12-24 21:57:51.321 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Received encoded '000055AA000000010000000A0000004C000000008272BDCD908ED703905E66BB340B579E38407C83A0A30F9468E45B9B05A63A5B6411FE5E4EB6E5774928E35BFCA121E9DFEBDD3EECC07B53EF85C33238A17B454CA1FF350000AA55'
2025-12-24 21:57:51.322 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Protocol version '3.3'
2025-12-24 21:57:51.322 [TRACE] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Decoded raw payload: 7B226465764964223A223431303134353536343833666461316336313031222C22647073223A7B2231223A66616C73652C2233223A32387D7D07070707070707
2025-12-24 21:57:51.322 [DEBUG] [.internal.local.handlers.TuyaDecoder] - 41014556483fda1c6101/192.168.20.7:6668: Received MessageWrapper{commandType=DP_QUERY, content='TcpStatusPayload{protocol=-1, devId='41014556483fda1c6101', gwId='', uid='', t=0, dps={1=false, 3=28.0}, data=Data{dps={}}}'}
2025-12-24 21:57:51.705 [TRACE] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e: connecting
2025-12-24 21:57:51.721 [DEBUG] [nding.tuya.internal.local.TuyaDevice] - 41014556483fda1cee4e/192.168.20.38:6668: channel connected
2025-12-24 21:57:51.721 [DEBUG] [a.internal.handler.TuyaDeviceHandler] - 41014556483fda1cee4e: connected
2025-12-24 21:57:51.721 [DEBUG] [.internal.local.handlers.TuyaEncoder] - 41014556483fda1cee4e/192.168.20.38:6668: Sending DP_QUERY, payload {devId=41014556483fda1cee4e, uid=41014556483fda1cee4e, t=1766609871, dps=[], gwId=41014556483fda1cee4e}
Hope the logs are helpful, in the meantime I rolled back to 5.0.3.
BR Andreas
BTW - I uninstalled the original bundle before updating to 5.1 and I also cleaned the cache.
Yeah dropping the unzipped jar file in the addons folder is enough!
