Hello Friends,
I love to use this Binding to control my Warm Water Heat pump.
For some circumstances I want to turn the device off and keep it locked of for 6 hours.
After this 6 hours I try to turn it of again.But it wont turn back on.
Any ideas are welcome.
The log says:
events.log:2025-12-31 03:14:22.295 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command OFF (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 03:14:22.295 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become OFF
events.log:2025-12-31 03:14:22.296 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' changed from ON to OFF (source: org.openhab.core.autoupdate.optimistic)
events.log:2025-12-31 04:10:13.290 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 04:10:13.291 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 04:10:13.292 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' changed from OFF to ON (source: org.openhab.core.autoupdate.optimistic)
events.log:2025-12-31 04:37:23.545 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 04:37:23.546 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 05:01:00.217 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 05:01:00.218 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 05:30:40.949 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 05:30:40.950 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 06:01:00.218 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 06:01:00.219 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 06:24:25.338 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 06:24:25.339 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 07:07:09.770 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 07:07:09.771 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 07:59:20.765 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 07:59:20.766 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:27:55.467 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:27:55.468 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:43:47.743 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:43:47.744 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:44:17.844 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:44:17.845 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:44:38.902 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:44:38.904 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:45:00.042 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:45:00.043 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:45:15.091 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:45:15.092 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:45:39.193 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:45:39.194 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:46:12.339 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:46:12.341 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:46:45.482 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:46:45.482 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:47:27.664 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:47:27.665 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:47:51.764 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:47:51.766 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:48:21.945 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:48:21.946 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:49:04.136 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:49:04.138 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:49:25.264 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:49:25.265 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:49:52.327 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:49:52.328 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:50:28.506 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:50:28.507 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:50:55.646 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:50:55.647 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:51:40.798 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:51:40.800 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:52:10.992 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:52:10.992 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:53:20.303 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:53:20.304 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 08:57:57.546 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 08:57:57.547 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 09:28:35.740 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 09:28:35.740 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 10:01:00.216 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 10:01:00.217 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 10:04:42.799 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' changed from ON to UNDEF (source: org.openhab.core.thing$tuya:tuyaDevice:bf18a6f60fa69011bfqszc:switch)
events.log:2025-12-31 10:05:29.600 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 10:05:29.601 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 10:05:29.603 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' changed from UNDEF to ON (source: org.openhab.core.autoupdate.optimistic)
events.log:2025-12-31 10:07:00.965 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 10:07:00.965 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 10:13:56.826 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 10:13:56.827 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 10:20:34.612 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 10:20:34.613 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 10:24:26.640 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 10:24:26.641 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 10:28:09.706 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 10:28:09.707 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 10:31:00.218 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 10:31:00.220 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 10:33:47.221 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 10:33:47.222 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 10:37:39.266 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 10:37:39.267 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 10:45:35.390 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 10:45:35.391 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 10:51:27.948 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 10:51:27.949 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:00:33.415 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:00:33.415 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:00:42.452 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:00:42.453 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:00:48.465 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:00:48.466 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:00:51.512 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:00:51.513 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:00:54.480 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:00:54.481 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:01:06.580 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:01:06.582 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:01:12.584 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:01:12.585 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:01:21.638 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:01:21.638 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:01:36.697 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:01:36.698 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:02:00.793 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:02:00.794 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:02:58.032 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:02:58.033 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:03:49.268 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:03:49.269 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:03:58.318 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:03:58.320 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:04:01.376 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:04:01.381 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:04:19.469 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:04:19.470 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:04:25.470 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:04:25.470 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:05:04.625 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:05:04.628 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:05:07.670 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:05:07.671 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:05:49.877 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:05:49.879 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:05:52.843 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:05:52.845 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:05:58.851 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:05:58.852 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:06:10.951 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:06:10.952 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:06:13.911 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:06:13.911 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:06:16.959 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:06:16.960 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:06:22.975 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:06:22.976 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:07:08.205 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:07:08.205 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:09:05.711 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:09:05.713 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:09:11.720 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:09:11.722 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:11:00.255 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:11:00.257 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:11:03.223 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:11:03.224 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:11:09.231 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:11:09.232 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:11:24.366 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:11:24.366 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:11:27.333 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:11:27.336 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:11:36.389 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:11:36.390 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:13:03.802 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:13:03.804 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:13:09.809 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:13:09.810 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:15:46.527 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:15:46.528 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:16:10.627 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:16:10.628 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:16:49.777 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:16:49.777 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:17:13.866 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:17:13.867 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:17:19.964 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:17:19.965 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:17:44.055 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:17:44.055 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:18:02.155 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:18:02.156 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:18:05.128 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:18:05.129 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:18:32.269 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:18:32.271 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:19:23.505 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:19:23.507 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:21:08.995 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:21:08.996 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:21:18.048 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:21:18.050 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:24:24.857 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:24:24.860 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:24:30.871 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:24:30.873 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:24:52.006 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:24:52.007 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:25:13.073 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:25:13.074 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:25:28.110 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:25:28.111 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:25:31.164 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:25:31.165 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:26:22.395 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:26:22.396 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:33:50.185 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:33:50.186 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:33:54.453 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:33:54.453 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:34:25.116 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:34:25.116 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
events.log:2025-12-31 11:37:25.360 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' received command ON (source: org.openhab.automation.jsscripting$rule:SetWaterHeatPumpOnOff)
events.log:2025-12-31 11:37:25.361 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Tuya_Hot_Water_Heat_Pump_Switch' predicted to become ON
