info 2021-07-13 23:47:21: Device '0x5c0272fffee16d8c' joined
info 2021-07-13 23:47:21: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x5c0272fffee16d8c","ieee_address":"0x5c0272fffee16d8c"},"type":"device_joined"}'
info 2021-07-13 23:47:21: Starting interview of '0x5c0272fffee16d8c'
info 2021-07-13 23:47:21: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x5c0272fffee16d8c","ieee_address":"0x5c0272fffee16d8c","status":"started"},"type":"device_interview"}'
info 2021-07-13 23:47:21: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"friendly_name":"0x5c0272fffee16d8c"},"type":"device_connected"}'
info 2021-07-13 23:47:21: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_started","meta":{"friendly_name":"0x5c0272fffee16d8c"},"type":"pairing"}'
info 2021-07-13 23:47:21: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x5c0272fffee16d8c","ieee_address":"0x5c0272fffee16d8c"},"type":"device_announce"}'
info 2021-07-13 23:47:22: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"announce","meta":{"friendly_name":"0x5c0272fffee16d8c"},"type":"device_announced"}'
info 2021-07-13 23:47:47: Successfully interviewed '0x5c0272fffee16d8c', device has successfully been paired
info 2021-07-13 23:47:47: Device '0x5c0272fffee16d8c' is supported, identified as: TuYa Curtain motor/roller blind motor/window pusher/tubular motor (TS0601_cover)
info 2021-07-13 23:47:47: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"Curtain motor/roller blind motor/window pusher/tubular motor","exposes":[{"features":[
{"access":3,"name":"state","property":"state","type":"binary","value_off":"CLOSE","value_on":"OPEN"},
{"access":3,"description":"Position of this cover","name":"position","property":"position","type":"numeric","value_max":100,"value_min":0}],"type":"cover"},
{"features":[{"access":3,"description":"Motor speed","name":"motor_speed","property":"motor_speed","type":"numeric","value_max":255,"value_min"0}],
"name":"options","property":"options","type":"composite"},
{"access":1,"description":"Link quality (signal strength)","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"TS0601_cover","supports_ota":false,"vendor":"TuYa"},"friendly_name":"0x5c0272fffee16d8c","ieee_address":"0x5c0272fffee16d8c","status":"successful","supported":true},"type":"device_interview"}'
info 2021-07-13 23:47:48: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_successful","meta":{"description":"Curtain motor/roller blind motor/window pusher/tubular motor","friendly_name":"0x5c0272fffee16d8c","model":"TS0601_cover","supported":true,"vendor":"TuYa"},"type":"pairing"}'
That is the the logging from the mqtt log when it first paired, i did post that before but i didnt know how to post it correctly.
From this I would assume it has three channels…?
Switch that can take a OPEN/CLOSED ?
Number that will accept position in numbers from 0-100
Number that will accept motor speed in numbers from 0-100
If I send it numbers on the position channel from MQTT Explorer it works but cant get it working from the UI.
Ideas?
