If I use both definitions it doesn’t work. I can not open the Kitchen in the web interface any more. If I use only one of them it works fine. What could be the problem or the solution?
Not a KNX guy, but it looks like the binding strings are IDENTICAL. Getting individual device addressability with identical binding strings seems like it requires a form of magic. Then again, not a KNX guy.
This was just an example so I don’t use real KNX group addresses. In my real config they are diffrent. I will change the values so it does not confuse any more
