I have configured my Homematic CCU as follows:
Bridge homematic:bridge:ccu "CCU Bridge" [gatewayAddress="192.168.178.66", callbackHost="192.168.178.53"]
Thing HM-Sec-SCo OEQ1557949 "Kontakt Haustuer"
Thing HM-Sec-SCo OEQ1558379 "Kontakt Dachfenster"
Thing HM-Sec-SCo OEQ1558420 "Kontakt Kellerfenster"
The items are configured as below:
Contact Haustuer "Haustuer [MAP(HM-Sec-SCo.map):%s]" {channel="homematic:HM-Sec-SCo:ccu:OEQ1557949:1#STATE"}
Contact FensterKeller "FensterKeller [MAP(HM-Sec-SCo.map):%s]" {channel="homematic:HM-Sec-SCo:ccu:OEQ1558420:1#STATE"}
Contact FensterDach "FensterDach [MAP(HM-Sec-SCo.map):%s]" {channel="homematic:HM-Sec-SCo:ccu:OEQ1558379:1#STATE"}
My sitemap looks as follows:
sitemap demo label="My Demo" {
Frame label="Date" {
Text item=Date
Frame label="Kontakte" {
Text item=Haustuer
Text item=FensterDach
Text item=FensterKeller
Unfortunately, when I open one of the two windows (OEQ1558420, OEQ1558379) when both are closed, the UI shows both windows as open. The same is true for closing one window and keeping the other open. This means, both optical sensors show the same state in the openhab UI.
In the CCU Web UI this is not the case, i.e. both windows and the door are reported correctly and separately from each other.
Do you have any ideas?
Openhab 2.3.0 as Docker image on a Raspberrypi 3
