Hi All
Noticed this on 2.4 stable, is this normal?
265 │ Active │ 80 │ 3.14.0 │ nrjavaserial
266 │ Active │ 80 │ 3.15.0.OH2 │ nrjavaserial
Hi All
I wouldn’t have thought so, but I see the same here:
openhab> bundle:list | grep -i javaserial
200 │ Active │ 80 │ 3.14.0 │ nrjavaserial
201 │ Active │ 80 │ 3.15.0.OH2 │ nrjavaserial
I haven’t experienced any problems (that I am aware of) with any of the installed bindings that use a serial connection.
Thanks Scott. I’ve removed the 265 bundle anyway and see. I’m having a raft of Zwave issues, ill try anything
I poked around in my local, up-to-date copies of the various openhab and ESH repositories. It looks like karaf has a dependency on nrjavaserial-3.14.0:
[scott@frisbee-ii smarthome (master)]$ find . -type f -exec fgrep -H nrjavaserial '{}' \;
./targetplatform/smarthome.target:<unit id="com.neuronrobotics.nrjavaserial" version="0.0.0"/>
./extensions/binding/org.eclipse.smarthome.binding.bluetooth.bluegiga.test/org.eclipse.smarthome.binding.bluetooth.bluegiga.test.launch:<setEntry value="nrjavaserial:default"/>
./extensions/binding/org.eclipse.smarthome.binding.bluetooth.test/org.eclipse.smarthome.binding.bluetooth.test.launch:<setEntry value="nrjavaserial:default"/>
./features/karaf/esh-tp/src/main/feature/feature.xml: <bundle>mvn:com.neuronrobotics/nrjavaserial/3.14.0</bundle>
Well ive uninstalled it so ill guess Ill see what explodes, it can’t get any worse to be honest. Im near giving up on this!
