Hi Guys,
I bought two zwave wallplugs with dimmerfunction. Each single dimmer works well.
Dimmer Dimmer1 “” { zwave=“2:command=SWITCH_MULTILEVEL,respond_to_basic=true” }
Dimmer Dimmer2 “” { zwave=“3:command=SWITCH_MULTILEVEL,respond_to_basic=true” }
But I need an ambient-slider wich effects the two dimmers at the same time.
My first idea was a rule. (One rule to dimm them all )
But I discoverd that there is the possibility to add more than one zwave binding to one item.
So I made a slider with to zwave nodes:
Dimmer Stimmungslicht “Stimmungslicht” { zwave=“3:command=SWITCH_MULTILEVEL,respond_to_basic=true”, zwave=“2:command=SWITCH_MULTILEVEL,respond_to_basic=true” }
But these slider has only effect an the first binding. When I chance the order of the nodes the effect changes too.
Any advise for me?
