2020-08-01 13:03:48.635 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 00 02 09 71 05 00 00 00 FF 06 17 00 B9 00 C2
2020-08-01 13:03:48.664 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 09 71 05 00 00 00 FF 06 17 00 B9 00
2020-08-01 13:03:48.667 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 09 71 05 00 00 00 FF 06 17 00 B9 00
2020-08-01 13:03:48.668 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 00 02 09 71 05 00 00 00 FF 06 17 00 B9 00 C2
2020-08-01 13:03:48.669 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-08-01 13:03:48.671 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
2020-08-01 13:03:48.673 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2020-08-01 13:03:48.675 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-08-01 13:03:48.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY NOT required on COMMAND_CLASS_ALARM
2020-08-01 13:03:48.678 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_ALARM V5 NOTIFICATION_REPORT
2020-08-01 13:03:48.680 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 2: NOTIFICATION report - 0 = 0, event=23, status=255, plen=0
2020-08-01 13:03:48.682 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 2: Alarm Type = ACCESS_CONTROL (0)
2020-08-01 13:03:48.684 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-08-01 13:03:48.686 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-08-01 13:03:48.688 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter processing NOTIFICATION
2020-08-01 13:03:48.690 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter NOTIFICATION event is 23, type OnOffType
2020-08-01 13:03:48.692 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter processing NOTIFICATION
2020-08-01 13:03:48.694 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 09 71 05 00 00 00 FF 06 17 00 B9 00
2020-08-01 13:03:48.694 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter NOTIFICATION event is 23, type OpenClosedType
2020-08-01 13:03:48.696 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating channel state zwave:device:d1117a3c:node2:sensor_door to CLOSED [OpenClosedType]
2020-08-01 13:03:48.698 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter processing NOTIFICATION
2020-08-01 13:03:48.706 [vent.ItemStateChangedEvent] - Kontakt_Wohnzimmer_Terassentuer changed from OPEN to CLOSED
2020-08-01 13:03:48.706 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter NOTIFICATION event is 23, type OnOffType
2020-08-01 13:03:48.707 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter processing NOTIFICATION
2020-08-01 13:03:48.708 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter NOTIFICATION event is 23, type OnOffType
2020-08-01 13:03:48.709 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
2020-08-01 13:03:48.710 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@340cbd.
2020-08-01 13:03:48.711 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-01 13:03:48.712 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-01 13:03:48.714 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=0, payload=00 02 09 71 05 00 00 00 FF 06 17 00 B9 00
2020-08-01 13:03:48.715 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-08-01 13:03:48.716 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
2020-08-01 13:03:48.717 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
2020-08-01 13:03:48.718 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-08-01 13:03:48.718 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY NOT required on COMMAND_CLASS_ALARM
2020-08-01 13:03:48.719 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_ALARM V5 NOTIFICATION_REPORT
2020-08-01 13:03:48.720 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 2: NOTIFICATION report - 0 = 0, event=23, status=255, plen=0
2020-08-01 13:03:48.721 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 2: Alarm Type = ACCESS_CONTROL (0)
2020-08-01 13:03:48.722 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-08-01 13:03:48.723 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-08-01 13:03:48.724 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter processing NOTIFICATION
2020-08-01 13:03:48.725 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter NOTIFICATION event is 23, type OnOffType
2020-08-01 13:03:48.726 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter processing NOTIFICATION
2020-08-01 13:03:48.727 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter NOTIFICATION event is 23, type OpenClosedType
2020-08-01 13:03:48.728 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating channel state zwave:device:d1117a3c:node2:sensor_door to CLOSED [OpenClosedType]
2020-08-01 13:03:48.730 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter processing NOTIFICATION
2020-08-01 13:03:48.731 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter NOTIFICATION event is 23, type OnOffType
2020-08-01 13:03:48.732 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter processing NOTIFICATION
2020-08-01 13:03:48.733 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 2: Alarm converter NOTIFICATION event is 23, type OnOffType
2020-08-01 13:03:48.734 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
2020-08-01 13:03:48.735 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@bc7124.
2020-08-01 13:03:48.736 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-01 13:03:48.737 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-01 13:03:48.738 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-08-01 13:03:48.739 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-08-01 13:03:50.694 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 00 03 09 71 05 00 00 00 FF 06 16 00 B9 00 C2
2020-08-01 13:03:50.724 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 09 71 05 00 00 00 FF 06 16 00 B9 00
2020-08-01 13:03:50.726 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 09 71 05 00 00 00 FF 06 16 00 B9 00
2020-08-01 13:03:50.727 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-08-01 13:03:50.729 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2020-08-01 13:03:50.730 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2020-08-01 13:03:50.731 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-08-01 13:03:50.733 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_ALARM
2020-08-01 13:03:50.734 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_ALARM V5 NOTIFICATION_REPORT
2020-08-01 13:03:50.735 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 3: NOTIFICATION report - 0 = 0, event=22, status=255, plen=0
2020-08-01 13:03:50.736 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 3: Alarm Type = ACCESS_CONTROL (0)
2020-08-01 13:03:50.738 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-08-01 13:03:50.740 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-08-01 13:03:50.741 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 00 03 09 71 05 00 00 00 FF 06 16 00 BB 00 C0
2020-08-01 13:03:50.741 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:50.743 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 22, type OnOffType
2020-08-01 13:03:50.745 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:50.746 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 22, type OpenClosedType
2020-08-01 13:03:50.747 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:d1117a3c:node3:sensor_door to OPEN [OpenClosedType]
2020-08-01 13:03:50.751 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:50.752 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 22, type OnOffType
2020-08-01 13:03:50.754 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:50.755 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 22, type OnOffType
2020-08-01 13:03:50.757 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2020-08-01 13:03:50.758 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5d43e1.
2020-08-01 13:03:50.760 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-01 13:03:50.761 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-01 13:03:50.762 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-08-01 13:03:50.763 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-08-01 13:03:50.773 [vent.ItemStateChangedEvent] - Kontakt_Wohnzimmer_Terassentuer changed from CLOSED to OPEN
2020-08-01 13:03:50.774 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 09 71 05 00 00 00 FF 06 16 00 BB 00
2020-08-01 13:03:50.777 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 09 71 05 00 00 00 FF 06 16 00 BB 00
2020-08-01 13:03:50.779 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-08-01 13:03:50.781 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2020-08-01 13:03:50.783 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2020-08-01 13:03:50.784 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-08-01 13:03:50.786 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_ALARM
2020-08-01 13:03:50.787 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_ALARM V5 NOTIFICATION_REPORT
2020-08-01 13:03:50.789 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 3: NOTIFICATION report - 0 = 0, event=22, status=255, plen=0
2020-08-01 13:03:50.791 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 3: Alarm Type = ACCESS_CONTROL (0)
2020-08-01 13:03:50.793 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-08-01 13:03:50.794 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-08-01 13:03:50.798 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:50.799 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 22, type OnOffType
2020-08-01 13:03:50.800 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:50.801 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 22, type OpenClosedType
2020-08-01 13:03:50.802 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:d1117a3c:node3:sensor_door to OPEN [OpenClosedType]
2020-08-01 13:03:50.805 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:50.806 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 22, type OnOffType
2020-08-01 13:03:50.807 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:50.808 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 22, type OnOffType
2020-08-01 13:03:50.809 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2020-08-01 13:03:50.810 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@127c0e8.
2020-08-01 13:03:50.811 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-01 13:03:50.812 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-01 13:03:50.814 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-08-01 13:03:50.815 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-08-01 13:03:51.835 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 00 03 09 71 05 00 00 00 FF 06 17 00 B9 00 C3
2020-08-01 13:03:51.864 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 09 71 05 00 00 00 FF 06 17 00 B9 00
2020-08-01 13:03:51.866 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 09 71 05 00 00 00 FF 06 17 00 B9 00
2020-08-01 13:03:51.868 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-08-01 13:03:51.870 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2020-08-01 13:03:51.871 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2020-08-01 13:03:51.873 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-08-01 13:03:51.874 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_ALARM
2020-08-01 13:03:51.876 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_ALARM V5 NOTIFICATION_REPORT
2020-08-01 13:03:51.878 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 3: NOTIFICATION report - 0 = 0, event=23, status=255, plen=0
2020-08-01 13:03:51.880 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 3: Alarm Type = ACCESS_CONTROL (0)
2020-08-01 13:03:51.881 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-08-01 13:03:51.883 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-08-01 13:03:51.885 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:51.887 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 23, type OnOffType
2020-08-01 13:03:51.889 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:51.891 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 23, type OpenClosedType
2020-08-01 13:03:51.893 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:d1117a3c:node3:sensor_door to CLOSED [OpenClosedType]
2020-08-01 13:03:51.897 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:51.899 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 23, type OnOffType
2020-08-01 13:03:51.901 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:51.903 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 23, type OnOffType
2020-08-01 13:03:51.905 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2020-08-01 13:03:51.907 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1e46815.
2020-08-01 13:03:51.909 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-01 13:03:51.911 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-01 13:03:51.913 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-08-01 13:03:51.914 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-08-01 13:03:51.917 [vent.ItemStateChangedEvent] - Kontakt_Wohnzimmer_Terassentuer changed from OPEN to CLOSED
2020-08-01 13:03:51.919 [vent.ItemStateChangedEvent] - Kontakt_Eingangstuere changed from OPEN to CLOSED
2020-08-01 13:03:51.949 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 00 03 09 71 05 00 00 00 FF 06 16 00 B9 00 C2
2020-08-01 13:03:51.973 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 09 71 05 00 00 00 FF 06 16 00 B9 00
2020-08-01 13:03:51.975 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 09 71 05 00 00 00 FF 06 16 00 B9 00
2020-08-01 13:03:51.975 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-08-01 13:03:51.976 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2020-08-01 13:03:51.977 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2020-08-01 13:03:51.978 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-08-01 13:03:51.978 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_ALARM
2020-08-01 13:03:51.979 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_ALARM V5 NOTIFICATION_REPORT
2020-08-01 13:03:51.980 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 3: NOTIFICATION report - 0 = 0, event=22, status=255, plen=0
2020-08-01 13:03:51.981 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 3: Alarm Type = ACCESS_CONTROL (0)
2020-08-01 13:03:51.982 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-08-01 13:03:51.983 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-08-01 13:03:51.984 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:51.985 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 22, type OnOffType
2020-08-01 13:03:51.986 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:51.987 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 22, type OpenClosedType
2020-08-01 13:03:51.988 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:d1117a3c:node3:sensor_door to OPEN [OpenClosedType]
2020-08-01 13:03:51.990 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:51.991 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 22, type OnOffType
2020-08-01 13:03:51.992 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter processing NOTIFICATION
2020-08-01 13:03:51.993 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 3: Alarm converter NOTIFICATION event is 22, type OnOffType
2020-08-01 13:03:51.997 [vent.ItemStateChangedEvent] - Kontakt_Wohnzimmer_Terassentuer changed from CLOSED to OPEN
2020-08-01 13:03:51.998 [vent.ItemStateChangedEvent] - Kontakt_Eingangstuere changed from CLOSED to OPEN
2020-08-01 13:03:52.006 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2020-08-01 13:03:52.007 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@38039c.
2020-08-01 13:03:52.008 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-01 13:03:52.009 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-08-01 13:03:52.010 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
