First i bought a TZ69 smart meter switch device witch worked just fine. Then i decided to buy 3 additional tz69 switches.
To bad the new tz69 switches are marked as unknown device cant do anything with them now.
The XML from the working TZ69:
<node>
<homeId>0xfb0bff27</homeId>
<nodeId>2</nodeId>
<version>4</version>
<manufacturer>0x118</manufacturer>
<deviceId>0x2</deviceId>
<deviceType>0x4</deviceType>
<listening>true</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>1000</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_METER</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_BINARY</commandClass>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_ALL</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<associations>
<associationMember>
<node>1</node>
</associationMember>
</associations>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SWITCH_BINARY</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_POWER_SWITCH_BINARY</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<COMMAND__CLASS__SWITCH__BINARY>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__SWITCH__BINARY>
</entry>
<entry>
<COMMAND__CLASS__FIRMWARE__UPDATE__MD>
<versionSupported>2</versionSupported>
</COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<zwPlusVersion>1</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_ALWAYS_ON</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<autoSubscribeGroups/>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>280</deviceManufacturer>
<deviceType>4</deviceType>
<deviceId>2</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<configParameters>
<entry>
<int>1</int>
<configurationParameter>
<index>1</index>
<size>1</size>
<value>1</value>
<readOnly>false</readOnly>
<writeOnly>false</writeOnly>
</configurationParameter>
</entry>
<entry>
<int>2</int>
<index>2</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>3</int>
<index>3</index>
<size>2</size>
<value>720</value>
</entry>
<entry>
<int>4</int>
<index>4</index>
<size>2</size>
<value>6</value>
</entry>
<entry>
<int>5</int>
<index>5</index>
<size>2</size>
<value>3000</value>
</entry>
<entry>
<int>6</int>
<index>6</index>
<size>2</size>
<value>10000</value>
</entry>
</configParameters>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<COMMAND__CLASS__BASIC>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<version>2</version>
<maxGroups>1</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>4.5</protocolVersion>
<applicationVersion>2.53</applicationVersion>
<hardwareVersion>1</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__SWITCH__ALL>
<mode>SWITCH_ALL_INCLUDE_ON_OFF</mode>
</COMMAND__CLASS__SWITCH__ALL>
</entry>
<entry>
<COMMAND__CLASS__METER>
<version>3</version>
<versionSupported>3</versionSupported>
<meterType>ELECTRIC</meterType>
<meterScales>
<meterScale>E_A</meterScale>
<meterScale>E_V</meterScale>
<meterScale>E_Power_Factor</meterScale>
<meterScale>E_W</meterScale>
<meterScale>E_KWh</meterScale>
</meterScales>
<canReset>true</canReset>
<isSupportRequestSupported>true</isSupportRequestSupported>
</COMMAND__CLASS__METER>
</entry>
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
</COMMAND__CLASS__NO__OPERATION>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors>
<int>1</int>
<int>3</int>
<int>4</int>
<int>5</int>
</nodeNeighbors>
<lastReceived>2019-05-19 18:44:45.893 UTC</lastReceived>
</node>
XML of the not working nodes:
<node>
<nodeId>8</nodeId>
<deviceId>0x3119</deviceId>
<deviceType>0x116</deviceType>
<associationGroups class="concurrent-hash-map"/>
<entry>
<int>0</int>
<endPoint>
<deviceClass>
</deviceClass>
<entry>
<version>0</version>
<instances>0</instances>
<versionSupported>0</versionSupported>
</entry>
<entry>
<configParameters/>
</entry>
<entry>
<maxGroups>0</maxGroups>
</entry>
<entry>
</entry>
<entry>
<protocolVersion>3.67</protocolVersion>
<applicationVersion>3.1</applicationVersion>
</entry>
<entry>
</entry>
<entry>
<deviceType>278</deviceType>
<deviceId>12569</deviceId>
</entry>
<entry>
<meterScales>
</meterScales>
</entry>
<entry>
</entry>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2019-05-19 18:44:53.159 UTC</lastReceived>
</node>
Does anyone has a idea how to resolve this?your code goes here
