make sure that you don’t have 2 jars in addons and clear tmp + cache
if it still appears: try bundle:uninstall 239 (or something similar… i can’t check atm)
I renamed version 2.2.0.jar in the addons folder, (renamed it´s extention to .old), and afterwards cleared the cache/tmp folders. This is where my problems started in the first place. Is renaming not enough?
I can however give it another go, and delete the version 2.2.0 first. I just wonder why rename it´s extension shouldn´t work.
Gave it a new try. (actually 2 tries as the first try gave me problems again with 2.3.0 failing to load).
Second try I downloaded a fresh copy of the jar file (build 10). Cleared the cache/tmp again, and started Openhab service..
Now I don´t get any errors. 2.3.0 loads fine, and no errors about 2.2.0 not beeing found. (Guess it´s gone for good now).
So I guess everything is fine now.. Thx for you´r help.
No neither. Though I remember playing with the Unifi API and it allowed you to cycle through all the connected devices on an AP…but there is an overall client list, as I use it for feeding an influxdb with data usage per device.
this thread has grown to 368 posts. For someone just joining in this is a lot to read. Is there a documentation of how to set up and use the binding? Maybe even for manual setup?
Thanks in advance!
Alex
Thanks! That’s what I was looking for.
Now I somehow need to get the lastSeen on the sitemap to show in the local timezone…
EDIT: Solved timezone issue. I needed to add the timezone to the EXTRA_JAVA_OPTS. Setting it under “System” in PaperUI was not enough. I know this is not a UniFi Binding issue, but a OpenHAB2 one…
EDIT2: @mgbowman Maybe the link to the documentation can be added to the first post?
jwiseman
(Mr. Wiseman (OH 4.3.8 Stable on Pi4))
375
Great job on this!
It took me 1/2 hour and I was up and running with it using Synology NAS with OH2.3.
My only suggestion would be to report the THINGS as being offline when controller HTTP port is down. In the log file it’s just giving a HTTP error of 503 and the THINGS are still online.
now that I have the presence part working, I’m already starting with a feature request
It would be great if one could not only read info about clients, but also do changes in the controller. I would like to enable and disable the guest network.
I’ve just installed my first Ubiquiti access point, and would like to start playing with the binding. I’m running 2.4.0 build 1314 and can’t find it in the list of bindings. What do I need to do to get it installed and start playing?
Thanks - copied it to my addons folder and within a couple of minutes had all my mobile devices set up - and presence detection working the best it ever has! No more network binding for me!
2018-07-24 13:48:12.671 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler UniFiControllerThingHandler tried updating the thing status although the handler was already disposed.
2018-07-24 13:48:23.672 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler UniFiControllerThingHandler tried updating the thing status although the handler was already disposed.
2018-07-24 13:48:34.672 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler UniFiControllerThingHandler tried updating the thing status although the handler was already disposed.
2018-07-24 13:48:45.673 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler UniFiControllerThingHandler tried updating the thing status although the handler was already disposed.
These messages begin whan openHAB is started, and continue every Refresh Interval even after stopping the binding. The only way I’ve found to resolve this is to restart openHAB.
I’m running this version of the binding, which admittedly is not the most current version. Let me know if you think this might be resolved in a more recent version.
